Hello my dear friends!
new weekend – new groupbuy!
Lumintop C01
400LM XPG3 LED German Standard
Built-in 1400mAh Li-polymer Battery
Rechargeable Cycling Bicycle Bike Light
Features:
- Utilizes XP-G3 neutral white LED with better color rendering and a 50,000 hours lifespan
- Three output levels with Strobe, SOS and Beacon, max 400 lumens
- Built-in 3.7V/1400mAh Li-polymer battery, provides a 10.5 hours max runtime
- Micro USB rechargeable with charging indicator
- Featuring low power indicator and intelligent output downshift function
- Tapered surface reflector designed with German standard, reduce the hazard of glare to oncoming people
- Detachable and adjustable bike mount, fit for 19-33mm diameter bicycle handlebar
- 360-degree rotatable on the mount allows easily to adjust the shooting direction
- One switch for fast and easy operation
- Versatile to serve as a bicycle light and handheld flashlight
- Made of high-intensity ABS materials, solid and lightweight
- Size: 77.5*45*31.5mm (excluding handlebar mount)
- Net weight: 87.5g (excluding handlebar mount)
- IP68 rated protection, 1.5 meters impact resistance
Operation:
ON/OFF: Click the switch for ON, long press the switch for 1 second for OFF.
Output selections: When the light is on, click the switch to cycle through Low-Med-High.
Next time you turn on the light, it will recall the previous output level.
Flash: When the light is on, press and hold the switch for 4 seconds to enter Strobe,
another click to cycle though Strobe-SOS-Beacon.
Package includes:
1x Bicycle light mount
1x User manual
1x Warranty card
1x Charging cable
