Review: KD 7135 V2 drivers 3040/2280/1520 mA with mode configuration
158 posts / 0 new
Lagerregal
Last seen: 7 years 11 months ago
viktori wrote:
Now, I have no idea if anyone else should order custom as well. I did tell them that if all goes well I'd be telling my friends and they will get more orders.
I'm the crash test dummy again. If anyone orders, please tell me about it. Perhaps PM me and I'll tell you my order number so you can quote it if you want the same thing.
Viktor
do you have any news? i am interested in ordering as well Smile
viktori
viktori's picture
Last seen: 4 years 8 months ago
Yup, arrived yesterday!
I got 5 pcs, one already in a flashlight, and that one works almost as expected.
Will post more info in the next few days.
Viktor
This is my flashlight collection.
TNT
Thanks to victori, I contacted KD with my own request and they said it should be fine, send them an order number of 5ea of these drivers and they will look into modifying them... I requested:
1. Original setup
2. Original setup
3. High - Low2 (10%)
4. Low2 (10%) - High
5. High - Low2 - Strobe
6. Low2 - High - Strobe
7. High - Med (30%) - Low (5%)
8. Low (5%) - Med (30%) - High
This should give me unlimited possibilities of modding for XPG at full power, XML at full power (by default) and adding 4 more chips for total of 4.5A for Triple XPG or Nichia... Should be awesome if they fulfill my request... fingers crossed... If they do, I know I'll never buy any other linear driver as this would cover for everything... Smile
DrJones
DrJones's picture
Last seen: 4 years 12 months ago
I still wonder what microcontroller they use...
Lagerregal
that are great news Smile  looking forward to your information
Sprinkles
Last seen: 4 weeks 19 hours ago
Same here.....
Sprinkles
It would be nice to see this driver be able to handle using a single primary 123 battery.  I don't know what would need changing in order to have that happen....it looks more specifically suited for 3.7v not 3.0v.
Can anyone spread some "light" on that for me?  (pun intended Smile )
pounder
pounder's picture
got 2 of these drivers I ordered awhile ago..they flashed them so my modes are ~3a, ~1.35a, ~.070a..awesome spacing...
JustFit
JustFit's picture
Last seen: 2 hours 24 min ago
viktori wrote:
Hey!
I didn't say no, did I? Smile
Here is a quote from Kural.
Quote:
Hi friend,
We can help you modify the driver as below:
XXX 3040mA 1500mA 500mA 150mA 30mA 5mA 10Hz 2Hz Beacon1 Beacon2
OXX 5mA 30mA 150mA 500mA 1000mA 3040mA 10Hz 2Hz Beacon1 Beacon2
OOX 3040mA 1500mA 500mA 150mA 30mA 5mA
OOO 5mA 30mA 150mA 500mA 1500mA 3040mA
XOO 3040mA 750mA 200mA 50mA
XXO 50mA 200mA 750mA 3040mA
OXO 3040mA 1000mA
XOX 3040mA 1000mA 2Hz
Beacon1 is 10sec off, 1sec on
Beacon2 is 10sec off, 1sec 3Hz strobe
You can just buy 5 pieces or 10 pieces is okay, please make a order on http://www.kaidomain.com/Product/Details.S020073
After you paid, please send your order number to me and let me arrange it.
Viktor
 Thank you for the info viktori . It's good to know they also flash them custom
Think twice, act fast!
JustFit
JustFit's picture
Question : Has anyone tried giving a good tap to the flashlight that has one of theese drivers installed?
I recently bought two KD 6x7135 V2 LED Driver 2280mA  , I've installed them in two UltraFire XM-L T6 WF-504B , used different settings , and if I tap anyone of them while on  High Mode, it automaticaly goes to Medium Mode, the memory mode S1 brige is connected so even if the battery would disconnect for a fraction of a second it wouldn't have to do this. I've noticed this odd thing because I'm using them on my bicycle...
pounder
pounder's picture
yes mine switches too if I hit it..a solution is to snug up the battery with tape or cardboard shims and/or adding a small standard p60 spring to the existing spring..I had to add springs to the old 105c drivers because the stock ones wouldn't contact the battery..i'll have to do the same thing to these drivers..
here is a link to pictures of what I did with the extra spring..the copper wire was left as it was more hassle to remove it than to just leave it..
http://budgetlightforum.com/node/1918
JustFit
JustFit's picture
The spring was also my first tought , probably when you tap it , for a fraction of a second there's a weak contact at the + end, and because of this the voltage drops below 2.8 V and the protection kick's in , which sets the output to 35 % ...
Thanks! I will try it. (and will probably work Laughing )
pounder
pounder's picture
yeah the spring rate on these drivers is really stiff..so any shot is going to lift the battery off the spring and not allow for a compensation like you get with these weaker p60 springs..it's really easy to fit the new spring on the existing spring..you just have to make sure the diameter of the part going on the stock spring is tight then feed solder to join..
viktori
viktori's picture
I've posted an article on my custom ordered KD 7135 V2 3040mA LED Driver:
http://budgetlightforum.com/node/9655
Viktor
Lagerregal
the drivers are now available with 50mA low mode at kaidomain. but you need to buy 5.
