In another thread I ran through my experiences with budget headlights and concluded that I couldn't come to terms with the Ultrafire H3 that I'd bought.
Since then, I have followed the advice of gcbryan and covered the lens with a disc of Scotch Magic Tape, to eliminate the circular artefacts. I have also changed the way that the light attaches to its headband (see below), which makes it considerably less bouncy.
The light has now been elevated from my 'least favourite', to 'most used' headlight. I particularly love the way that the flood beam's periphery fades into the darkness, as opposed to having a distinctive defined edge.
Here in northern Britain we are currently reduced to 7 hours of daylight; hence the light gets used twice a day for dog walks of 60-75 minutes apiece. I can only measure output via an incident light meter, which at 2.5" reads 12 EV. I prefer to use the light with this ramped down to 10.5 EV and six hours of such usage pulls a protected UF 3000 mAh battery down from 4.15v to 3.60v.
Don reckons this light's XRE-Q5 produces 120 lumens on full, so I'm guessing that at 1.5 stops less, it's producing around 37.5 lumens. At this setting it is plenty bright enough for my walks. On the narrow riverside path where I have lots of tree roots and stones to negotiate, I also use a hand-held UF-502 set on low to illuminate these from a lower angle. Side projection picks them out much better than when illuminating them from head height, which doesn't correctly reveal their 3 dimensions.
I want to fall in love with this light but having just zapped a different XRE-Q5 headlight that had serious thermal issues I am half preparing myself in case things go wrong. I find that after an hour's use the light remains cold to touch, but am unsure whether that is due to a lack of thermal pathway, or that I'm simply not pushing the LED hard enough to make it produce heat. Can these lights be safely run for long periods on high? I have seen stories of similar XRE-Q5 Zebralights becoming too hot to touch after 10 minutes of full power usage.
My second concern is about waterproofing. If I blow into the battery compartment I don't hear any air escape, which suggests the light is reasonably impervious and should stand a shower of rain (which is has). I don't plan to immerse it in water, but would appreciate any commentary upon the light's waterproofness (or otherwise) and whether this can be improved upon.
