Emisar D4S review
2439 posts / 0 new
Turby3Pots
Turby3Pots's picture
Last seen: 10 months 3 weeks ago
fixed it wrote:
Did it come off cleanly? That would be much easier indeed except I’m not 100% sure about it.
Oh yeah it comes right off, though the DC-FIX is trash after that; one time use only.
i only ran it for like 4 minutes so i’m not sure how it affected the beam overall
fixed it
Last seen: 2 years 2 weeks ago
Thanks. Will try it once the light gets here. I’ll try to take pictures too.
Mark M
Mark M's picture
Last seen: 15 hours 29 min ago
Overall I love the new firmware! I love the new stepped ramping. Good job ToyKeeper. Thanks for all of your hard work.
I do have some feedback after using it a few days. The most annoying feature is not being able to exit momentary mode without pulling the battery. I understand why momentary mode has no exit. In my opinion it should take more than 4 clicks to activate it since the mode has no exit function built in. Because of timing idiosyncrasies I always seemingly activate momentary mode instead of lockout when the light is off. I find that I have to slow down my clicking. The fact that I have pull the battery to exit is frustrating, at least this is open source so I am going to reflash it with some changes.
The other other feedback that I have is that it takes longer for the light to turn off when in ramping mode. I guess because it is waiting to see if there is any more user input? But the delay seems oddly long.
I appreciate the flashing breakout being accessible.
LichtAn
Last seen: 1 year 3 months ago
Current on Turbo was everything between 11 and 18 Amps on turbo. It’s highly dependant on how hard you press on the battery while measuring. If you have short cells, I could imagine you’re missing out on quiet some current. Guess a bypass would be beneficial.
Is double click turbo affected by my ramp ceiling? I didn’t press anything when setting the ceiling, so I assume it’s on maximum? Well if I double click from off and then double click again when it’s on, it gets a bit brighter. is this intended? I thought turbo is turbo. Edit: This just happens with the stepped mode, on ramping double click is full power directly.
ToyKeeper
ToyKeeper's picture
Last seen: 3 days 16 hours ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
LichtAn wrote:
D4S XP-L recieved today. The light is too good to be true. Does the V3 UI fit on the D1 and D4? Oh I just found the source code. Looks like I need a flashing interface. Big Smile
The V3 UI fits on the D1 and D4, but if you’re going to flash them, you may as well upgrade to Anduril. It’s what I use, at least.
http://budgetlightforum.com/node/56105
I also find it inconvenient that momentary is 4 clicks and lockout is 6 clicks. This is fixed in Anduril, which uses 4 clicks for lockout.
If you feel the click timeout is too long, change a couple of definitions and re-compile the code. Specifically, change these:
#define HOLD_TIMEOUT 24
#define RELEASE_TIMEOUT 24
Each unit (tick) is 16 ms, so one second is 62 ticks. Higher values make it easier to enter long sequences, lower values make the entire interface respond faster.
ToyKeeper
ToyKeeper's picture
Double-click from off goes to the current ramp’s ceiling.
Double-click while on goes to full turbo.
In config modes, if you don’t press anything, the value is not changed.
Each ramp has its own ceiling and floor.
ToyKeeper
ToyKeeper's picture
Nicolicous wrote:
It’s a nice design but i lost the wow factor for brightness. My eyes are use to lights with >16k lumens
I hope you weren’t expecting 16k lumens from a light this size with a single battery, especially without active cooling. The tech for that doesn’t even exist yet.
JordanZHP
Last seen: 2 min 44 sec ago
alex64 wrote:
DeusLight wrote:
My D4s was delivered today in the UK!
Does anyone know if there is likely to be a frosted optic option in the future, or possibly some other colour options / aux LED colours? I think purple would look great.
Time ago I post a link with the optionals flood lens from Ledil.
alex64 wrote:
I’m a big fan of flood beam and in my D4 I use the Carclo 10623 instead of 10622 for better flood. The D4S it seems that uses the Ledil Angie-S and for people like me Ledil have Angie-M and Angie-W with more angle of light/flood (and less throw). I don’t know if they are going to be compatible but I think if.
https://eu.mouser.com/Ledil/Optoelectronics/LED-Lighting/LED-Lighting-Op...
Thanks for the link! Which of the 5 available would be best for flood? These should fit the D4S no problem?
LichtAn
Ah nice thanks for the explanation. Then I correct myself on the maximum current for the XP-L Hi version to be between 16.5A and 18A on a Golisi 4200 cell.
So maximum ceiling in config is reached by pressing once during ceiling setup? Seems like in stepped it’s lower than in ramping.
And how do I reach the 3×7135 mode in stepped mode? Also with twist off and on?
Let me thank you for this great piece of UI. Just had the flashlight out with me. It’s just such a pleasure to use. I need more of them.
Pete7874
Pete7874's picture
Last seen: 3 hours 12 min ago
What does D4S weigh, excluding cell?
ToyKeeper
ToyKeeper's picture
Yes, but it’ll go to the nearest configured step instead of going exactly to the 3×7135 level.
DeusLight
Last seen: 1 year 8 months ago
Hi JordanZHP, I think C12288_ANGIE-W would be the best for flood judging from the 37degree viewing angle.
jdh00
jdh00's picture
Last seen: 10 months 1 week ago
145g (5.1oz)
Pete7874
Pete7874's picture
Thanks!
deleted-200707
Last seen: 1 year 6 months ago
kept trying to compare, on a white wall, my new green D4S XP-L 3A to my grey D4 XP-L 3A….no way Jose!
I had to get out my Q8 to approximate the throw and brightness.
