Amazon Basics AA rechargeable. Eneloop 2018 help picking
36 posts / 0 new
Mikeadoo
Last seen: 11 months 23 hours ago
Hi all I’ve been looking for more decent NiMH cells but can’t afford the price of the Eneloops. I’ve read a lot on YouTube and Google people saying the Amazon basics are Eneloop rewraps or close to it for much cheaper. I need a lot of cells for a party and would rather buy rechargeables so I can use them again instead of just trashing them.
Amazon Questions and answers were saying that Amazon changed the color of the wrapper and I don’t know which ones are “made in Japan” and NOT the made in China ones.
Could someone help me out please?
Would greatly appreciate it!
Mike
toddcshoe
toddcshoe's picture
Last seen: 1 day 9 hours ago
"Everywhere I go, there I am"
chops728
Last seen: 4 hours 13 min ago
I purchased these in AA and AAA —- They seem to work fine—the ones I tested on my Opus charger showed above rated capacity— Output in lights is really close to Eneloops—as far as cycles only time will tell —I have some Eneloops 5 + yrs old that still reach rated capacity
https://www.amazon.com/gp/product/B00CWNMV4G/ref=oh_aui_detailpage_o03_s...
Mikeadoo
Thanks guys. I’m guessing the black ones are like the Eneloop pro and the grey are like the white Eneloop?
Mike
Mikeadoo
I have 2 lights I will be using that are powered by 6 AAs. A 700 claimed lumen Husky flashlight and another Coleman Illumilast 750 lumen. Q8 for me but the kiddos want some “powerful fun” lights too
Can’t find anything on the Illumilast. It’s just a light from Meijer. My EBL cells are too fat for it. It’s a tough fit
Mike
ggf31416
Last seen: 1 day 20 hours ago
This thread should be of your interest http://budgetlightforum.com/node/60169
Also there are two forum categories for 1xAA and multiple AAs lights.
Pete7874
Pete7874's picture
Last seen: 12 hours 29 min ago
The other way around.
Mikeadoo
Thanks Pete!! Do you know if they are reliable? I read lots of reviews on Amazon and lots of people were saying great and lots were saying fat/don’t fit. So I’m wanting the black cells for more cycles.
Mike
Pete7874
Pete7874's picture
In my experience, the newer “Made in Japan” ones are great. I’ve been using them for a while and I keep buying more from time to time.
To put things in perspective, even the grey ones are rated for something like 500 cycles. If you recharge them once per week, on average, they will last you almost 10 years. Now, if you’re going to be recharging them every single day, then by all means, go for the black ones.
Mikeadoo
Never thought about it that way Pete. Thanks again for clearing that up for me. Looks like I’m going with them grey ones. Save me some money compared to them Eneloops. Slow charge them with my Maha Powerex charger? Or use the Panasonic BQCC55 (got the BQCC17 also). C4-12.
Mike
Mikeadoo
Oh I also have the Liitokala Engineer Lii-500 charger.
Mike
Pete7874
Pete7874's picture
Shouldn’t matter which one of these chargers you use.
Any charge rate up to about 0.5C should be safe and not stress the cells at all.
Mikeadoo
Ok definitely soft or slow whatever for the Maha. Rapid charge finishes AAs crazy quick. Thanks. Should I do the whole break in thing first when I get them? Does it really matter. Break in with charger or just from normal use. Kinda same ish I’m thinking.
Mike
Pete7874
Pete7874's picture
I would just start using them.
chops728
I usually run one test cycle on them—If you’re using them in pairs etc—you can kind of half match the sets—also if they don’t test out close Amazon will make it right
Mikeadoo
I’m going to mostly be using them in my 4 and 6 cell powered lights. So I’m going to have to buy 16. Maha powerex has a “condition” mode on it. Is that the same as test cycle?
Charge, discharge then charge again. Or on the Engineer it has that Nor test mode and shows all the mAh voltage and stuff. Maha just blinks. Bought Maha mainly for my C and D batteries
Mike
flyboy
Last seen: 4 months 1 week ago
Huh? Apologies if I ruffled feathers. Not worth the contention.
It Is A Fine and Pleasant Madness
Mikeadoo
I may have overreacted. Sorry Flyboy. Having a really rough week. I am using the AA to D adaptors I already have in them cheap Eveready flashlights. That way I will have more AA cells. My EBL cells are really old and don’t hold much charge anymore. I use rechargeables in everything. My TV remote don’t work with the EBL except a few of them.
So I guess I really didn’t need to include the party thing. I just don’t want the price of Eneloop if the Amazon are similar for less $.
Mike
chops728
My powerex charger has a refresh/analyze mode—you can set the charge discharge rates—-with the rest periods in between cycles it takes forever—- I usually charge up the cells on other chargers to speed it up a bit—- the opus and litokala are lots faster
Mikeadoo
Do you have the MH-C808M? I can’t adjust anything on mine other than doing a soft charge or condition mode.
I have the Engineer Lii-500. Is that the one you use?
Mike
chops728
Powerex MH—C9000 and the Lii 500 —- do the noir test on the 500 —you can set the charge rate —it has preset discharge rates 500ma and below uses a 250ma discharge —- 700ma and above uses a 500ma discharge —I use the higher ma on AA cells
Mikeadoo
Do you think 1000mah is Overkill on AAs? I got my EBL C doing noir test now just out of curiosity 1000
Mike
chops728
I use to do 700 ma but I read some post I think from HJK that said if too low a charge current is used it affects the cut off —I don’t know for sure—in most all my cells Ni-Mh Lithium etc —I usually stay some where around half the capacity for my charge rate
Mikeadoo
So if I’m understanding this right, for a 5,000 mAh C I would use 250? If that’s even possible on the engineer li500
Mike
Mikeadoo
Alright so I officially confused myself lol.
So my 26650 Keeppower 5200 mAh on the Lii500 what would be half capacity?
Mike
Pete7874
Pete7874's picture
You would use 2500 mA, but Lii500 only goes up to 1000.
Pete7874
Pete7874's picture
Half of 5200 is 2600.
Mikeadoo
Yes I know what half is Pete. But my charger only has 300 500 700 and 1000.
I know. This is one stupid guy.
Mike
Pete7874
Pete7874's picture
Any cell that’s 2,000 mAh or larger, just use 1000 mA charge rate on the Lii-500.
Mikeadoo
How about the nor test thing? Same 1000
Mike
Pete7874
Pete7874's picture
Yes, same thing.
