Astrolux S43S NW Test Results
39 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 1 day 5 hours ago
It would be nice if Atmel came out with a new MCU that could still run existing software, but had a way to use an external temp probe. That would solve so many problems. Get rid of the lag, much better temperature control.
Tom E
Tom E's picture
Last seen: 25 min 37 sec ago
You could add an external temp sensor on a 85, just that it will take an I/O pin. Currently on the FET+1's using internal voltage divider, there's a spare pin even with a switch LED. Of course I'm say'n this like I've done it, but actually I'm not familiar with what temp sensors are out there and exactly how they work. I thought though there are ones more reliable that don't need calibration. Thought Richard had it working, Led4power for sure, dunno how well they work though.
led4power charges €0.20 (23 cents) so pretty cheap.
Theodore41
Last seen: 1 day 1 hour ago
I finally tried to measure intensity of a S43S,which I have some months before,and took only 4500cd,measured at 7.6m.The light however seems to be very strong,my eyes hurt.
The meter was a cheapy HS1010,the one which is two pieces with a cable between.I tried a second time with a Dr.Meter luxmeter,but I found about the same,ie 4600cd.
I think it is too low.Any suggestion?
Tom E
Tom E's picture
How are you doing the conversion from lux to candela? should be:
  candela = lux * 7.6 * 7.6
Also according to the NEMA/FL-1 standard, you should used only the max reading, highest # you encounter - no averaging, no typical, but the max. Should be after 30 secs but I know I cheat a bit on that rule - I don't time it, but takes me a while of hunting to find the highest reading.
Theodore41
I go to this site, https://www.rapidtables.com/calc/light/lux-to-candela-calculator.html, put the data and voila.Also,I press the max button.
Tom E
Tom E's picture
K, did a simple test on that site and #'s look good. Dunno - forgot what I got for throw, don't have the #'s offhand. Not sure what others measured offhand either. Could you be off by a factor of 10? I usually used my meter in 10's, or 100's for my big (mostly custom) throwers, but that's at 5 meters.
JasonWW
JasonWW's picture
So you measured about 78 lux at 7.6 meters and got 4500cd or 134 meters of throw?
What led and battery are you using?
Banggood says the XP-G3 version does 184 meters. Nichia will be less, of course.
I never measured the throw on my nichia version. I consider it a short range light.
Tom E
Tom E's picture
I checked my numbers. I have a S43S with 219C's. After my tweaks I measured 8.75 kcd on a 30Q cell. I noted I got a 7.1% bump in lumens from stock with the tweaks, so the bump in kcd should be about the same. Tweaks were sanding/grinding down the bezel, better springs - not sure what else.
