Sofirn Q8 group buy (gb closed, but try PM to Sofirn for discount)
1281 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 3 days 14 hours ago
DENGOH wrote:
JasonWW wrote:
DENGOH wrote:
djozz, do you have measurement of standby current? Thanks.
It should be the same as the original Q8.
135 micro amps switch led on
22 micro amps switch led off
Thanks.
I was thinking the driver might be different from BLF Q8.
The only difference should be the newer firmware. That should not effect the parasitic drain. It may have an added capacitor to make it more bump resistant.
Maybe someone can double check that the parasitic drain hasn’t increased. Only a couple people have them so far.
If anyone wants to check, here is how you do it.
You can temporarily deactivate the switch light by turning it on then ramp up or down and turn the light off very quickly.
DB Custom
DB Custom's picture
Last seen: 3 days 13 hours ago
YMMV, but I’ve seen meters show different values when the probes are inverted as they are in that picture. It can’t be an inverse drain, so of course the probes are on the wrong ends.
Seets
Last seen: 3 years 1 month ago
1 x Solfirn Q8 via Ali
deleted-200707
Last seen: 1 year 3 months ago
The Sofirn Q8 is in the Sofirn store on Amazon!
Where is my code?
Correction!!! that is the BLF Q8 Sad
owmyeyes
Last seen: 2 weeks 3 days ago
Amazon US for me, please!
Funtastic
Funtastic's picture
Last seen: 17 hours 53 min ago
2 x Sofirn Q8 via AliExpress please
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
sbslider
sbslider's picture
Last seen: 1 week 23 hours ago
In terms of different functionality,or how functionality is implemented, firmware definitely can affect parasitic drain, I don’t know anything about the difference in this case, you are likely correct.
http://budgetlightforum.com/comment/1371672#comment-1371672
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
JasonWW
JasonWW's picture
In this case we are talking about NarsilM v1.0 to v1.2. There are only small changes in the code. Whether it takes 6 years to drain or 11 or 2 makes no difference to most people. If your going to store the light for long periods it’s always best to turn the battery tube to cut all power.
Maybe someone will report back the drain they measure.
foxtermonster
Last seen: 2 years 4 months ago
Asked by Aliexpres and on the way, I hope to have her soon at home, thanks for the help. Big Smile
JasonWW
JasonWW's picture
Funtastic wrote:
The BLF Q8 is rated at 5000 lumens with XPL.
How can the Sofirn Q8 be the same with XPL HI?
Maybe because it’s a direct drive light and the measured output actually varies a lot depending on batteries and a lot of other factors.
CW also tends to measure higher than NW. So maybe they’re getting very similar measurements?
Funtastic wrote:
I’ve lost trust with the new C8F 21700 that isn’t the lumen rating they gave it.
You lose trust way too easy. Only a handful of people have actually received it so far so we don’t really know if there’s a problem or not. It may be a simple fix. It’s way too early to tell.
djozz
djozz's picture
Last seen: 3 hours 39 min ago
How can the Sofirn Q8 be the same with XPL HI? I’ve lost trust with the new C8F 21700 that isn’t the lumen rating they gave it.
Can’t wait until my TA lumen tube arrives!
I measured the sample Sofirn Q8, not exactly 5000 lumen but close enough IMO, see the OP for details, should be pretty accurate.
DB Custom
DB Custom's picture
Buying in bulk from a group buy to extort the market, priceless…
Good way to end group buy pricing for the rest of us.
Not to mention using up all the available stock so we can’t get one. Limited number available, even more limited thanks to those who abuse the system. Not cool man!
DB Custom
DB Custom's picture
Oh, I can read just fine, perhaps it’s in how you wrote it?
Regardless, Sofirn never does the spring bypass well so if you were going to resale bulk you would either have to sell em as-is or bite the bullet and do some work for your profits. It is what it is… we have come to accept compromise from Chinese vendors, will your customers learn to accept the same from you?
Still, extorting a group buy to get samples for business use is rather unscrupulous…
Gj
Gj's picture
Please add a 2nd via Amazon for me, thanks.
