Test / Review: Callies Kustoms 3100mAh (Black)
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 5 hours 2 min ago
This is my first "stand alone" battery test/review, there is very little text in the review, but I have written a seperate article with more information about the information box and the charts. Later on I plan on making a comparison, like my old2010 and 2011 battery reviews.
DSC_0301
Callies%20Kustoms%203100mAh%20(Black)-info
DSC_0268 DSC_0269
DSC_0273 DSC_0274
DSC_0270
DSC_0271
DSC_0272
Callies%20Kustoms%203100mAh%20(Black)-Capacity
Each chart has curves for two batteries, but these batteries are nearly identical in performance and the curves are on top of each other.
Callies%20Kustoms%203100mAh%20(Black)-CapacityTimeHours
Callies%20Kustoms%203100mAh%20(Black)-Energy
Callies%20Kustoms%203100mAh%20(Black)-PowerLoadTime
Callies%20Kustoms%203100mAh%20(Black)-TripCurrent
Callies%20Kustoms%203100mAh%20(Black)-Charge
The battery is charged to 4.2 volt (More precise: 4.196V), but when the charge current is stopped the voltage falls immediately to 4.185 volt and during the next hour to 4.163 volt. This is normal for LiIon batteries.
Notes and links
Edited by: sb56637 on 08/26/2014 - 17:47
jacktheclipper
jacktheclipper's picture
Last seen: 22 hours 12 min ago
Thanks , man .
What I do
Chicago X
Chicago X's picture
Last seen: 8 years 6 months ago
Thanks very much for the detailed review !!!
Crib notes:
*Extremely well-matched cells, perfect for multi-cell operation.
*Over 8-Amp discharge rate.
*Very good capacity at both high and low discharge rates.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
HKJ
HKJ's picture
That was a surprise, when I did the first trace of the second cell and looked at the graph, I could not find it! A close study revealed that there was two curve, nearly perfectly on top of each other.
I believe that some of the reason for this close match is because I have very tight control of the charging. I wonder how other cells will do.
PierCC
Last seen: 1 year 3 months ago
thank you HKJ!
your tests are always very interesting
