WTS: Calibration lights for DIY integrating spheres / lumen tubes - 67 € -
333 posts / 0 new
maukka
maukka's picture
Last seen: 6 months 4 days ago
Since the lux meter is probably not filtered perfectly I would use different correction factors for different types of lights. Check out djozz’s great lux meter tests for more info. Test1, test2, test3, test4, test5.
Texas_Ace
Texas_Ace's picture
Last seen: 5 days 12 hours ago
peabody wrote:
Here we go with the math again.(Steel’s lights)I took Maukkas readings at 30 sec. So we got 35 and 34.1 which is somewhere around .972. (so if 40 is the reading-38.88) And we got 98 and 94.5 which is somewhere around .965. (so if the reading is 485-468.02) Now, since we have a difference should we average the .972 and .965? ( .968.5 ) We get up into the higher numbers with the S2 and the number goes smaller ,say .945 do we just average all numbers or just the two calibrated lights we have? Sorry to be so dumb about this. Math is not my forte’.
The difference is mostly due to the tint of LED I am guessing.
These cheap meters are effected by the tint of the LED. Meters that are not biased would cost as much as the whole sphere.
There is not much that can be done to correct for the tint bias sadly outside of buying a $100++ lux meter.
Texas_Ace
Texas_Ace's picture
Yep, I agree. I know for a fact that these meters (and every other meter I have tried in the sub $100 price range) are biased to cooler tints.
djozz
djozz's picture
Last seen: 31 min 1 sec ago
I just yesterday found out that my most used integrating sphere warms up the spectrum by a few hundred K, maybe I should use a cheaper luxmeter to compensate for that Party
JasonWW
JasonWW's picture
Last seen: 1 day 7 hours ago
I would not do any math. It’s not about super accuracy. I would use the number right off the meter for NW lights.
For CW I would just bump it down about 3% worth. So a cool white light measuring 1000 lm would be 970, etc… Easy peasy.
djozz
djozz's picture
I have a new Extech LT45 luxmeter (to be tested together with some other new luxmeters) that because of the imperfect spectrum sensitivity has pre-sets for different light tints, which is about the same what you suggest here. Smile
steel_1024
steel_1024's picture
Smooth surface, face to face
Grooves are outward
Scotch tape fixed on both sides
Minor reduction of light
Put into the tube
Leave some gap between the illuminometer and the tube
Fully charged battery eneloop AAA
I get perfect data
BLF 348
Olight i3E EOS
Sorry for my poor english.
JasonWW
JasonWW's picture
I can see a lot of light escaping.
Maybe those small lights need a tighter fitting centering ring?
Geuzzz
Geuzzz's picture
Last seen: 2 hours 16 sec ago
Not if it’s calibrated correct right now. Don’t touch anything, just enjoy Beer
JasonWW
JasonWW's picture
I disagree. Plus I don’t think it’s calibrated. If keeping the leaking light in the tube makes the readings go up, then it’s reading high.
In my opinion, the fit around the light should be a bit tighter (although it doesn’t always seem to make that big of a change) and the lux meter needs to be pushed all the way in. This is how you will get consistent results with other lights.
steel_1024
First test:LuminTop ODF30
moon: 11
Low:191
Med:682
High:2140
Turbo:4270
ODF30 Now
moon: 4
Low:124
Med:447
High:1423
Turbo:2850
Standard flashlight test light escaping too much?
djozz
djozz's picture
Light escaping is not a problem by itself, consistency is when the escaping light is the same fraction for all lights.
JasonWW
JasonWW's picture
Exactly my point.
Texas_Ace
Texas_Ace's picture
I just tested with my own BLF348 and it read 1 lumen higher with a custom centering ring vs the smallest normal ring.
JasonWW
JasonWW's picture
And what about with your lux meter slightly pulled out?
Texas_Ace
Texas_Ace's picture
The meter position will be relative, it will effect all the readings by a fixed percentage. It basically becomes part of the calibration.
That said I do not recommend using the meter position as part of the calibration as it is too hard to keep it consistent over the long term.
Adding a little electrical tape to the inside of the 1st bend would be a better way to fine tune the readings since that will not be effected by bumping the sphere.
JasonWW
JasonWW's picture
That was the point I was trying to make earlier. It’s best to put the meter all the way in so that it’s consistent and then find some other way to adjust the output up or down to get the correct Lumen reading straight from the meter.
Also, the vast majority of my lights have a fairly decent fit through the centering ring holes. If I were going to be using those extra small diameter lights to do the calibration, I would probably rig up something simple to prevent that extra light from getting out.
Sorry if I sounded grumpy.
Newlumen
Newlumen's picture
moon: 11
Low:191
Med:682
High:2140
Turbo:4270
ODF30 Now
moon: 4
Low:124
Med:447
High:1423
Turbo:2850
Thats about right.. i got 3150 lumen @ turn on.. and 3090 lumen.. odf30 is a joke.. sometimes turbo mode doesnt want to work… lumintop should have use spring tailcap.. oh well..
JasonWW
JasonWW's picture
Newlumen wrote:
moon: 11
Low:191
Med:682
High:2140
Turbo:4270
ODF30 Now
moon: 4
Low:124
Med:447
High:1423
Turbo:2850
I think it’s a pretty good light.
The tail cap lacks springyness. Just pull the tab up a little so the battery gets compressed. Then you should get turbo for about 1m30s or more. I might replace that tab for a regular spring and bypass it.
I got about 3050 lumen at 30s.
I don’t use it because it lacks a mode around 1000 lm and has the weird one click on and press/hold off. Also, I don’t like glued lights.
I can’t seem to find any 26650 boost driver light that meets my needs. I’m just waiting for Lexel to start selling his drivers.
vestureofblood
vestureofblood's picture
Last seen: 2 days 14 hours ago
My lights came today. I will give a report once I have some time to play. Thanks again Maukka
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
maukka
maukka's picture
More lights arrived today. All the people on the list will have their sets sent out this week.
yasenf
Last seen: 5 hours 36 min ago
I also got my lights – very happy, thanks Maukka!
slimkango
slimkango's picture
Last seen: 7 months 21 hours ago
PPal sent! Thank you very much!
Terry Oregon
Terry Oregon's picture
Last seen: 1 day 12 hours ago
What carrier is delivering these in the U.S.  ?
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK,  Convoy S21A LINK
peabody
Last seen: 5 days 4 hours ago
Not that it matters but VoB got his his really quick. Probably paid extra for the shipping. As far as who is delivering them in the states I have no clue. I would think usps will eventually end up delivering them.
They will get here when they get here.
moderator007
moderator007's picture
Last seen: 6 months 1 week ago
I have been rushing to the mailbox everyday after work, nothing yet. I usually don’t to get excited about new lights but these, I feel like a 10 year old at Christmas. Big Smile
nkresho
nkresho's picture
Last seen: 3 months 4 weeks ago
Got mine via USPS today. Thanks! Can’t wait to get calibrating. Thanks maukka!
For those who are antsy (I was), it wasn’t in my informed delivery app, just showed up.
Terry Oregon
Thanks, that tells me I don't need to check the front of my house for packages after USPS has delivered the regular mail.
nkresho
nkresho's picture
It fit in the mailbox easily. And I’ve got a regular sized mailbox.
Newlumen
Newlumen's picture
Those who received calibrate lights should post lumen. Thanks
