Possible fake Samsung 30Q 18650?
71 posts / 0 new
andygs
Last seen: 1 year 1 month ago
bcm00re wrote:
nick779 wrote:
The second character “0’ in the first line should be a dead giveaway that they are real.
Why? IMO that doesn’t prove anything because any forger could know what the datasheet says and thus make their imitations look real.
Have any of you seen any fakes that try to replicate the markings on the cell wall under the wrapper for a 30Q? Seems like more hassle for the fakers to go through. Thoughts?
nick779
nick779's picture
Last seen: 1 week 1 day ago
If they exist, they havent been identified. Usually the fake cells can barely get the font and printing correct on the wrapper, I doubt they could make a perfect counterfeit without throwing a bunch of resources at it.
BaronVonEissler
BaronVonEissler's picture
andygs wrote:
BaronVonEissler wrote:
There are photos on this forum of Two legs but I could not find them.
Hold on. Are all yours BT? They do not look that great, but what Two leafs are you talking about? I thought you were referencing that to the FT batteries?
I’m referring to the ones I just bought, you can see the photos in post #13 above
Yes, I saw them. I am not sure you can base a real or fake battery on its BT. Other factors like performance, labeling and info. under the label.
I see that you live in Australia. I can not recommend any credible dealers down under. There are many Aussies on here that could help you with that.I would recommend NOT to buy off of Ebay again.
By the looks of them, my guess is that they are fakes.
You can't hide me from me.
nick779
nick779's picture
The bottom line here is to remove the clear jacket/button top to check the legs on the top of the cell. 4 legs = fake. All the other markings look correct, the 141 is just a manufacturing batch number.
bcm00re
Last seen: 3 weeks 3 days ago
nick779 wrote:
True, but I trust Mooch’s experience and his recommended retailers substantially more than I do your opinion.
Fair enough — but I really wasn’t questioning Mooch’s recommendations of li-ion retailers.
andygs
Well, I was reluctant to do any surgery to the battery. However I did end up buying some more batteries from a reputable seller in Australia (www.techaroundyou.com) which has been recommended on this forum. They arrived and I ran a simple test on them to compare. The short version is that the ones I got from ebay seem legit.
I ordered 3 batteries from this techardoundyou store and I noticed two were batch 141 just like the ones I got from ebay, and one was batch 136. So a very slight difference. Examining them closely, I noticed the batch 141 batteries from ebay looked identical in every way to the batch 141 ones from techaroundyou. Even down to the little unusual looking “Q” character. The battery from batch 136 had a slightly different printing on it which was more consistent with images of batch 136 Q30 batteries I’ve seen online.
What I did was get two 10 watt 1 ohm resistors in parallel, thus producing ~ 0.5 Ohms of resistance. Then while measuring the voltage on the cell I briefly completed the circuit to get some current flowing, and then measured the voltage results. I also ran it through a crude amp meter I had to measure peak amps – not sure how accurate it is since the voltage it reported was vastly different to what my multimeter said. Anyway the results were very consistent across all the batteries:
Initial voltage: 4.18
Voltage under load: between 3.78 and 3.83
Resistance: 0.5 Ohms approx
Current Measured in my power meter: between 6.67 – 6.70 amps
Calculated internal resistance: 0.045 and 0.053
Just for fun I did the same test on some old trustfire and ultrafire batteries I had laying around. They immediately went down from about 4.1v to 2.4v or tripped the protection built in. Terrible.
Along with the Q30’s from techaroundyou, I also purchased some Sony VTC4 high current batteries. They performed basically identically to the Q30’s, presumably because I’m no where near pulling enough amps to make the Q30’s start stressing and sagging voltage too much.
So to my very basic judgement, they seem like legit cells assuming the techaroundyou cells are legit, since they seem to perform identically under about 7 amp loads.
Thoughts?
sac02
sac02's picture
Last seen: 7 months 4 weeks ago
That’s a good test and looks like you got genuine cells. Thumbs Up
andygs wrote:
… not sure how accurate it is since the voltage it reported was vastly different to what my multimeter said. …
That’s normal. The leads (even good ones) start to become a significant issue when measuring this kind of current with a multimeter, even if the advertised allowable current on the MM is “10A” (pretty common).
