OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
1420 posts / 0 new
Funtastic
Funtastic's picture
Last seen: 16 min 42 sec ago
Much appreciated.
Just as I thought when I compared to KD’s mcpcb. Confirms that mine aren’t dtp for the Osram red, I’ll reflow one to the KD board. It’ll be great if I can drive them harder.
They’re currently on 3535 so using 3030 may improve too
I was going to buy Convoy’s newly added 3030 boards but can’t tell by photo if really dtp?
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
Barkuti
Barkuti's picture
Last seen: 1 day 5 hours ago
Funtastic wrote:
I was going to buy Convoy's newly added 3030 boards but can't tell by photo if really dtp?
I really doubt Simon has any interest in run-of-the-mill boards. Had to look: 20mm DTP copper board for 3030 LED / for osram KW...
Pretty explicit.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases! They are better called exosomes, and they are cell cleaners! Watch Virus Theory vs Exosome Theory video and awaken to this truth! Check this article by MD Andrew Kaufman. Read the book “Béchamp or Pasteur” by Ethel Hume for in-depth information.
The_Fat_Controller
The_Fat_Controller's picture
Last seen: 1 year 3 months ago
Barkuti wrote:
While reflowing tap the emitter with a cotton bud Funtastic, this removes excess solder.
What he said, This method is excellent.
The led4power dtps are nice quality! a good flat fit to the host with some grizzly kryonaut and you’re pretty well sorted.
Funtastic
Funtastic's picture
The boost version of the 2mm? is available here but needs reflowing to DTP
contactcr
Last seen: 6 hours 12 min ago
I ordered from here last week but until they arrive I will remain skeptical
The_Driver
The_Driver's picture
Last seen: 7 hours 26 min ago
Funtastic wrote:
The boost version of the 2mm? is available "here":https://www.aliexpress.com/item/4001162805115.html but needs reflowing to DTP
We have waited two years for this LED to finally become available! Supposedly the ultimate thrower LED.
Interestingly, the SBT-90.2 which became available in the meantime is a better fit for many larger lights.
luminarium iaculator
luminarium iaculator's picture
Last seen: 19 hours 59 min ago
Party I hope it will not be to hungry…
JaredM
JaredM's picture
That “HX” from AE (YinDing) seems off. What’s with the exposed gray portion next to the die? Also, their other white flat listings have unusual markings on the surrounding white areas of the package.
https://fundrazr.com/osturaband
No affiliation, just a fan.
Funtastic
Funtastic's picture
I’m using their red flats and they’re legit
contactcr
I would guess preliminary version of LED (is why it looks different)
d_t_a
Last seen: 16 hours 49 min ago
I got here 2 flashlights with supposedly Osram NM1 LEDs
Both have some letter markings on top of the LED, but one of them also has a grey bar on the side (while the other does not).
Is there any difference?
contactcr
Why do you think they call it LED lottery? You are supposed to scratch it off and see if you win!
/s
no idea
JaredM
JaredM's picture
As contactr mentioned earlier. I’m presuming this is a pre-production or engineering sample type marking..
d_t_a
Another 2 flashlights with Osram, one has the gray bar, the other doesn’t.
Yokiamy
Yokiamy's picture
Last seen: 10 hours 9 min ago
!https://i.imgur.com/nGCseAG.png!
Any specs?
The right one seems to be the CULPM1;which is the higher current version of CSLPM1.TG. There aren’t too many manufacturers around which use them
HONDARIDER
HONDARIDER's picture
They look the same size to me. isn’t the CULPM1 the 2mm version?
d_t_a
Any specs?
Both flashlights are the same model: Manta Ray S21 with Osram NM1 LED (supposedly) – one has a gray bar, the other does not. The Manta Ray S21 uses a 2.8Amp (7135×8) driver, but the UI is sort of different (it seems to be related in terms of configuration as the Convoy C8+ SST40 ‘ramping’ driver version).
In my other set of Osram NM1 photos, one is a Wainlight C8S-G with Osram NM1 LED (no gray bar), the other is a Boruit C8 with Osram NM1 LED (but has a gray bar). The Boruit C8 and the Wainlight C8S-G look very similar (they use the same flashlight host as the Convoy C8+, but place an Osram NM1 LED and both seem to use a driver that is similar to Convoy’s 5/3-mode group driver (also 7135×8 or 2.8Amps).
Yokiamy
Yokiamy's picture
you’re correct
i was thinking about this one
https://nl.aliexpress.com/item/4001162805115.html
SKV89
Last seen: 14 hours 6 min ago
Yokiamy wrote:
you’re correct
Wow that’s a good find! You can even buy this soldered onto various size boards down to 11.8mm for use in AAA sized lights!
