Sofirn SP33 New Version XHP 50.2
YouTube link:
Hello my friends today I’ll share with you about upgraded version flashlight Sofirn SP33 use Led XHP 50.2
The box design is quite simple and beautiful not much information is printed on the box.
Inside the box is a letter of thanks from the manufacturer, a user manual, 2 spare O-ring, a lanyard.
If you buy the flashlight with battery, you will get a battery and charger.
The charger that comes with flashlight is well finished, with a charging current of 0.75A.
Sofirn SP33 by adopting the Cree XHP 50.2, it emits a maximum output that exceeds 2500 lumens and a beam distance over 217 meters.
The button is placed on the body of the flashlight with the battery backlight on when the first flashlight is on.
Side switch displays Green if remaining battery power is >50, Yellow if remaining battery power is 20–50, Red if remaining battery power is <20
IX8 rated protection, water resistant up to 30 minutes at a depth of up to 2 meters.
Aluminum with type III hard-coat anodizing, provides stability when used in harsh environments.
Unfortunately glass does not AR coating, if Sofirn finish with AR coating for SP33 then the lighting efficiency is even higher.
The screw thread made very nice but not lubricated.
The flashlight are very well done. The buttons and inscriptions on the flashlight are on a line look very nice.
I like the way Sofirn caring for the small details on their products.
The flashlight body has trimmed, anti-roll when it is placed on a flat surface, with multiple cut lines and thick aluminum housing for better heat exchange.
The flashlight use orange peel reflector give nice beam. Bezel made of white steel with 3 lines cut down to help protect and destroy glass more effectively.
The flashlight bulb can’t be removed because the company has poured a layer of glue to prevent water and also ensure a stable.
The two-spring design not only makes the lamp more compatible with many types of batteries but also increases the impact and shock resistance when mounted on a gun.
Flashlights will be sold with 2 battery options 18650 and 26650, you should buy with batteries would be better.
Advanced Temperature Regulation (ATR) technology will adjust the brightness automatically when the temperature reaches 55℃ (131 °F).
Turbo mode steps down to High mode after 2 minutes. Step-down and Advanced Temperature Regulation (ATR) coexist,
avoid flashlights work too long at high temperatures will affect the life of the lamp.
Reverse polarity protection from improper battery installation. High voltage & low voltage protection, the light cannot turn on if the voltage was over 5 volts and lower than around 2.6 volts.
The Turbo will be disabled autocratically when the voltage is lower than 3.4 volts; It steps down to lower modes automatically when the voltage is lower than 3 Volts.
The weight of the flashlight is 150g not including battery, size is 37mm x 128mm is small and light to carry. Price range is 28$ easy to access for a stable operation flashlight, software interface easy to use.
I will share with you a little bit about this interface of Sofirn Sp33.
- Short click to turn on; Short click to turn off
- Press and hold the side switch to cycle through: Low→Medium→High→Low
- Turbo: In any modes, double clicks to active Turbo mode, one click to return last mode
- From Turbo mode, double clicks to active Strobe mode, double click again to return Turbo mode, another one click returns to last normal mode
  • From OFF, press and hold the side switch to enter Eco mode with 15 lumens
    Lock-out: From OFF, 4x fast clicks active lock-out; 4x fast clicks again cancel lock-out. The lock mode of the flashlight is quite strange,
    after the lock you click the light is still blinking twice at low light level. But hold tight, the light will flash 2 times then off.
    This lock mode is quite good or you can use the flash as momentary mode without unlocking.
Thanks for reading. I send you some pictures try the flashlight. Wish you find the right flashlight for your needs.
Thanks for your reviews , I like SP33 so I order the 2nd one and plan to slice dome for some throw and warmer the tint.
@vietnam reviews, that is a good review.
However, there is one thing that should be corrected.
It’s “Bezel”, not Benzene :slight_smile:
Thank you so much my friend.
You are welcome my friend. I love color temperature: 5000k
Yours was 5000K ? Mine cooler as well as latest 32A V2.
On Sofirn store have a version 5000K.
I’m not seeing it at Aliexpress
https://www.aliexpress.com/item/Sofirn-SP33-Powerful-LED-Flashlight-26650-Cree-XHP50-2500lm-Tactical-Torch-18650-Flash-Light-6-Modes/32841695782.html?src=google&albslr=230295163&src=google&albch=shopping&acnt=494-037-6276&isdl=y&slnk=&plac=&mtctp=&albbt=Google_7_shopping&aff_platform=google&aff_short_key=UneMJZVf&&albcp=1582410664&albag=59754279756&trgt=296904914040&crea=en32841695782&netw=u&device=c&gclid=Cj0KCQiAr93gBRDSARIsADvHiOqOdJ9SVbN8V42mN5xakp_KJLPEeMu_5-4dmfzta1fd1fscCt-PWS0aAnjrEALw_wcB&gclsrc=aw.ds
I don’t see 5000K in this image you posted. Didn’t see it on my Sofirn sight either. Maybe just available to Europe?
Sorry. I see it from Sofirn store on Aliexpress on 11-11-2018. Today i don’t see that.
I bought mine on 11-11. I didn’t see it or I would have bought it.
Nice to see Viet guy review. Did you do any impact resistance, XP8 water rating, durability rating. drop test from 1.5 to 2 meters? etc…… The review will be complete with defined results.
You are from Mien Bac correct?
Prefer 6500K CW version.
Some observations based on testing my light.
There is no yellow switch light. (There are only 2 leds)
You lose turbo at 3.70 volts.
At 3.4v the green light switches to red.
The flashlight bulb, or led, is easily removed, it’s the driver that is glued into place.
My version was definitely not 5000K NW, it was more of a 6000K-6500K CW.
Nice review! I ordered mine this morning from AliExpress. Can’t wait for it!