I’m wondering, should I get on the AE list as well in case Amazon sells out before I buy there?
azj
Last seen: 7 hours 53 min ago
Amazon US pls Smile
teacher
teacher's picture
Last seen: 2 years 2 months ago
Just to note.
Buying in bulk, a true merchant can most always get a price much better (depending on purchase volume) than a Group Buy price.
(no matter the vendor)
Samples can usually be obtained free or at minimal cost also.
Just saying…. there is no reason for a true merchant to “utilize” a GB to obtain ‘products’ to sell. There is no benefit to the merchant.
JasonWW
JasonWW's picture
Funtastic wrote:
I have my own store in New Zealand and buy in bulk when Sofirn releases a new good product so for me it’s more of an issue than most who’ve just purchased one. Won’t be fun applying any kind of fix to a large order
Also do I just leave a comment to get on the group buy or message the OP? Wanting to just get 2 x Sofirn Q8 via AliExpress this time around.
That’s definitely a different situation than most of us. Everybody takes a certain risk buying a “brand new to the market” product.
You just leave a comment here in this thread.
lachesis
Interested in 1 via Amazon US please.
Funtastic
Funtastic's picture
Just to be clear, the two Sofirn Q8’s I’m wanting from this group buy aren’t for business purposes. I’m gifting one to my father for pig hunting and the other is for a friend. If they’re good torches I’ll buy more to sell through buying directly.
Well the upside i guess is that it works fine and there’s not some fault. I may just have to drop the price and sell as they are. Hopefully Sofirn correct whatever is needed in the future as it’s an awesome looking light.
T18
JasonWW wrote:
T18 wrote:
I’m interested as well, possibly two please.
You left out which store you buy from.
I’m sorry about not mentioning the store, just had another member give me a wake up call about this,
I am happy to buy from Alie, I looked just now through Amazon U.S. and didn’t see it but that would be the best but not a big deal.
So Alie would be great and then I can buy some other things from them while I’m there,
I think I have the purchase pause down, I’ve had to do that once before with another vendor, Simon I think..?
Sorry again for my falling asleep at the wheel, hope I didn’t miss out.
Thank You JasonWW..!!
JasonWW
JasonWW's picture
It’s not for sale on Amazon yet. Any day now. For Aliexpress you can buy right now.
T18
I can wait a couple days for Amazon, will they send a message or other when they are available..?
If it’s easier for anyone I can also buy from Alie, it is not any sort of big deal time wise for me, so a day or a week no problem.
If you want to pick the place just let me know where to go and off I will go.
Thank you again
Edit: I really think Alie might be best frankly, I need some Jaxman parts and then the new CU S2+ has been haunting me so need to go by Simon’s store, so Alie I guess, I’m a dork and flashaholic, I’ll go anywhere for a light.. Ha
T18
This will be a dumb question but I rather be dumb than not asking first.
Can you tell me if those PCB’s that Sofrin is selling with all the other Q8 parts, those will still work in these lights, correct.
That way if I’m right I can mess with multiple tint LEDs and just swap them around…?
Edit: Saw the Amazon, thank you once again … great deal.
BlueSwordM
BlueSwordM's picture
Last seen: 15 min 33 sec ago
Yes they will work with the original BLF Q8, and the Sofirn one.
This is only an update to the LEDs and the firmware.
T18
Got it, Thank You BlueSwordM,
wigglybroom
Last seen: 9 months 2 weeks ago
No one got an amazon link yet?
JasonWW
JasonWW's picture
It’s not ready yet.
Old_Klein
Last seen: 7 months 2 days ago
I just need one of those for night skiing this winter. Giggle..
Can someone add me to list for Aliexpress.
Btw i also see Q8 on Bangood. Is it the same light ?
JasonWW
JasonWW's picture
There is the Sofirn Q8 and the BLF Q8. This thread is for the Sofirn version.
DB Custom
DB Custom's picture
Old_Klein, the translation to Jason’s answer is yes, essentially the same light.
The one on Banggood is the original BLF version. It has XP-L HD emitters in 3D tint (or our group buy did) whereas this Sofirn has HI emitters in a cooler tint for a tighter more throwy beam. Other than that, the same. (The BLF Q8 has flats on the battery tube, the Sofirn Q8 does not.) So, minor differences in the same light. lol