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 2 weeks 2 days ago
CULPM1 also has a 4×4mm pad IIRC (vs 3×3mm on the CS models), isn’t that why it has higher thermal resistance?
Funtastic
Funtastic's picture
SKV89 wrote:
Yokiamy wrote:
you’re correct
Yes, but not on 3030, he uses 3535 and the copper boards aren’t dtp
Barkuti
Barkuti's picture
BurningPlayd0h, according to my wisdom a bigger footprint equals lower thermal resistance; or it should.
Kaidomain has both 3030 and 4040 DTP boards for sale, check here:
http://kaidomain.com/Flashlight-DIY-and-Tools/led-pcbs-or-mcpcbs?limit=100
Barkuti
Barkuti's picture
In the absence of led4power (hope they're back sometime), some way or the other we now have access to all 4 White Flats. The thread should now be renamed to
OSRAM CSLNM1.TG 1mm², CSLPM1.TG 2mm², CULNM1.TG 1mm², CULPM1.TG 2mm²
or maybe to
Hope Mr luminarium iaculator notices. Is someone going to test the Boost HX? The 2mm² WF is more surface to power constrained, this means the Boost HX should obtain a higher gain than the HL. Sent a PM to djozz…
Barkuti wrote:
In the absence of led4power (hope they’re back sometime), some way or the other we now have access to all 4 White Flats. The thread should now be renamed to
or maybe to
I did seen and changed… Thumbs Up
I still can’t remember those Osram emitters… It is to complicated to me. Letter and number dizziness Tired
P.S.
First post of this thread requires re-editing with all relevant data. Thread is hard to follow and maybe it is better to read it backward > forward direction.
Funtastic
Funtastic's picture
Can someone please check my below list for white, red,, blue, and green to see if it’s correct or missing any
Trying to tell Simon what I need
This is the reply I received from Simon when I asked for confirmation that he had CSLPM1.TG, not CSLNM1.TG
Quote:
i got some CSLPM1.TG ,these should be green light LED,i will test it
i think you need CULPM1.TG,right?
I’m really not a fan of the way Osram has assigned their part numbers
List I have
White – KW CSLNM1.TG – 3030 (1mm²)
White – KW CSLPM1.TG – 3030 (2mm²)
White – KW CULNM1.TG – 4040 (1mm²)
White – KW CULPM1.TG – 4040 (2mm²)
Red – KR CSLNM1.23 – 3030 (1mm²)
Blue – KB CSLNM1.14 – 3030 (1mm²)
Green – KP CSLNM1.F1 – 3030 (1mm²)
Green – KP CSLPM1.F1 – 3030 (2mm²)
I just want to send this to Simon
contactcr
Barkuti
Barkuti's picture
By the way, djozz told me he'll be reviewing the Boost HX for sale @ Shenzhen silver ingot Technology Co., Ltd.
We'll see. djozz told me he received a Boost HX sample way back from Hank, and it performed even worse than the 5P bin CSLPM1.TG he reviewed from Neven (led4power) back then (1480 versus 1530 djozz lumen), despite reaching a higher maximum current at 9A as expected. This means that CULPM1.TG probably was some ugly duckling pre-production sample or God knows what.
Hope those CULPM1.TG emitters are some decent bin, 5P minimum.
Funtastic
Funtastic's picture
One question, how to tell which way I reflow these leds for their polarity? Twice now I’ve got it wrong.
Funtastic
Funtastic's picture
Reply from Simon
Quote:
White – KW CSLNM1.TG – 3030 (1mm²) in stock
White – KW CSLPM1.TG – 3030 (2mm²) Not purchased
White – KW CULNM1.TG – 4040 (1mm²) Not purchased
White – KW CULPM1.TG – 4040 (2mm²) It has been purchased and the goods are in transit.
Red – KR CSLNM1.23 – 3030 (1mm²) 7L-2-0 200pcs in stock
Blue – KB CSLNM1.14 – 3030 (1mm²) Not purchased
Green – KP CSLNM1.F1 – 3030 (1mm²) 8P-A-0 167pcs in stock
Green – KP CSLPM1.F1 – 3030 (2mm²) 6P-A-0 200pcs in stock
Yellow – KY CSLNM1.FY – 3030 (1mm²) Not purchased
Just thought I’d share in case anyone wants some Red or Green from Convoy since it’s not listed on the store
jojosupir
jojosupir's picture
Last seen: 1 year 4 months ago
I hope this could help.
Screenshot-from-2020-08-05-12-19-01!
Screenshot-from-2020-08-05-12-19-03