Me like 2time at least!
Mark M
Mark M's picture
Thank you for pointing out the code changes!
deleted-200707
well, the protected 26650 in my Rofis MR70 will not fit in my D4S (too long)
butt I can charge the Shockli IMR26650 5500mAh from RMM in the MR70 just fine
and I can use either in the MR70 to charge anything using USB for recharge
very handy and useful
Herb Tarlek
Herb Tarlek's picture
Last seen: 19 hours 58 min ago
I can’t speak for vendors in other countries, but after doing some Googling it looks like all the U.S.-based vendors are out of stock, and most list a 6 week lead time.
This might be a good thing for intl-outdoor or Mountain Electronics to stock…? I’d almost certainly buy one from them (assuming the cost of shipping weren’t $8 like Mouser. Tired )
I want a cool white light about as much as I want Cool Ranch Soda.
"Gerecht pointed his light. Like us, he was carrying an eyeball-melting flashlight that carried for a long ways. Monster Hunters wanted all the lumens." --Larry Correia, Monster Hunter: Siege
SM03
SM03's picture
Last seen: 3 years 4 months ago
this D4S throws just as far as my Klarus XT11GTXHP 35 Hi! I’m new here so forgive my ignorance. I showed a buddy at work my newly acquired D4S and he instantly bought one yesterday from mtn! Toykeeper, I could see the smooth ramp function on this light alone selling Big to the general public! My wife’s mom thought it was.. and I quote, “a really nice mood light” lol.
Now the momentary tactical mode In my opinion is perfect! I love that it cannot exit this mode without untwisting the tailcap for a set amount of time. This is truly a re-invention of the modern day LED flashlight. This light is actually fun to operate and learn all the modes too with the flow chart!
ToyKeeper
ToyKeeper's picture
It’s a better mood light with Anduril installed. That adds, among other things, candle mode. Works well with a traffic wand or something over the bezel.
ToyKeeper
ToyKeeper's picture
Gavka wrote:
ToyKeeper and Friends. Please tell me how to flash this light.
Click the Link in my signature for more information.
Also, for the pinouts, this might help. I refer to it while figuring out where to poke wires through my D4S driver.
http://flashlightwiki.com/AVR_Drivers#Set_up_your_clip
LichtAn
@ToyKeeper
How do you feel about these arguments for an estimate of levels?
./level_calc.py 2 150 7135 1 0.5 400 FET 1 10 4300
ToyKeeper
ToyKeeper's picture
Gavka wrote:
ToyKeeper, thank you! These holes in battery side driver used by acupuncture-style with a set of six pins ? Six holes for six pins for easy flashing firmware without disassembly the head?
Yes.
It’s a bit primitive, but it works and it uses parts which are easy to get.
ToyKeeper
ToyKeeper's picture
LichtAn wrote:
@ToyKeeper
You should be able to check the accuracy by comparing known levels to what the computed ramp says. For example, level 85 is the 3×7135 mode and should be about 400 lm with XP-L HI emitters.
I’d suggest checking a few points along the curve, like 1, 40, 85, 120, and 150. Then adjust the parameters until all of those line up with the expected values.
Because the calculator and the actual light won’t necessarily agree, it may be necessary to split the ramp into two parts and calculate them separately. Probably levels 1 to 85 in one segment, and 86 to 150 in another segment. It’s a little tricky getting the calculated shape to match, which is why I haven’t already made a reference chart.
Additionally, the 219c curve will be different because all its FET values are multiplied by 0.8. This is because Hank was getting complaints about 219c emitters burning themselves out on turbo, so the 219c “turbo” is 80% power.
LichtAn
I’ll try this.
How are the discrete modes in the actual firmware calculated? Sorry if I missed that, if it’s already written somewhere.
ToyKeeper
ToyKeeper's picture
They’re evenly-spaced along the ramp. Floor at one end, ceiling at the other end, and “num steps – 2” levels between.
Because a few people have asked, I added a stepped ramp calculator called “steps.py” in the anduril directory. Here is an example of its usage:
> ./steps.py 1 150 10
1: 1
2: 17
3: 34
4: 50
5: 67
6: 83
7: 100
8: 116
9: 133
10: 150
Or, using the D4S default values, here is the result:
> ./steps.py 20 120 7
1: 20
2: 36
3: 53
4: 70
5: 86
6: 103
7: 120
zeroflow
Last seen: 11 months 2 days ago
Another solution until the pogo pins arrive: just use a piece of breadboard with some crooked pin headers as the programming vias are not aligned on a 100mil grid.
It may not be the best solution, but it’s faster than connecting all 6 pins seperate each time.
Adapter for the D4S is on the left, Clip for D4 / Q8 is on the right.
Also, if you don’t have an AVR ISP but own an arduino you can program the arduino to act as an ISP.
The_Flashaholic
The_Flashaholic's picture
Last seen: 1 month 1 week ago
Gavka wrote:
You are so great one! It works without any desassembling!
Do you plan to add OFF-timer? It will be great, believe me. One minute = One click. Could you make sub-menu for this timer? Is it possible?
I love the timer feature on the Olight S1R. If Hank could give us a diffused side light, motion sensor and timer in the D4GT I’d have his baby.
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - http://www.youtube.com/c/FLASHAHOLIC_TV
patmurris
patmurris's picture
Last seen: 2 months 4 days ago
Received a grey Nichia D4S today from Intl-outdoor – ordered August 3 (20 days ago).
ohbreeeezy
ohbreeeezy's picture
Last seen: 3 months 2 days ago
Anyone got a pic of the magnet tailcap?
