Sofirn SP36, impressions of a sample
583 posts / 0 new
HONDARIDER
HONDARIDER's picture
Last seen: 1 month 4 days ago
Are there bare MCPCB’s available for the SP36? I’d love to keep the L2’s and be able to put some 3000K or 4000K XP-L HI in it if I wanted.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 2 weeks 6 days ago
Thats only possible for the Q8 and C8F.
For the Q8 there are other footprints available.
https://de.aliexpress.com/wholesale?catId=0&initiative_id=SB_20190213110...
https://led4power.com/product/l4p-blf-q8-40405050-38mm-dtp-direct-therma...
HONDARIDER
Yep, I actually have 2 of those. Just hoping they will be available at some point. Guess I will just modify the one I have. more of a 3500K fella.
robertsig
Last seen: 20 hours 30 min ago
It was asked on page 3 about PWM.  Any update on that?  Is it a mechanical switch?  Any parasitic drain?
ToyKeeper
ToyKeeper's picture
Last seen: 52 min 12 sec ago
Did you mean to post this in a different thread?
The SP36 has 16 kHz PWM, an e-switch, and virtually zero parasitic drain when the button light is off.
Barry0892
Barry0892's picture
Last seen: 3 days 13 hours ago
I started a topic on SP36 Anduril version with new samsungs leds. Sofirn need your opinion.
http://budgetlightforum.com/node/66002
WhatsApp: +8615773183209
My new Facebook account: https://www.facebook.com/barry.dong.9250
fluke
Last seen: 5 days 2 hours ago
Anyone know how to get the driver out ?
djozz
djozz's picture
Last seen: 1 hour 1 min ago
In post#62 in this thread is how I did it.
fluke
Thank you.
Tom E
Tom E's picture
Last seen: 1 min 20 sec ago
 Post #442 here is what I did, using a wire.
Alexium
Last seen: 6 months 1 week ago
Got my little monster the other day. The first impressions are very good.
Love the smaller size. The brighter button LEDs are fun, can use them for illumination as long as it’s sufficiently dark. Q8’s LED draws 4 mA, SP36’s 5 mA, but the latter is much brighter despite the black button cap (silly choice of material if you ask me).
The build quality, on the outside, seems as good as the Q8. The threads were lubricated much better than on the Q8 I bought a year ago.
The built-in charger is something I would rather save $5 on, but I won’t deny it’s convenient. Charged my 30Qs to 4.204 volts, darn good voltage calibration.
What I like better about Q8 compared to SP36:
  • The steel bezel. Makes it feel sturdy, and you’re not afraid to smash the Q8 into other sturdy things.
  • The chamfers on the body that make it unlikely to roll off a surface. SP36 is very round.
  • The colder light. This is about as cold as I can still call neutral.
Sp36 gets hot way faster than Q8. At first I thought it’s because of the larger surface area and overall bulk of the larger light, but then I begun to think the difference is too large to be attributed to surface area. I think SP36 might have better thermal contact between the LEDs and the head tube. Perhaps, my Q8 is not well assembled, lacks thermal paste or something?
MTE C3-907 -> Convoy C8 -> Convoy S2+ -> BLF Q8 -> Sofirn SP36 -> Somebody please make me stop!
Spartan
!{width:50%}https://i.imgur.com/D2XIWSq.jpg!
Given the same amount of heat from the LED’s, the smaller mass of the SP36 will heat up faster.
Moses came from the mountaintop carrying a tablet. The Words were....WITH GREAT LUMENS COMES GREAT REPONSIBILITY.
Tom E
Tom E's picture
XP-L2's in the SP36 draw more amps than XP-L's in the Q8, have a lower Vf, so should get hotter. Your Q8 is probably fine. Yes, Q8 has a super thick shelf, bigger, more metal host - should handle the heat better, little longer.
Alexium
Sure, but the difference seems to be too large to be attributed to that alone. Also, not only does it reach higher temps, it starts getting warmer much sooner after I turn it on than Q8. That tells me that thermal conductivity is better in SP36.
djozz
djozz's picture
Still I’m sure it is not a worse heat path in the Q8, it is thermally one of the best lights around and the way it is built, even in assembly there is hardly a way to screw it up.
I think that you underestimate how much more metal is in the Q8, it has a higher heat capacity so it warms up (and cools down) more slowly.
Alexium
You must be right then, my experience with flashlights is zero compared to yours. Still, it’s nice to see that SP36 has a good thermal path.
