Hi all,
I am new to the world of flashing driver.
My first attempt was flashing a ToyKeeper BLF A6 firmware on BLF A6 A17DD-L FET + 1 driver.
Since I don't yet have the proper hardwear, I am using Arduino board to flash the driver connected to the MCU using soldered wires.
While connecting to the Arduino everything works perfectly and also when I only use the arduino as power supply (only GND and 5V connected).
But when I disconnect everything and try to use a 18650 as a power source, nothing works - the LED is not turn on.
Voltage between terminal is 4v.
Do you have any advices?
Thanks
Flashing driver using Arduino
Wed, 11/21/2018 - 17:48
#1
I hope you connected positive and negative correctly. Check the voltage at the Attiny then – perhaps the schottky diode is defect. You might also have left a solder bridge somewhere. Check all pins against ther neighbors for shorts.
BLF Q8 Janus --- Emisar D4 RGBW
Convoy S2+ Multi Color --- Convoy S2+ Multi Color 18500 Shorty
6th Annual Light Contest Entry --- 7th Annual Light Contest Entry
Connection is correct
It is 4v, shouldn't it be same as terminals?
What should I check?
No shorts, pin 3 and 4, are shortly beeps and also 7 and 8 but it is the same with my other (new) driver
My FW repository
My BLF/OL contest entries: 7th | 8th | 9th | 10th |
The voltage at the Attiny should be about 0.3 Volts less than at the cell due to the diode. You might have disconnected a pin of the Attiny when you unsoldered the wires. Or it might be fried but they are pretty tough.
Difficult to say what more could be damaged, perhaps if you post a picture.
Do you flash right fuse?
Forgot my pen
Thanks Mike,
I think it might be the diode.
I didn't desolderd the wires from the MCU, I keep them soldered in order to continue practicing flashing code. I only disconnect the wires from the Arduino board when connecting to battery.
I didn't notice the diode is in series to MCU, so when connecting to Arduino 5v I connected id directly to pin 8
My FW repository
Actually I don't know, the code sayes:
But I can't find where it is burned to the MCU
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/view/he...
My FW repository
After some reading in the Attiny Datasheet and other sources about the fuse, mrheosuper was correct and the problem was in the fuse settings.
In case, someone will have the same problem in the future:
The tutorials on the web for flashing MCU using Arduino include burning bootloader. During the burning of bootloader the fuse is also burned.
In order to use the same fuse settings as toykeeper set the BOD to 1.8v and clock to 4.8 MHz internal (under tools menu at the Arduino IDE).
Thanks mrheosuper for the Tip.
My FW repository