I have one MM (a cheap one but it works good enough for this purpose) that I have modded for this reason. I soldered short thick leads directly to the PCB and it is basically dedicated to reading tailcap current draws up to 10A or so, and does a pretty good job.
nick779
nick779's picture
I ended up stripping the top layer and welded button top off of ALL of my 30Qs from batches 136 and 141(multiple sellers for both batches)
All were 3 leg, all had proper lot codes except for my most recent liionwholesale batch, all measured similar IR on my MiBoxer C412. I dont have any special load testers, but they seem to be ok.
Regardless, im done with the 30q. Ill be doing VT6s with solder blobs the next time around.
brewster
Last seen: 2 weeks 2 days ago
Thoughts?
Do any of the ones you’ve acquired have the writing on the can under the wrap (especially the one with batch 136)?
I have a couple of 30Qs bought from ebay.au (not techaroundyou though) that seem mostly OK but I have had doubts. They have 3-prong top caps that look identical other Samsung flat tops, and the writing on the wrap shows no variation in typography of the kind that others have reported. They are marked batch 136 like other 30Qs. When new they tested slightly lower capacity than other 30Qs (maybe 7-8% down) but their internal resistance was very similar to other flat-top 30Qs. They seem to deliver good current in use, but that is a subjective assessment and not tested. My main concern has been the absence of writing on the can inside the wrap, like on other Samsungs.
Capacity and resistance testing done on an Opus BT-C3100. My capacity measurements are usually about 3% higher than HKJ’s at the same current draw (done at 1000mA). I have found that resistance measurement on the Opus is much more consistent and closer to those reported by HKJ if I maintain firm pressure on the slide against the back of the cell.
So my question is: is the absence of writing on the cans inside the wrap significant?
Barkuti
Barkuti's picture
Last seen: 7 hours 2 min ago
andygs, unwrapping at least one of your eBay bought 30Q button tops can shed some definitive light.
This is the sort of cell can markings Samsung 30Q 29E Innocent cells come printed with:
Sooner or later you should buy some heat shrinkable sleeves/wraps and learn to wrap batteries anyway, imho.
Tue, 05/19/2020 - 13:47
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
brewster
andygs wrote:
… I ordered 3 batteries from this techardoundyou store and I noticed two were batch 141 just like the ones I got from ebay, and one was batch 136. So a very slight difference. Examining them closely, I noticed the batch 141 batteries from ebay looked identical in every way to the batch 141 ones from techaroundyou. Even down to the little unusual looking “Q” character. The battery from batch 136 had a slightly different printing on it which was more consistent with images of batch 136 Q30 batteries I’ve seen online. … Thoughts?
Does the batch 136 cell you got from techaroundyou have the code printed on the metal can under the wrap?
vapcell Dennis
vapcell Dennis's picture
Last seen: 2 days 6 hours ago
Select reputable wholesalers to purchase
Then we also have Ali express store, selling genuine 30q batteries Big Smile
d_t_a
Last seen: 2 hours 55 min ago
From Barkuti’s pic: is this genuine Samsung 30Q?
markings:
E9GG
B4C31
the 2nd digit of the first line “9” from “E9GG” should be a “0” for Samsung 30Q, as per my understanding.
(eg. L0I7, L0J4, where the 2nd digit is “0” for 30Q)
brewster
d_t_a wrote:
From Barkuti’s pic: is this genuine Samsung 30Q? markings: E9GG B4C31 the 2nd digit of the first line “9” from “E9GG” should be a “0” for Samsung 30Q, as per my understanding. (eg. L0I7, L0J4, where the 2nd digit is “0” for 30Q)
The same question applies to the two other cells depicted by Barkuti. Neither of them has the two lines printed across the cell with “0” as the second character on the first line.
On the other hand, I have a bunch of Samsung 20Q cells from Aldi power tools. They have marking across the cell in two lines C0HV / N6D81. That is a zero for the second character on the first line. As 20Qs they have only 70% of the capacity expected of a 30Q.
vapcell Dennis
markings:
E9GG
B4C31
It is fake 30Q, this is samsung 29E, E9GG,July 2016
Barkuti
Barkuti's picture
brewster wrote:
The same question applies to the two other cells depicted by Barkuti. Neither of them has the two lines printed across the cell with "0" as the second character on the first line.
These are multiple shots of the same cell.
vapcell Dennis wrote:
Good catch and good to know, along with another one I received it in some old early AE order Facepalm long ago but didn't actually internal resistance tested them; I just presumed what they were with the limited information I had.
