Lii-402: Same way to fix the high cut-off voltage?
4 posts / 0 new
Flashmckenzie
Last seen: 11 months 6 days ago
As many of you know, the Liitokala chargers are very budget-friendly chargers but they bring a little too high cut-off voltage while charging (around 4,22-4,25V) with them.
Following this thread I already fixed this at my Lii-100s. Now that I have ordered a BLF Q8 and need to charge more batterys, I’m wondering if you can do the same mod on the Lii-402? Some users say it has the same charge voltage as the Lii-100. Has anybody disassembled the charger already and is able to help me?
Thanks!
Edited by: Flashmckenzie on 11/13/2018 - 12:17
d_t_a
Last seen: 3 hours 27 min ago
I tested a few pieces Lii-100, Lii-S1, Lii-202, Lii-402.
Using a low-resistance battery (eg. VTC5/VTC6) and then charging only 1 battery at a time, then as fast as is possible (I have to manually check when the charger has just charged the battery to “full”), then immediately remove the battery and test the voltage with a DMM (using a Fluke 117).
Lii-100 and Lii-S1 : (I’ll have to find my notes, but I remember they tend to charge at a higher voltage, somewhere from 4.22-4.24v)
Lii-202: Left slot: 4.169-4.185v Right slot: 4.203-4.219v (comment: the left slot is always below 4.20v, while the right slot is always a bit higher than 4.20v)
Lii-402 #1: from left to right: 4.206v – 4.214v – 4.208v – 4.214v
Lii-402 #2: from L to R: 4.211v – 4.228v – 4.211v – 4.211v
Based on my limited samples and experience, the Lii-402 and Lii-202 overcharges less than the Lii-100 or Lii-S1.
Barkuti
Barkuti's picture
Last seen: 1 day 14 hours ago
Do you really think 2 - 3 centivolts is that much of a big deal?
If you do really care about cell cycle life you should reduce the maximum charging voltage quite a bit more, as much as well below 4V (14/15 Vmax or 3.92V for 4.2Vmax cells) for maximum cycle life.
There are slot Vout resistor divider mods available for the Lii-100:
How to fix high charge voltage in Liitokala Lii-100 and how to make lower charge currents
Also, DC/DC CC/CV modules are super cheap and readily available at eBay/AliExpress and other sources.
Cheers Party
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
Muto
Last seen: 7 hours 34 min ago
Y’all crack me up with the “within/over spec” thing.
Do the math on battery cycles and you will probably find that you will not hit the 500 cycle mark of most batteries before you get rid of them or not use them near as much because new technology will make them an also ran.
You will be buying the latest greatest before the life of the battery is used up regardless of whether it is charged at 4.25v or 4.15v
And testing the voltage 2 seconds after it comes off the charger is just silly. The battery needs a few minutes to settle before an accurate repeatable reading should be made.
And within 10 seconds of firing up your favorite flashlight it will be below 4.20 volts anyway, Big deal, no really.
Life’s short and the Reaper doesn’t take a day off so enjoy every day now Smile
Peace out,
Keith
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
