Lumintop GT Mini (Thower) Beam shots and more!
151 posts / 0 new
ZozzV6
ZozzV6's picture
luca955i wrote:
Hello everyone, I noticed around the spill, a very well defined ring, which I have never seen in any other torch in my possession. According to you it is normal, or maybe the LED is mounted too far / high. Mine is NW
Thanks to everyone in advance
Mine is the same. I thought it is a normal thing and with XP-L HI it doesn’t matter much. But when I putted in a much smaller led (Osram oslon black flat) I noticed that the reflector inner 3cm diameter is not perfectly focused bot the outer 1-1,5cm ring is good. So you can’t perfectly focus the reflector with shimming because the focal length is not equal on the center and on the edge.
I got 160 kcd only and this ugly hollow beam at 1-2m distance:
at 10 cm:
But I had an Emisar D1S and replaced the reflector with that and after only that change I got 214 kcd and the beam was like this:
So the D1S reflector is more consistent in focus than GT mini.
luca955i
luca955i's picture
Thx !
MACS0647
MACS0647's picture
Last seen: 3 weeks 1 day ago
For those who might be interested,
here’s to find a little beam-shot comparison of my GT Mini nw., Cometa 2016 , Xin TD XP-G2 ded., and three more….
Beam-shots GT Mini nw., Cometa 2016
MACS
LichtAn
Last seen: 1 year 3 months ago
@ZozzV6
At what distance did you measure Lux? With these superfocused LEDs I think it’s quite normal to have a hollow beam at short distance, isn’t it? At least my TN42, MF02 also look like this close up to the wall.
Also how much current for 160k cd? At just 3A I get 196k cd measured at 14 meters in the Mini GT with the Oslon successor. But I also get the bright corona around the hotspot.
Fun fact: The XP-L HI from my GT Mini is the first LED I threw right in the garbage after taking it off the MCPCB, because the tint is really THAT BAD. Crazy
P.S.: I also have to order a D1S now to mod it. Thanks! Facepalm Big Smile
ZozzV6
ZozzV6's picture
I measured from 5 to 25m at every 5m. And this was the best result.
luminarium iaculator
luminarium iaculator's picture
Last seen: 3 hours 9 min ago
I found that sometimes you gotta to toss centering rings and drill through reflector to perfectly center small led but no one do that Smile
LichtAn
I tried without centering ring, but the reflector sits on the rim of the flashlight head. And focus got a lot worse. The stock centering ring seems to be about 95% correct in terms of height.
I don’t have that GT mini… So it does not go any deeper since rim sits on flashlight head? If so is there any way to raise the pill up toward reflector bottom lets say by unscrewing it slightly? And of course double layer of kapton tape on reflector bottom or contacts everything goes to oblivion… Than base your build around that centering ring (raise it by adding kapton tape or something if necessary).
I usually start centering with reflector bottom strictly on mcpcb and then I decide what I’ll do next… But we all have our own mothods and there is more than one way to skin a deer.
Look what I mean when I say drill through reflector with not so accurate accu drill lol :
ZozzV6
ZozzV6's picture
No. This flashlight doesn’t have a screw pill. It has an integrated shelf.
LichtAn
Alright so I put the fully charged cell in it and NOW it has a black spot in the center of the beam. Facepalm
Well it’s weekend and I got time… How to remove the driver? Is it just glued like the Emisars?
HONDARIDER
HONDARIDER's picture
Last seen: 5 months 5 days ago
I am so impressed with these that I have 4 NW and 2 CW versions. Of course I purchased them when they were $32 each. I do have more C8’s but this little light is awesome for an XP-L Hi.
mortuus
mortuus's picture
Last seen: 5 hours 38 min ago
lol 6 lights? what do u need so many for hehe?
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
HONDARIDER
Since this group is my support group, I have to admit……….I may have a problem.
wstrachan
Last seen: 2 weeks 2 days ago
Is anyone having switch problems with their light? Mine came out of the box malfunctioning. The light won’t turn off. I have to remove the tailcap.
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
Texas_Ace
Texas_Ace's picture
Last seen: 4 hours 50 min ago
This sounds like a short to the ground wire of the LED. Very possible.
mortuus
mortuus's picture
yes sadly a few so far had problems around 10-12 so far reported in the other gt thread, myself i got a new head from neal and a few others also that bought during group buy so its nice to see that they atleast sent out replacements. You should ask also for new replacement head, have zero issues now with the new so hopefully it will stay that way.
              つ ◕_◕ ༽つ
mortuus
mortuus's picture
Switch problems i guess ? U bought from Neal or banggood ?
              つ ◕_◕ ༽つ
bts
My GT Mini button feels spongy, is this normal?
Better to hv it and not need it than to need it and not hv it.
mortuus
mortuus's picture
yes the early batch of the gt mini feels more spongy, the newer replacement head it feels a bit less..
              つ ◕_◕ ༽つ
Kazik
Last seen: 1 month 1 hour ago
I got the GT mini today. Overall it’s a really great flashlight, but in my sample mode programming sucks. I’ve managed to set “UI – mode sets” and then I tried to program mode set. Here’s what happens:
1 click (in programming mode) – 1 mode (moonlight excluded)
2 clicks – 2 modes
…. same pattern – number of x clicks gets me x modes…
7 clicks – 7 modes
8 clicks – 8 modes (first WTF?)
9 cliks – 4 modes
10 clicks – 5 modes
11 clicks – 6 modes
12 clicks – 8 modes
That’s neither NarsilM v1.2 mode sets, nor those in manual I got with the flashlight. Anyone had same situation?
JasonWW
JasonWW's picture
Last seen: 2 days 23 hours ago
2 clicks – 2 modes
7 clicks – 7 modes
9 cliks – 4 modes
10 clicks – 5 modes
11 clicks – 6 modes
12 clicks – 8 modes
Everything looks correct. IIRC the manual that came with the light is an old version based on a different light. Look in post 1 here for the correct manual.
http://budgetlightforum.com/node/60983
Kazik
Ok, problem solved – thanks JasonWW! Smile
Are all those “100%” modes driven DD with FET?
Texas_Ace
Texas_Ace's picture
2 clicks – 2 modes
7 clicks – 7 modes
9 cliks – 4 modes
10 clicks – 5 modes
11 clicks – 6 modes
12 clicks – 8 modes
Good point, I forgot about that.
Texas_Ace
Texas_Ace's picture
Yes, turbo / 100% are the same thing.
Kazik
OK, thanks! Smile
chadvone
chadvone's picture
Last seen: 11 hours 30 min ago
Does anyone know what LED they are using in the NW version??
I just jumped on this light without doing much research, thinking I would have to swap out the LED anyway.
After having it out a while tonight, I love it. I want to order some more LED’s of this tint.
Pierced the woods almost as well as my NW modded M2X Javalot even though it didn’t have the lux.
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 21 min ago
4000k XPL-HI in the 5A/5D chromacity bin, so under the BBL.
chadvone
chadvone's picture
Thank you, Its performed well in the timber.
komeko
komeko's picture
Last seen: 3 months 4 days ago
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
mortuus
mortuus's picture
wow that is very good specs for a 4000k emitter. almost 1400 lumens is accurate also ?
              つ ◕_◕ ༽つ
