Xtar VP4 Dragon - mah charge\discharge bug in test mode?
4 posts / 0 new
skroober
I’ve noticed some of the channels randomly show that charge capacity and discharge capacity are exactly the same numbers. The past two times I noticed it was channel 4. One time I caught it, the charge rate was at 99% and showing something like ~3063 mah and then it jumped to 100% directly after and was ~3103 mah, which was exactly what it displayed as the discharge mah.
Any one here experience this?
This Amazon review also describes it.
Got mine from illumn so pretty sure it isn’t a fake.
SKV89
Last seen: 9 hours 21 min ago
Yea that happens on mine too. But usually the charge and discharge capacity is very close anyways. Whatever it is, I just use the discharge capacity on the screen. This is the response I got from Xtar several months ago.
XTAR wrote:
Thanks for the feedbacks of XTAR Dragon VP4 Plus.
Regarding to the problem described in Amazon, theoretically, the charging capacity should higher than discharging, and there is an error range in 5% when using, something like refuel the car, it shows 500 miles to empty when full fueled, actually maybe runs 500 or 490 miles.
Please feel free to contact us for any questions.
skroober
After looking at a few of the pictures I took of the issue, it seems the charge capacity is usually listed as higher than the discharge capacity, so I’ll just go off the discharge capacity when this happens. Not a huge deal I guess but kind of annoying. Though I wonder if maybe the discharge capacity is actually more useful anyway.
Thanks
SKV89
Charge and discharge capacity having the same reading occur about 15% of the time from my experience. You need to go off the discharge capacity because that is how much you will get when you use it in your device (e.g. flashlight) that will be discharging the cell.
