Astrolux MF02S NW review (XHP70.2, 4x18650)
41 posts / 0 new
LichtAn
Last seen: 3 months 4 weeks ago
SKV89 wrote:
Those lumen numbers are pretty insane for a single XHP70.2.
I’m surprised Astrolux/Bangood still use glue on their flashlights after so much protest from BLF.
The MF04 I recieved could be unscrewed by hand with very little force. So that they glued again now is really strange.
wstrachan
I don’t have a means to check output. I have the CW version received last week and I believe it to be every bit of 6,000 lumen plus. It blows away the Haikelite MT07S. Overall very satisfied with the light. I don’t know why light MFRs can’t get their numbers right except the obvious embellishment to sell as you said EasyB. In this case maybe they tested a prototype version or a different tint…
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
lexvegas
Last seen: 1 year 1 month ago
http://www.abov.co.kr/en/index.php?Depth1=3&Depth2=1&Depth3=1&Depth4=1&I...
Here’s the mfg page for the MCU. They seem to have something called “VPE” that does code generation for setting ports and such, and does seem to have some definitions of ports so it wouldn’t be all bit-shifty mess. I was able to get it running with Wine on Ubuntu. When I’m home I’ll look at spinning up a windows VM and playing a bit more. Need to get the desk cleared off first, though, as I’ll need to get a flashing setup working.
Mark M
Mark M's picture
Last seen: 4 hours 11 min ago
I just received the Mateminco MT-70 version of this light, and I just wanted to report that mine came without glue on the bezel. maukka does your bezel/glass make a clicking sound on your model like it did with the MF02?
minim
Last seen: 5 days 10 hours ago
Anyone de domed this and did comparison shots?
Maxabeam - Astrolux MF02S + MF04 - Emisar D4s - Emisar D4 - Convoy S2
klrman
klrman's picture
Last seen: 1 day 20 min ago
Mine makes the clicking sound too and I have it running on  high at the moment.  What is that clicking sound?
Update:
With battery cage removed, the clicking sound is still there.  Stays around for about 20 minutes or so.  Could be just be expansion/contraction of metal unless a little bit of power stays for awhile in the driver and something is wrong there.  My guess is it's the metal making funny noises from the heat.
NWoodsman
NWoodsman's picture
Can you suggest where to buy a threaded lanyard part like the one included with this light?
d_t_a
Last seen: 3 hours 47 min ago
I’m just curious, the Sofirn SP70 also uses an XHP70.2 and has a relatively big head/reflector, but uses 2× 26650.
Whereas the MF02S uses XHP70.2, also has a relatively big head, and uses 4× 18650.
Maybe someone has a side-by-side picture of the head size of the Astrolux MF02S vs Sofirn SP70?
I have the SP70, but don’t have an MF02/MF02S – is the head/reflector of the MF02/S bigger than the SP70 so that the specs of the MF02S indicates “1000 meters” throw and “8000” lumens max (measurement above for MF02S is 7570 lumens at 0-seconds, and 860 meters of throw).
The SP70 manufacturer rating is only 5500 lumens (I think some people measured higher than that), although I’m not sure about the actual measured beam distance/throw figures (SP70 manufacturer rating is 700 or 715 meters, IIRC).
klrman
klrman's picture
SP70 head diameter is 90mm
MF02S is 84mm and I just measured the actual reflector diameter and it is 71mm
d_t_a
Thanks for the measurements!
So, that means that theoretically, the SP70 should be able to throw as far or more than the MF02S, if pushed with even higher current (SP70 ‘BLF edition’) ?
(since SP70 lists “5500” lumens and MF02S lists “8000” lumens)