FX-32
FX-32's picture
Last seen: 4 years 11 months ago
Andi wrote:
Piggyback works fine, i soldered 2 extra 7135 (350mA) on it, and driver delivers 3,74A.
I bought some of them to give it a try, I tried adding an extra 7135 (350mA from the V1), but when I connect the chip the driver doesn’t turn on…
Why can this be? maybe the extra 7135 is damaged? or maybe they should be inserted in some specific order?
If someone did it before with this KD V2 I would like to know where to connect the extra 7135
EDIT: I did this before with the V1 version, at first it didn’t work until E1320 helped me with the order, and since then it always works… but this new driver is giving me this problem again Sad
Here is a pic of the not working piggy mod, it is not fully connected
MosesM
MosesM's picture
Last seen: 2 days 5 hours ago
Hey FX-32, I haven’t tried stacking 350mA and 380mA chips together, but strictly judging from your picture, are the middle legs soldered together?
Reason I’m asking is because when I stack them, I usually solder together the larger tab at the back instead of the middle leg since they are the same anyway (if that makes any sense).
NightCrawl
Last seen: 5 years 1 month ago
I have mixed different AMCs and it worked.. if that's any help for you.
raccoon city
raccoon city's picture
Last seen: 9 hours 45 min ago
Welcome to the family, MosesM!
Best0270
Moses
FX-32
FX-32's picture
Welcome to BLF MosesM!
No, I didn’t soldered the middle leg, just the larger tab as you say.
Anyway, the flashlight is now done, 3050mA is OK…
taz
taz's picture
Last seen: 1 year 3 months ago
I am curious about how the modes rotate... a while back I installed the driver to a V6-T60, selecting hi/med/lo modes, no memory. However if I stay at any mode longer than a sec or two, then to go to the next mode I have to half-click twice. So for example I start on high, if I leave it a bit and want to go to med I half click twice. If I leave it at med and want to go to low I half-click twice again. If I do it fast I can rotate through the modes with a single click. Is this normal mode behavior?
agedbriar
My Nanjg 105 works the same and another one (brand/model unknown) too.
Rufusbduck
Rufusbduck's picture
Last seen: 1 week 5 days ago
Another possible reason for having only high mode. The led+ pad is adjacent to the Vdd pin on one of the chips(large ground tab on top, bottom right pin is Vdd). If the pad is shorted to the pin with solder you will get only high mode, leaving the controller screaming in the closet.
Scott
bowhunter
Last seen: 5 years 11 months ago
does anyone have a diagram on how to slave 2 of these boards together?
thanks
apt323
apt323's picture
Last seen: 2 weeks 22 hours ago
I used the 1500ma board to drive a xre p4 warm white. I set it to 3 modes lo-med-high with mem, but it has lo-med-high but no memmory but im sure i didnt get something correct on that. What I did notice is that if I half clicked six times when i was in low fast that on the next half click it would go to strobe then to sos. then if i left it off for a minuted then it went back to only have 3 modes only lo-med-high.
Its like it has hidden modes. Has anyone ever experienced that before?
bowhunter
hi gang – does anyone have a diagram/info on how to slave 2 or 3 of these drivers together? – also, can the low voltage cut off / protection be eliminated??
thanks
TNT
Did anyone succeed turning KDv2 into SINGLE mode with current regulation still in place ???
I did look at Intl-Outdoors NANJG 105c and it shows pretty clear how to turn that one into single mode (remove two small components marked with R1 and R2 as well as control 8-pin chip, then solder together three upper-left points where the chip was… as well as capacitor on the other side…
http://intl-outdoor.com/amc71358-1mode-circuit-board-nanjg-105c-p-643.html
Anyone tried it yet with KDv2 ???
Matjazz
Matjazz's picture
Last seen: 1 week 1 hour ago
Looks like yo haven’t connected any bridge. Your driver is still in the default 10-mode group:
lo – med – hi – lo – med – hi – strobe – warning – sos – beacon
Now I see
lhartman89
Last seen: 7 years 4 months ago
So I got the 3040 ma version of this and tried it out and I only get high. I checked all my solder points and everything looked good. I originally soldered S1 for memory and S3 for high > med > low and all I got was high. Then I de-soldered both S1 and S3 and I still only got high. I might have heated up some of the 7135 chips when soldering on the neg and pos wires. I don’t know what is wrong with this thing. I’m about ready to take off the 7135 chips and throw it away. This is my first time messing with swapping drivers. I had no problem re-installing the old drivers and they work fine.
Itinifni
Itinifni's picture
Last seen: 1 day 18 hours ago
Make sure you didn’t bridge the LED – wire to the outer ground ring on the driver, I believe that will leave you with one mode at direct drive.
Also make sure that same wire is not grounded to the pill.
I remember a time, when I searched for lights to fit my needs. Now I search for needs to fit my lights.