I have a 30Q from NKON which I'll shoot and rewrap for a better picture.
Henk4U2
Henk4U2's picture
Last seen: 1 hour 27 min ago
A quick look learned that all (28) my 30Q cell’s are marked 136. Bought them from BG and NKON.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Barkuti
Barkuti's picture
Pictures of an actual 30Q (first picture is before rewrapping):
So well, that actually is my only 30Q right now. Time to blow the dust off some VTC5As…
nick779
nick779's picture
Just for the record, Liionwholesale claims that some recent batches of the 30Q might have weird can markings due to temporary production facility changes. I have a few marked making me think they were 29E’s as well but they have similar IR and capacity to my known legit 30Qs with good can markings.
Funtastic
Funtastic's picture
Last seen: 11 hours 10 min ago
Sooooo I just realized my two latest batches from Lucky’s Electronics Store on AliExpress sent me 30Qs with the top line of code “L30Q” . This has been my trusted supplier for the last 4 years and is listed on BLF as a trusted source.
I’m just charging a couple up to do a discharge test on my CBA.
I had 100pcs with an added button top arrive genuine but looks like my flat top are fakes.
Genuine always test at 3.40v and these read 3.44v.
EDIT: Well, they’re genuine. Tested at 15A and got 2968mAh and it almost perfectly matches the curve of Mooch’s test back in 2018
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
d_t_a
Just starting fairly recently, I’ve started to record measurements of batteries (from shipped condition: voltage & IR as tested with YR1030 resistance tester, and weight; I haven’t started doing measuring dimensions though).
So far the genuine 30Qs I get arrive usually from around 3.36v-3.45v. and there seem to be 2 sets of IR readings, I think both are genuine.
1 set of 30Qs (“141”) have YR1030 IR reading of around 11.8-12.0mOhms, while the others (“136” and “138”) usually around 12.6-12.8mOhms.
Funtastic
Funtastic's picture
I have the same resistance tester as you and two cells with L30Q read 12.06 & 12.11. It’s very interesting that these are genuine when Mooch said if it hasn’t got “0” as the 2nd digit it’s fake
nick779
nick779's picture
My weird marking 30Qs have that same “L30Q” code too.
Funtastic
Funtastic's picture
I messaged Mooch and he said it could be new codes that Samsung is starting to use. The 40T is no longer a 0 for the 2nd digit. It’s now N40T
Mooch is going to try find a L30Q and test it.
Goatlvl
I might be too late … but, how about “R30Q” code?
One online shop in my country has a good deal of 30Q (around $4.5 per piece). But the close-up picture shows a faint code R30Q/JCKA6 (I think). It is neither “0” at the 2nd position nor “L30Q”. In addition, some VTC6 pics in this shop show LiitoKala sticker on the cell (I heard a lot of fakes in Liito store).
I’m not sure whether to buy from this shop or not. I also don’t have tools for testing, so buying and testing it is not possible now.
Additional reference, this is the picture of markings on pink wrap.
Funtastic
Funtastic's picture
R30Q is genuine, all mine come from a trusted source and I’ve tested them as authentic. This code alone doesn’t make them genuine though.
The warning note is on all new batches now
Funtastic
Funtastic's picture
$4.50 a pc sounds pretty cheap though but if he’s buying in massive bulk then they’d get a better discount than me. My cost price is $4.40 usd excl shipping.
I’d be cautious on the pricing
Barkuti
Barkuti's picture
Goatlvl, the top or positive pole of cells is a distinctive trait. Battery brands carefully choose the geometry and shape of the top pole for their cells. Its like an emblem, unique. Different brands never (!) use the same top / positive pole. This is the shape of the Samsung one:
Pictures from: 18650 30Q review, 21700 50G review.
There are a couple chinese OEM manufacturers which use a (pretty) close in shape positive pole to Samsung's: FST or Far East Battery and Heter.
The FST top pole looks like:
Picture from: test of FST 21700 4500mAh (Pink).
This one is fairly close. Still, Samsung's legs are proportionally wider.
Concerning Heter, I once bought a bunch of cells from AliExpress which turned out (not bad, but) fake. The following picture says it all:
This one is easy to distinguish.
peg matite
peg matite's picture
Last seen: 51 min 31 sec ago
Goatlvl I say guess is fake. The 3s on pink wrapping don’t look right.
Funtastic
Funtastic's picture
I have an order of 100pcs confirmed genuine with 3s like that
