3 Minute 30 Cent Mods
26 posts / 0 new
Boaz
Boaz's picture
Last seen: 2 hours 36 min ago
 I'd like to have a place we could put our simplest of all mods.
 Modifications that are simple , cost next to nothing and easy enough that anyone new or experienced can accomplish.
 - Tonight I took a bolt .filed down the head ,cut down the threads with a hacksaw . Used JB weld to glue a small magnet on top, painted it black with an indelible marker.
Simple easy and adds a magnet to my Jetbeam Jet1-mk and my Nitecore EZ-AA
   Next time I'll file the bolts head at an angle so the light will have different angle options when stuck to a metal object .
  Show us your super easy mod that anyone can do .
pennzy
pennzy's picture
Last seen: 7 hours 44 min ago
My only quickie mod is one I have stated before. Gluing a washer around my SP10’s side switch to mitigate inadvertent activation ,as I prefer this method to lock out . Now it is my EDC light at work mixed in with keys and other pocket junk and have never found it on unless the moon mode gets me by accident. Had to learn to check it before putting it in the pocket.
Geuzzz
Geuzzz's picture
I like baking the ano of a flashlight. Should cost you less than 30ct of gas.
nottawhackjob
Last seen: 1 hour 3 min ago
If you’re gonna describe something getting modded by filing, altering dimensions, affixing it to some other part, etc., then provide pictures, sketches, links, whatever, or it can be confusing cuz what I THINK you said may not be what you MEANT and what you meant may not be exactly what ya DID.
A picture sez a thousand words and a thousand words may still not really get the picture.
IOW what the hell did ya do and most importantly HOW did ya do it? I mean if we’re gonna try and make things truly stupid simple.
LOL Cool Beer
“In many things in order to truly understand the small picture you have to understand the big picture first.”
Lightbringer
Lightbringer's picture
Last seen: 35 min 23 sec ago
• 20mm TIR lens of your choice dropped into an S2+ in place of the reflector. Beautiful blending of the beam, especially the 4C (beautiful warm-sunlight color) and no fried-egginess of the beam at all anymore.
• Fasttech deep-carry clip (advertised for the S2/S2+) which fits the Nitefox UT20 and similar lights as if it were specially made for them, even down to the color/matte of the finish.
pennzy
pennzy's picture
Do you have a link to the TIR you use in the S2+?
Lightbringer
Too many. I went to Amazon and just goggled “20mm collimating lens” (yeah, go figure) and got a bunch from LEDsupply.
Got some coming in from AX, some generic supplier for a 5pak of 10pak or whatever,
Best bet as to being choosy is from LEDsupply. I’ll go find the link…
Lightbringer
That was easy…
https://www.ledsupply.com/20mm-carclo-led-optics
If you want a 20pak or so, Amazon’s the place. Probably won’t have to wait 3mos to get it.
Lightbringer
Ugh, was phrased horribly.
I got a bunch from LEDsupply.
Before that, I went to Amazon and found some TIRs, but “TIR” was nowhere to be found in the description, only “collimating lens” in various combinations’n‘permutations. Narrow it down with “20mm” if you want to.
LEDsupply lets you order singly, etc., but Amazon usually has bulk paks of 20 or more.
pennzy
pennzy's picture
Thanks , will give it a try.
Slayer1
Slayer1's picture
Last seen: 1 day 14 hours ago
I got mine from here : http://www.leddna.com/reflector/
Lightbringer
Oh, LEDsupply also has 26mm TIRs in case you want to a D26/P60/P90, but you’ll need a spacer to make up for the TIR height vs reflector height.
Henk4U2
Henk4U2's picture
Last seen: 53 min 45 sec ago
Still not reflowing my own led’s, I always buy them on a pcb. Especially the alu ones tend to be a bit warped. Every new pcb+led that goes into one of my lights, gets a flattening trip on a lapping stone. But a sheet of fine sandpaper on a glass plate also will do the trick. It makes better contact (IMHO) and saves on thermal grease. You only need a hint instead of a blob.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
pennzy
pennzy's picture
Not sure of the correct size for S2+. Does the emitter type matter? I found these 45degree ones on Amazon. I am guessing 45 degree will give smooth beam?
https://www.amazon.com/10pcs-Transparent-Reflector-Collimator-Degree/dp/...
