Second Generation Silver Plated High Current Beryllium Copper Springs and 95+CRI SST20!
696 posts / 0 new
shirnask
shirnask's picture
Last seen: 10 hours 59 min ago
Unloco wrote:
Unloco wrote:
I have used it at around 200-220C but I think the max temp is 400C.
In a few hours, when I return to my home I check it.
Confirmed. Maximum 400C.
djozz wrote:
So how do you like that hotplate? It looks very small and convenient, I almost bought one. What time does it take to reach the set temperature?
I like very much. Since I have it, I have not failed any led reflow.
Room temperature 27C (air conditioned).
Hotplate initial temperature 33C.
Delay until reaching the set temperature (218C) 10:44 minutes.
Thanks, I have been thinking about this unit for several months, you just convinced me – ordered
Tom E
Tom E's picture
Last seen: 53 min 49 sec ago
It's the best price as well on Ali. Others may list it cheaper but charge almost as much for shipping.
Bob_McBob
Last seen: 20 hours 45 min ago
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 22 hours ago
BTW guys, I’m going to order the 3000k LEDs at the same time as the springs.
Who would like additional 3000k LEDs?
If I could actually order 250 LEDs, I could actually make them a bit cheaper than 1,50$USD/pcs.
I’m also still looking at the SST-20 4000k.
netprince
Last seen: 4 hours 39 min ago
Sure, I’ll take 8 of the 3000k if its not too late… I haven’t signed up for any of them yet I dont think…
BlueSwordM
No prob. You weren’t added to the list.
The list has been updated:
https://docs.google.com/spreadsheets/d/18SyWGP08EpK5OOcv1vZbLokQGv1KojNW...
Anybody else?
MikeMacD
Last seen: 2 months 49 min ago
BlueSwordM, add 20 of the SST-20 3000k to my order (line 47) if that helps.
AEDe
AEDe's picture
Last seen: 9 hours 56 min ago
What is the current price of 3000K with fee ? Is it cheaper than at intloutdoor?
BlueSwordM
Currently?
If you order with the springs, yes.
Otherwise, since you pay for shipping, it’s not really worth it if you buy a small quantity of LEDs.
So, in your case, since you have some springs, then yes, it will cheaper, even with the fee, compared to Intl Outdoor.
AEDe
AEDe's picture
Thanks. So 3500K 3000K can be shipped with springs.and 4000k will be later.
Then I am in for 20pcs 3500K and 20pcs 3000. and no 4000K if possible.
BlueSwordM
Excellent.
I’ve added you all to the updated list:
If I actually manage to find a good source of 500 SST-20 4000k, then we are golden Smile
Tom E
Tom E's picture
Dang Blue! I finished a ROT66 LED swap to your 3500K's from the 219B's and am very happy with it. Kcd is up 50% and got a slight bump in lumens as well, and really like the tint! Side by side with an E07 with their SST-20 4000K's and it's quite a difference - the 3500K's got that rosy touch while the 4000K's seam to have an something like an aqua blue. I thought the E07 looked really good before this side by side comparison.
Thanks Again!!
Other notes: swapped the stock teflon short LED wires with silicone 18 AWG longer ones to allow re-programming, and removed the inner spring of the driver spring and added in a short 22 AWG bypass. I left the dual springs in the carrier as-is for now.
BlueSwordM
That is excellent!
Also, you got a 50% improvement in throw? That’s honestly extremely good for a very high CRI emitter swap.
I’d honestly love it if the SST-20 were available in a dedomed variant.
Actually, it would be the absolute throwiest high CRI emitter.
I do wonder now how the 3000k and 4000k would look, especially since the 3000k at the distributor is under the BBL too.
netprince
I used the last 4 of my 3500k leds tonight. Installed them in a triple, accidentally busted one of them. The tint is very nice… Thanks for making these available.
BlueSwordM
You’re welcome, but how did you bust a single LED?
I’d like to know. Smile
shirnask
shirnask's picture
Please add 12 3000k SST-20’s to my list.
Thanks
netprince
I do not have the proper equipment for reflowing electronics, and so I was using the stove set to a low setting. I usually have no trouble doing single led boards, but multiple led boards give me more trouble. That combined with being a bit impatient while trying to clean excess solder from around the LEDs, and I just clipped the corner off one…
Getting a hot air gun or a regulated hotplate is on my long term wishlist…
BlueSwordM
Well, at least, if you want a triple SST-20 3000k build, you know where to look.
I actually have one triple 20mm MCPCB left, so I can build a triple LED array with my hotplate setup pretty easily.
netprince
Do you like your hotplate setup? What is it? I seriously need to figure something out sometime in the future…
I really like the jaxman e2l as a host, and it requires very delicately reducing a 20mm triple board down to about 18mm without shorting the + or – to ground. Its a pain but I enjoy the end product. (and mostly enjoy doing the work too)
Tom E
Tom E's picture
Ohh, I did end up ordering the one Unloco linked: https://www.aliexpress.com/item/UYUE-946-1010-LED. It's the best price on Ali for this model. Talked to my EE friend at work and he thought it was a good deal as well. Thanks everyone!
BlueSwordM
Yep.
Hotplates are a godsend, especially if you have a stencil.
For components that have low thermal mass, it makes it so easy to just reflow, slowly raise the heat, and the part is soldered down.
For high thermal mass parts, like springs on tailcaps/drivers, or parts very sensitive to heat, using a hotplate can be very useful to preheat the part and solder it using a soldering iron.
Heck, to make my job even easier, I use SnBi solder paste, since its very low melting point is perfect for stuff that should never get close to 100C, like springs and low power builds, making the job that much faster too.
Also, is there someone who would like a triple 3000k/3500k build on an MCPCB? I have one left that I can use for this.
woodlandSerenade
Could you add me to the list for 15 of both the small & large springs? Thanks!
BlueSwordM
No problem.
Added to the list.
Tom E
Tom E's picture
Just used 4 of the small springs on a mod of the infamous "TESLACOM" flashlight. There was a 1/2 price deal on Amazon for it. First I thought it was a junker, umoddable, cheaply made, but ended up getting it apart and could see a couple things about it could be fixed up, one of which is better springs.
This is it, but I only paid $18: https://www.amazon.com TESLACOM. Beleive me it's not worth $37, not even sure if it's worth $18.
BlueSwordM
God this light looks bad.
It could be so good too.
N4 SST-40 5000k, BeCu springs, 5A buck driver, nice good fins, a good 5 mode UI with moonlight but that would cost a large part of the profit margin.
BlueSwordM
So, I’m going to start sending PMs by Tuesday to the people in the final list:
https://drive.google.com/file/d/1VcHKmXf6AHm4PAtF_xA2_l3GcE8vmx5t/view?u...
So, if anybody wants to get on the list for the springs and 3000k LEDs, now is the time.
Unloco
Last seen: 1 day 20 hours ago
BlueSwordM wrote:
… 3000k LEDs, now is the time.
Please add to my order 6 × 3000k leds.
I am in line 43.
BlueSwordM
moderator007
moderator007's picture
Hey blue, did you change your paypal email for payments? Just checking to be sure?
BlueSwordM
No, I didn’t.
Why?
