Samsung INR18650-33G 3150mAh (Blue)
Official specifications:
Typical capacity: 3150mAh
Minimum capacity: 3000mAh
Charge voltage: 4.20V
Nominal voltage: 3.60V
Charging method: CC/CV
Standard charge current: 975mA
Maximum charge current: 3250mA (Not for cycle life)
Maximum continuous discharge current: 6500mA
Maximum pulse discharge current: 9750mA
Discharge cut-off voltage: 2.5V
Cycle life: 500 cycles to 75% with 975mA charge and 3250mA discharge.
Operating temperature: charge: 0°C ~ 45°C, discharge: –20°C ~ 60°C
Storage temperature: 1 month: –20°C ~ 60°C, 3 months: –20°C ~ 40°C, 1 year: –20°C ~ 45°C
This is a high capacity cell with limited current capabilities.
The discharge curves matches fine, but the cell is not for high current, even 10A is over the limit, but then it is not rated for more than 6.5A
Conclusion
It is a good quality high capacity cell, but watch out for charge current.
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
