Efest IMR20700 3100mAh (Purple) 2018
Official specifications:
Rated capacity: 3100mAh
Nominal voltage: 3.7V
Voltage at end of discharging: 2.5V
Maximum charging current: 4A
Standard charging current: 2A
Maximum discharge current: 30A
Charging temperature range: 0°C ~ 45°C
Discharging temperature range: –20°C ~ 75°C
Inner resistance: 20mOhm
The batteries are not perfectly matches, but fairly close. They can handle 20A with problems, but at 30A they get too hot.
I forgot to mount the temperature sensor on one of the batteries.
Conclusion
This is a nice high current battery and the slightly large size compare to a 18650 can be seen on the improved performance.
This battery is mostly for people that needs well above 10A, for lower currents look at a 18650.
Notes and links
The batteries was supplied by Efest for review.
Compare to 18650 and other batteries
