What Battery brand and where from?
13 posts / 0 new
KevinLevrone
Last seen: 3 years 4 months ago
Looking at getting the Convoy L6, have never bought batteries before so wondering if there is particular brands or specs I should look for? Any websites that you could recommend (that also ship to Australia)
vit55
Last seen: 3 days 9 hours ago
Just buy Keeppower 26650 protected cells for convoy L6 by banggood like i’ve already done (69,5)mm length.
Lightbringer
Lightbringer's picture
Last seen: 5 hours 31 min ago
I got LK blue-wraps for my L2s, quite nice, but I think the newer LKs are black-wraps. Should still be excellent.
I only do unprotected anymore, fwiw.
emarkd
emarkd's picture
Last seen: 11 months 1 week ago
Seconding the Liitokala suggestion. Great cells. Their official store is on aliexpress so I know they’d ship to you.
Macka17
Last seen: 9 months 5 days ago
So far.
I’ve used mainly Laptop battery pack cells for most (LG and Samsung)
and so far. no problems Usually around 2200Mah capacity (C8/S2 torches, etc)
Good ones. I buy new Panasonic only. 90% of other good ones sold seem to be built with the Pana cells anyway.
And so far. No problems.
But I must admit I bought a pr of SOSHINE 26650’s 5500Mah. just to try out in my L6.
Again. No problems. So far.
Just remember to remove that smooth slip ring around base above rear cap if you install that anti-roll collar. Or you won’t get contact for battery.
As long as you buy other than the basic Chinese Battery’s. you should be right.
PS Bangood sent me email. They ship to AUST again now.
And I recommend spending the $10+ at same time and ship the Smooth reflector with torch.
It does improve it. Have fun.
KevinLevrone
Whats the thoughts on This Charger for only $11
Macka17
I got one. To replace a 2 x cell Li.Ion charger I bought without checking.
I have Ni-Cad too drrrr.
They Fine. As are their battery’s according to those in the know/tried them On here.
mortuus
mortuus's picture
Last seen: 1 day 12 hours ago
but they are flat top, wont work unless u add solder top, im using Efest in my l6 works great.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
KevinLevrone
Would these work in the L6? Keeppower 6000 mAh . There are also a few others from the seller that others in Australia have recommended Ebay supplier Im not sure what version is correct, it has Short flat tops, genuine etc
vidramon
This KP 6000 mAh from your’s first link can be connected in series, but I don’t know can they stand by the width in L6.
mmalive
Last seen: 2 years 8 months ago
KP 6000 mAh are both larger in diameter and longer. Use KP 5200
KevinLevrone
The short flat tops or the protected version? He has both on his ebay listings (I dont mind about price)
mortuus
mortuus's picture
no flat tops wont work, the KP 5200mah protected will work and is the recommended battery to use from the Convoy maker also.
https://www.ebay.com.au/itm/2-X-PROTECTED-26650-Keeppower-5200-mAh-rechargeable-Lithium-ion-batteries-PCM/272184229904?hash=item3f5f71c010:g:U2YAAOSwmtJXUCZd
looks like a legit seller .
              つ ◕_◕ ༽つ
