XINHONGXIN XHX QY-309Bi SnBi solder paste - real!
11 posts / 0 new
Agro
Agro's picture
Last seen: 4 weeks 12 hours ago
After buying 2 “Sn42Bi58” wires (Mechanic, UYUE) which turned out to be fake I tried again. There was no other wire, so I bought a paste.
I run an experiment:
On the tip of my iron I put 2 blobs of solder paste, Mechanic SnPb and Auchans SnBi. I turned the iron on with the lowest temperature setting – 200 C.
Expected result:
Once the tip is heated both pastes are melted. Auchans is melted way quicker.
Actual result:
Once the iron stops heating neither paste is melted.
But if I keep waiting, Auchans melts.
If I wait much longer – Mechanic melts as well.
So really thermal control of my iron is quite bad.
I have no idea what was the melting temperature of Auchans. But it was clearly lower than that of Mechanic.
What else can I do to check if I got the real stuff?
ADDED:
I bought a TM-902C thermocouple.
After I set my iron to 180C I checked temperature – a bit lower than set, 171 C. Depending on the touched part of the tip, 171 was the hottest, ~150 coolest.
The iron has melted the paste with ease.
Edited by: Agro on 09/20/2018 - 17:43
contactcr
Last seen: 4 hours 44 min ago
Use a stove top and IR temp gun instead as if you were going to reflow it?
I cant really answer your question but that should get you much closer to an accurate temp
Lexel
Lexel's picture
Last seen: 10 months 2 weeks ago
heat up a bigger copper part like an MCPCB with iron
check temperature with IR thermometer when you see the Paste starts to melt
make sure the IR thermometer does not see reflective metal parts of the MCPCB, like using some tape or other stuff to cover it
nsl18
Last seen: 1 week 3 days ago
Argo, product link?
Agro
Agro's picture
I bought from
https://www.aliexpress.com/item/60g-Sn42Bi58-QY-309Bi-Low-Temperature-Le...
That was the cheapest at the time. Though expensive compared to the fakes I bought before.
Barkuti
Barkuti's picture
Last seen: 1 hour 50 min ago
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
duramax
Good product, pricey but if the quality is high it shouldn’t matter too much.
Boaz
Boaz's picture
Last seen: 18 hours 1 min ago
tastes real to me
Barkuti
Barkuti's picture
Suggestion for Agro: I prefer to properly name stuff and of course I believe it can be of a lot of help for related searches. I'd edit the title to include the actual product brand and name: (XINHONGXIN) XHX QY-309Bi.
Agro
Agro's picture
You’re right, fixed
Agro
Agro's picture
After I set my iron to 180C I checked tip temperature – a bit lower than set, 171 C. Depending on the touched part of the tip, 171 was the hottest, ~150 coolest.
