It stand firmly, I do not have loupe but as far as I can see with my eyes all is on its place, there is a lot of small components so I can’t be 100% sure without enlargement.
I will check tommorow, go to sleep now, thanks.
Thanks, it looks like it is ! :+1:
No it is not burned or damaged, probably I cut it a little somewhere when removing a driver from shell.
I check with DMM and there is connection on both wires from top to the bottom.
Got it, replaced but I have only one 100% mode :person_facepalming: On pic it say 1, 10, 50, 100 % and strobo…
Don’t know what is happening, first review comment says : ‘’wrong wire females припаяли seller look at the picture shown as there is correct, they дибилы припаяли blankly дросселю to and збсь so all!!!’’
Don’t understand what he saying something about wrong + and - but as I see all is like it should be :cry:
Check for shorts between the emitter/driver negative and the body/reflector. This will effectively bypass the driver and give direct drive whenever the tails switch is on.
Yep thanks I found a problem, open again and somehow when I put all together and screw up an retaining ring from negative wire is taken off some isolation so wire was naked and somehow touching something which causes a problem…
Also I get one new inductor, will try to replace on faulty driver to see can it been fixed.
I do not think the induktor itself is damaged. But because it is heavy it could have broken loose. try to resolder the leads of the induktor and check if the problem is gone.
