Circumference of 3D Maglite
I don’t have one handy to measure but need this for a project. What is the circumference of a 3D Maglite? The battery tube measured all the way around.
Thank you!
Use a scale. A few types are available. Caliper, ruler, etc… Measure inside diameter of tube( ID for short ) and Measure outside of tube ( OD for short ). Diameter is distance across body tube once tail cap is unscrewed. Depending measuring units either inches or millimeters.
According to the drawing I found here.
The outside diameter of the battery tube of a 3D maglight is 1-9/16”
That comes to a diameter of 39.7 mm and a circumference of 124.7 mm
Thank you!!
Old Lumens thread. Maglite Dimensions Thread for modders
I used it as a reference many a time. RIP
