112MM DIA DCX LENS 169MM FL B270 GLASS possible use in our mods?
This is lens on Surplus Shed, I was curious if it was something that might be used in flashlights or builds.
https://www.surplusshed.com/pages/item/PL1276.html
“slightly aspheric” is not something you want in a flashlight lens.
It should be perfectly aspheric.
You also need PCX not DCX.
Enderman, thanks for checking this out, and the input.
:+1:
Still haven’t found any better affordable lenses than Optolife, if you need cheaper then fasttech or dx are your best bet.
