Medium sized throwers
85 posts / 0 new
Jaketheone4646
Last seen: 2 years 5 months ago
So the L21 it is so far, is there any other 21700 thrower out there?? Looking for a thrower that will give me noticeably more than my astrolux c8 which I love by the way.
Yokiamy
Yokiamy's picture
Last seen: 8 hours 41 min ago
The L21A comes with XHP35 also since last week, and might throw even better.
My FT03 fits an 21700 as well, but it’s a tight fit
Agro
Agro's picture
Last seen: 10 hours 30 min ago
Thanks for mentioning these lights. Smile Looks like L21A is missing, I will add it soon.
As far as I can tell, M21A is just a C8 with 21700 tube, right? If that’s the case, it’s too small for inclusion.
KeepingItLight
KeepingItLight's picture
Last seen: 1 day 4 hours ago
VestureOfBlood posted an amazing video in this thread about the the Acebeam W30.
  • White laser
  • Pencil thin beam rated at 1.5 million candela
  • Small size, single cell, etc. all meet your spec.
Possible downside: little or no spill makes this a special purpose tool. One poster suggested that it may be ideal for certain boating and marine applications, such as spotting marker buoys at distance without generating huge reflections off the surface of the water.
Agro
Agro's picture
I still don’t really know what to do about LEP throwers.
Some seem to clearly fit this thread but at the same time they are so different from LED ones that I feel they deserve a thread of their own….
Kindle
Kindle's picture
Last seen: 3 months 4 days ago
Yes, same head and reflector.
You could always include LEP lights in this thread but place them in their own chart below the main one.
man of light
man of light's picture
Last seen: 1 month 4 weeks ago
I miss the FT03 with XHP50.2 on the List.
Also would be nice if the available tints for each where listed, although it’s a lot of work and not really necessary.
Agro
Agro's picture
Thanks for pointing this out, I just added it. I have a feeling there are more measurements to be found but I don’t have the time to do the search…
Thank you for this suggestion as well, though I think it would clutter the table.
Actually I’m thinking about what can I remove from the list to make the rows smaller…
Kindle
Kindle's picture
You could combine empty/loaded weight into a single column.
Agro
Agro's picture
Good idea. Will do it later. Smile Smile
Kindle
Kindle's picture
My other thought would be to replace the ‘charger’ & ‘type’ columns with a ‘notes’ column. With most of the lights utilizing a reflector and no on board charging, that would be the default. Then you could add anything outside of that in the notes column (Onboard charging, aspheric lens etc).
Agro
Agro's picture
I will think about it.
I did some formatting changes already, it’s a bit better.
I see that I forgot to add Convoy L21A – that’s TODO.
I added SBT-90 variant of NI40. This thing performs niiice. Smile
Agro
Agro's picture
I finally added Convoy L21A today.
beggindog
beggindog's picture
Last seen: 1 year 9 months ago
Sofirn C8G ?
t ouellette
d_t_a
Last seen: 1 hour 49 min ago
Hi Agro, appreciate your making this table (and also other comparison tables for flashlights which I noticed here in BLF).
Since the list is growing, would you happen to have a spreadsheet version of it online (so can be sorted by KCD, or lumens, or price, etc.)? Thanks!
Agro
Agro's picture
beggindog wrote:
Sofirn C8G ?
Thanks for the suggestion but due to my time constraints I limited the list to lights that are strictly larger than C8.
I really like that idea. I’ve been looking for some good way to make these lists more collaborative and this might just be the right way to do it. I’ll explore the possibilities in the coming days.
Also, this collaborativity may enable expanding the scope of the list to include throwers of all sizes…
Agro
Agro's picture
I added Noctigon K1.
As to conversion to a spreadsheet – I did some work on that but have no success so far.
I tried to find a good spreadsheet software for the task.
So far I tried ethercalc. I used that before and I like it but it appears that it doesn’t support multiple links in a single cell.
I ruled out google calc – I just don’t like google.
There are a few other options but I didn’t find time to check them out yet.
jojosupir
jojosupir's picture
Last seen: 10 months 1 week ago
How about Speras t1 @Agro?
Agro
Agro's picture
AFAIK it’s dual cell?
jojosupir
jojosupir's picture
Facepalm my bad
How about weltool t11?
Agro
Agro's picture
Thanks, looks ok at the first sight, I will add it later.
Agro
Agro's picture
Sorry for the delay, I added Weltool T11 just now.
Xeen
Xeen's picture
Last seen: 3 months 4 weeks ago
Add Acebeam T28?
It has a larger reflector than the Acebeam T27, but the same output. Or is there not enough difference?
UPD: fail, i forgot
Quote:
at most 75 mm head diameter
Also i can not find Convoy L21A, only L2 here.
Agro
Agro's picture
Xeen wrote:
Add Acebeam T28? It has a larger reflector than the Acebeam T27, but the same output. Or is there not enough difference? UPD: fail, i forgot
I don’t know what happened to it…thanks for pointing it out. Smile
