Test/review of Hoco 2x18W PD car Z20A
1 post / 0 new
HKJ
HKJ's picture
Last seen: 1 day 17 hours ago
Hoco 2×18W PD car Z20A
DSC_9379
Official specifications:
  • Input: DC12-24V
  • Output: Type-C: DC5V / 3.0A (PD), DC9V / 2.0A (PD), DC12.0V / 1.5A (PD), 18W;
  • USB Output: QC3.0 (3.6-6.5V / 2.4A 6.5-9V / 2A 9-12V / 1.5A)
  • Flame retardant PC material + zinc alloy shell, durable
  • 18W PD output + QC3.0 dual output total power 36W, fully meet The charging needs
  • Multiple circuit protection, compatible with PD input mobile phone/ tablet / PD input some of notebooks and QC3.0 / QC2.0 digital Devices
I got it from Aliexpress dealer: BYKRSEN Store
DSC_9356 DSC_9359 DSC_9357 DSC_9358
The box only contained the charger, no instruction sheet or usb cable.
DSC_9381 DSC_9382
There is a ring around the connectors, it has a weak blue light behind it.
DSC_9383 DSC_9384
DSC_9385 DSC_9386
Measurements
  • PD codes: 5V 2.39A, 9V 2.15A, 12V 1.51A     5V is marked as 3A on the charger
  • PD outputs starts enabled.
  • PD output is auto code with DCP, Apple 2.4A, Samsung, QC3, Samsung-AFC, Huawei-FCP, Huawei-SCP
  • QC output is auto detect with DCP, Apple 2.4, QC3, PE2.0, Huwai-FCP, Huwai-SCP, Samsung-AFC
  • Minimum QC3 voltage is 5.0V     QC3 is supposed to be lower than that
  • Power consumption is 7mA from 12V and 5mA from 24V
The charger has many different output voltages and with input support up to 24V this makes for many combinations, I have tested many of them, but will not show all here.
No%20load%20voltage%20sweep
Power consumption when noting is connected to output depends on input voltage.
QC output
Load%20sweep%2011.6VQC5V
5V output with low input voltage, this looks good up to about 3.6A
Load%20sweep%2011.6VQC9V
9V output, again with low input voltage, the output can deliver about 1.7A, rating is 2A or 1.5A (It has both ratings)
Load%20sweep%2011.6VQC12V
12V output with low input voltage is a bit problematic (This is the same on just about any car charger), it gets nearly up to 1.7A before it drops, this is fine for a 1.5A rated output.
Load%20sweep%2014.6VQC12V
12V output with high input voltage can deliver exactly 1.7A with stable output voltage.
Voltage%20sweep%202AQC5V%20input%20current
In this curve I sweep voltage from 24V and down with a output load of 2A.
The 5V output is stable down to about 6V input.
Voltage%20sweep%201.5AQC9V
9V output can be maintained down to about 10V input with a 1.5A load
Voltage%20sweep%201.0AQC12V
12V output works down to about 13V with 1A load, I could not get it started at 24V input with 1.5A load.
10ohmQC5V
At 5V 0.5A the noise is 8mV rms and 117mVpp
5ohmQC5V
At 5V 1A the noise is 13mV rms and 118mVpp
2ohmQC5V
At 5V 2.5A the noise is 12mV rms and 136mVpp.
10ohmQC9V
At 9V 0.9A the noise is 13mV rms and 111mVpp
10ohmQC12V
At 12V 1.2A the noise is 17mV rms and 230mVpp, generally very low noise.
PD output
Load%20sweep%2014.6VPD5V
USB-C PD with 5V output and high input voltage can deliver about 3.5A
Load%20sweep%2014.6VPD9V
At 9V the output is limited to a bit above 2.6A
12V can deliver 1.7A
Load%20sweep%2011.6VPD12V
12V output with low input voltage, the output voltage sags at higher current, but handles the rated 1.5A fairly well (About 10.5V).
Voltage%20sweep%202APD5V%20input%20current
5V with 2A load works down to about 6V.
Voltage%20sweep%202APD9V
9V output works down to about 10V with 2A output.
Voltage%20sweep%201.5APD12V
12V works down to about 13V, but do not maintain 12V output with 24V input.
10ohmPD5V
At 5V 0.5A the noise is 7mV rms and 191mVpp
5ohmPD5V
At 5V 1A the noise is 10mV rms and 205mVpp
2ohmPD5V
At 5V 2.5A the noise is 7mV rms and 143mVpp
10ohmPD9V
At 9V 0.9A the noise is 11mV rms and 207mVpp
10ohmPD12V
At 12V 1.2A the noise is 12mV rms and 214mVpp, PD do also have very low noise.
Full load
Load%20test%203.0A
Loading both outputs with rated load did not work for long, the PD output reduced the output voltage, probably due to heat.
Load%20test%202.4A
Reducing the PD load to 2.4A fixed that, here I could run for 1 hour.
The temperature photo below are taken between 30 minutes and 60 minutes into the one hour test.
Temp5525
M1: 65.8°C, HS1: 75.6°C
Temp5526
M1: 61.7°C, HS1: 77.4°C
The charger gets rather warm, performance will depend on how well the socket can cool it.
Tear down
DSC_9486
Both the enclosure and the front is in metal.
DSC_9487
The front has the two usb connectors and a LED
DSC_9488
DSC_9490
The sides is for 0V power connection.
DSC_9492
The bottom is for 12V power connection.
DSC_9489
On the side with the USB-C connector is the PD circuit.
DSC_9491
And on the side with the normal USB connector is the QC circuit.
DSC_9493
Getting inside the electronic circuit required a bit of violence, the circuit boards are both soldered and (weakly) glued together.
DSC_9495 DSC_9496
The QC output is one chip, one inductor and a large capacitor. There is also a few supporting capacitors and resistors.
At the current input is a fuse and a smd ferrite working as an inductor, they got damaged when I took it apart.
DSC_9497
DSC_9498 DSC_9499
Again it is a very simple circuit and very similar to the QC circuit, but this time for PD (U2: IP6510).
DSC_9500
DSC_9501
Being a 12V device there is no need to test with high voltages.
Conclusion
This car charger works fine on both PD and QC output, as expected for a charger without boost converter the 12V mode voltage will depend on the input voltage, this charger has a fairly low voltage drop. The QC output has automatic coding with a lot of modes, making the charger work with many different phones. The noise is low. The charger has some problems with 24V.
I will call it a fairly good charger.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