Tom E
Tom E's picture
Again as evidence, my stock SP36 did 6800-6420 lumens - about 1000 lumens higher than any stock Q8 I've tested -- main reason: XP-L2's. The Q8 XP-L's are V6 and I assume the SP36 XP-L2's are also V6, if so, the SP36 must be pulling more amps.
Ilumenati
Ilumenati's picture
Last seen: 3 weeks 15 hours ago
Anyone found a nice diffuser for the sp36?
I can’t find one that fits and I think it would make a handy little lantern at times.
Thanks,
Alexium
I was not able to detect a difference in lumens between my Q8 with 30Qs and SP36 with VTC6. Looks like buying VTC6 was a waste of money, 30Qs are just as good even for powerful flashlights.
Tom E
Tom E's picture
I get consistently higher output #'s on VTC6's vs. 30Q's in many FET based lights. Not just 1 or 2, it's every light - factory FET based, or modded, I've tested - dozens. Whether you notice it, is something else. Comparing a Q8 and SP36 is different LED's, different tints, somewhat different beam patterns.
Funtastic
Funtastic's picture
Last seen: 7 hours 47 min ago
Tom E wrote:
Again as evidence, my stock SP36 did 6800-6420 lumens – about 1000 lumens higher than any stock Q8 I’ve tested — main reason: XP-L2’s. The Q8 XP-L’s are V6 and I assume the SP36 XP-L2’s are also V6, if so, the SP36 must be pulling more amps.
My TA calibrated lumen tube gets just above 6000 lumens at turn on and 5400 at 30sec using 30Q’s with the SP36.
What are you using to measure yours?
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Funtastic
Funtastic's picture
Would VTC6 cells give a 400 lumen improvement?
Tom E
Tom E's picture
Funtastic wrote:
My TA calibrated lumen tube gets just above 6000 lumens at turn on and 5400 at 30sec using 30Q's with the SP36. What are you using to measure yours?
Not sure what "TA calibrated" means. I have one of the "original" PVC based measuring devices made by the brothers Rick and Rodney. Those #'s are my typical calibrated measurements I've been positing here on BLF for about 5 years or so. I re-calibrated it using the maukka calibration lights and figured the results are 12% lower than my previous calibrations based on manufacturer spec'd lights - 100's.
 So just subtract 12% from my #'s and you got maukka ANSI calibration.
Funtastic
Funtastic's picture
Tom E wrote:
Funtastic wrote:
My TA calibrated lumen tube gets just above 6000 lumens at turn on and 5400 at 30sec using 30Q’s with the SP36. What are you using to measure yours?
Not sure what “TA calibrated” means. I have one of the “original” PVC based measuring devices made by the brothers Rick and Rodney. Those #‘s are my typical calibrated measurements I’ve been positing here on BLF for about 5 years or so. I re-calibrated it using the maukka calibration lights and figured the results are 12% lower than my previous calibrations based on manufacturer spec’d lights – 100’s.
 So just subtract 12% from my #‘s and you got maukka ANSI calibration.
I meant one of the Texas Ace lumen tubes he sold and I calibrated it with maukka lights. My wording could have better.
I sell a lot of flashlights here in New Zealand so I’ll look into stocking some VTC6 cells instead of 30Q’s.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 21 min ago
Driver popped right out of my SP36 I got today, glue didn’t stick/adhere too well to the ano even though it’s bathed in it.
LED’s and FET got to go! Sick
KB1428 “Live Life WOT
djozz
djozz's picture
I’m looking forward to your mod! Smile
Hollybrook
Thanks,
I made one from the clear plastic cap on a laundry detergent bottle. Sanded the inside to frost it and put white paper at the bottom (top?) to reflect light towards the table. Works pretty well at about 1,000 lumens.
kuzuna
Does anyone know of any good belt holsters that fit this, or if Sofirn plans to sell one for it?
Yokiamy
Yokiamy's picture
Last seen: 17 min 56 sec ago
I am a bit disappointed in sofirn, i bought an SP36 almost 2 weeks ago on their AE store and it showed as ‘in stock’
Next day i received a tracking number, but until today no result, so shot them a message, their reply was, sorry the item was not in stock, we will ship as soon as we have it on stock…
@kawiboy, Nice to read you got it open that easy! did you use that bended bodkin, or what tool is it?
KawiBoy1428
Yes, it is a Craftsman Pick, I have a full set. https://www.sears.com/craftsman-4-pc-hook-and-pick-set-with/p-0094163400...