Also, at the Led site , I see various models that have the same specs. For instance , I see different numbers for 20mm wide angle ripple but no way of knowing what the difference is between them . Are holders needed for S2+?
Lightbringer
20mm is the “right” size, but they might be listed as 20.1mm or some rot like that. They fit.
The inside of the front bezel keeps the TIR more or less flat, and as long as the LED is centered in the hole, all should be okay. XM vs XP (5050 vs 3535) shouldn’t make much difference, especially with a wider-angle lens.
Ideally, TIRs should have the “shoe” that acts as a centering ring and spacer, lifting the lens just a smidge off the pcb, but it’s not critical. I wedged one in there, had a hard time doing so, but it worked. Also worked well without it, either.
Just get an assortment, play around with it, and you’ll likely find one that suits you.
60° is a nice flooder, especially for a headlamp, but also in a S2/S2+ that’s mainly to be used close-in and you’d want it to be nice and floody.
pennzy
pennzy's picture
Thumbs Up
contactcr
Last seen: 2 hours 25 min ago
Will a XHP50.2 fit under one of these? With boost drivers coming (eventually) this may be good way to clean up a 50.2 beam in a S2+ host
eas
eas's picture
Last seen: 1 year 3 months ago
XHP50.2 is basically the same form factor as XM-L/2, 5mmx5mm.
pennzy
pennzy's picture
All this talk of lens got me to thinking about DC Fix . I have been meaning to use it on a C8 to smooth out the beam. Finally got around to it . Looks much better on the wall . Won’t be able to test it outside tonight because we are in a frickin monsoon this week in NEPA.
contactcr
That is only the footprint though. Its a decent amount taller
pennzy
pennzy's picture
All this talk of lens got me to thinking about DC Fix . I have been meaning to use it on a C8 to smooth out the beam. Finally got around to it . Looks much better on the wall . Won’t be able to test it outside tonight because we are in a frickin monsoon this week in NEPA. Thanks Boaz for turning me on to it.
NeutralFan
NeutralFan's picture
Last seen: 13 hours 14 min ago
Nice tip Henk4U2! Where were you many, many mods ago? For a recent mod I was filing down the edge of a copper 3 LED MCPCB after I made it smaller and then ran the bottom of it over the file and was surprised the middle around the hole actually filed down more than the rest.
I’d rather use my flashlight around the house than turn on the lights.
NeutralFan
A no cost simple mod you can do if you have a beam with artifacts is to take your glass lens and sand down 1 of the sides with medium grit sandpaper. Not sure if it will work with an AR lens or a big lens. I did it with a Convoy S2+. Just press the lens down hard on the sandpaper and move it back and forth in 1 direction, rotate the lens, sand some more, and continue until the etching (i.e. scratches) is consistent across the lens.
If it doesn’t work the first time, you can start over again on the same side. It took me 4-5 attempts until it turned out to my satisfaction. And I was shocked as to how well it smoothed out the beam. The LED had a crack in the dome which caused a very annoying artifact. This mod smoothed everything out perfectly.
And as a bonus, the lens is still glass so it remains durable.
Boaz
Boaz's picture
 12 cents worth of dc fix will smooth out your beam  .
 *edit >  less than a nickle for an S2+
Boaz
Boaz's picture
Geuzzz wrote:
I like baking the ano of a flashlight. Should cost you less than 30ct of gas. !
 Baking a flashlight is a cool  .14 cent mod
  My newest crazy habit is to bake all of these cheap shiny silver clips that come on lights these days  till they turn beautifully bronze like your flashlight in the picture above. The bronze on black is a much nicer look and it happens in minutes .Either roast the clip over an open flame or just throw them up on the electric burner on high .About 50 seconds open flame and about three minutes on an electric burner ..super simple mod that produces nice results .
 final cost...03 cents
Boaz
Boaz's picture
  # -  Someone was talking about.... adding a magnet to the side of a clip using heat shrink.
  # - Used some clear nail polish on a few 18650's that got nicked ..nice 3 second 3 cent mod.
