Feeler thread / sneak preview: Wuben TO50R HC ("The Flashlight")
199 posts / 0 new
Archangel72
Interested
SKV89
Last seen: 1 hour 20 min ago
Thanks Maukka. Have you measured the lumens too?
I bought three TO40R and one TO10R and I like the light but my biggest complaint is how frustratingly difficult it is to locate the buttons in the dark. They really need to do something about it. At least make the buttons another color instead of black.
maukka
maukka's picture
Last seen: 4 hours 9 min ago
Lumens are on my previous post.
Happy to report there’s no visible flicker on any mode. Well, I was barely able to make it out on moon with rapid eye movements while bouncing the light off some reflector where it created a very small specular highlight. But couldn’t see it under any normal circumstance. Other modes, no chance.
SKV89
Oh those lumen numbers were so perfectly rounded I those were manufacturer’s specs. The jump from 250 lumens to 1200 lumens is too much. I wish they have a max sustainable lumen mode, probably 700-800 lumens, to make the light more practical
maukka
maukka's picture
The switches are backlit, but they’re only lit when low on battery or charging.
I like how the light doesn’t even allow high modes when the battery is low. It just cycles the lower modes as if the higher ones don’t exist. Until only moon works. Makes it easy to notice when you’re running out of juice.
SKV89
Those are very thoughtful features but regarding the difficulty locating the buttons in the dark, they should make at least one of the buttons white and have it illuminated constantly when off. For those concerned about battery drain, they can just unscrew the tail cap slightly to lock it out.
MascaratumB
MascaratumB's picture
Last seen: 7 hours 42 min ago
On the new Wuben E05 that I recently reviewed, they’ve come with a more or less nice situation, making the pocket stick on the opposite side of the switch (on the head). It is not a perfect solution but it helps to locate it everytime you pick the flashlight!
BTW, thanks maukka for the tests and information! Thumbs Up
_the_
_the_'s picture
Last seen: 2 weeks 2 hours ago
That’s what I typically do with side switch lights: Turn the clip to the opposite side of the switch and you’ll easily know where the switch is.
=the=
maukka
maukka's picture
The TO50R has a super efficient design. In the 250 lumen mode it clocks in at over 10 hours with an average system efficacy of ~125lm/W. This is the highest of any CRI90+ light I’ve tested. Regulated for the first 8 hours and slowly declining after that until stepping down to 50lm for the remaining runtime.
oceanfreak
Can you confirm if this light flashes S-O-S correctly? I am rubbed the wrong way on Wuben with their A21 flashing S-O-O instead of S-O-S. Seemed like a great gift light for my father but now it’s just an embarrassment. Great feel, but really… Probably never buy another Wuben.
_the_
_the_'s picture
I can confirm the SOS is correct.
=the=
McLight
McLight's picture
Last seen: 7 months 2 weeks ago
Location: German rain does not fall, our rain occupying the area.
the wrote:
McLight wrote:
Interested, will be only black available, or colored versions too???
Black is the new black. No other colors planned.
Thank you the,
i can deal with it, if its in CW available.. Cool
In GoD & Trance we trust, the rest pay Cash!!
_the_
_the_'s picture
McLight wrote:
Thank you the,
You must be pulling my leg.. Cool
This light will be NW, 5000K, 90+CRI. No other versions planned.
=the=
SKV89
Maukka, is there any temperature regulation or preset stepdown timers on the higher modes? I really hope they don’t have any step down timers.
Kurt_Norway
Kurt_Norway's picture
Last seen: 1 month 1 week ago
Interested Big Smile
maukka
maukka's picture
It’s temperature regulated. It isn’t as sophisticated as a really well optimized PID, but it stays brighter longer when you keep it cool. Even bounces back after stepdown if you manage to bring the temperature down enough. At some situations this may result in slow oscillations as the light climbs back to full output and steps back down after heating up again.
Without cooling on turbo and high my sample steps down to about 820 lumens and stays there in room temperature (23c) without additional cooling. Surface temperature is about 50 degrees. Most lights this size can’t retain 800 lumens without cooling or burning your skin.
SKV89
Thanks for the graph! I think if the light was set at 1,200 lumen mode, the oscillation would be farther apart and less pronounced. Maintaining true 800 lumens is really good for this size light. But it is 21700 host so should have more mass. Someone should suggest to Wuben to add a sustainable 800 lumen mode.
McLight
McLight's picture
the wrote:
McLight wrote:
Thank you the,
Na, i never make neighbours angry.. Big Smile
Surly not my favorite color but still a must have.. Innocent
x-ray
Last seen: 3 weeks 4 days ago
This looks really nice!
Any rough estimates on price?
maukka
maukka's picture
The magnet in the tail is super strong (and useful). Although at times, it sticks to nearby stuff a bit too eagerly…
TexasToasted
TexasToasted's picture
Last seen: 22 hours 35 min ago
Just the way I like it!
MascaratumB
I wish this is not a super expensive flashlight, ‘cause the shape it is showing is the flashlight Love
SKV89
Maukka do you have the weight without battery? I just want to see how it compares with the TO46R. The thermal performance of the TO46R is pretty good already but I hope this added a good amount more mass since the output is so much higher.
maukka
maukka's picture
126 grams with the clip but without a battery.
SKV89
Oh that’s not so heavy. With a little more mass, it should be able to sustain the 1200lm mode.
P33
Last seen: 2 weeks 1 day ago
Is it going to be micro USB or USB C?
Dioda
Last seen: 12 hours 48 min ago
Interested
g_damian
g_damian's picture
Last seen: 2 hours 28 min ago
Interested
Di_Joker
Di_Joker's picture
Last seen: 1 hour 4 min ago
Interested.
Sorry for my poor english.
d_t_a
Last seen: 6 hours 23 min ago
Interested!
(I don’t have a flashlight that uses LH351D yet.. and 5000K CRI 90 sounds good) … at least until the FW3A gets released (hopefully in XPL-Hi and LH351D versions)
