【convoy】KY CSLNM1.FY,LH351D 3500K / 2700K available
3917 posts / 0 new
Simon Mao
Simon Mao's picture
Last seen: 1 day 13 hours ago
m47mu74nt wrote:
Hello Simon,
I want to swap emitter and driver on the just arrived Z1, but can’t figure out how to disassemble the driver section?
Can you give me the right direction please?
Thx
remove the bezel ,then remove the black lid around the LED,
you can see the brass pill inside.then take it out
m47mu74nt
Last seen: 1 day 12 hours ago
Perfect ! I wasn’t sure the pill could unscrew from the top ! (sadly I tore the o-ring of the zooming part when reassembling …)
Simon Mao wrote:
remove the bezel ,then remove the black lid around the LED, you can see the brass pill inside.then take it out
1stein
1stein's picture
Last seen: 7 hours 18 min ago
m47mu74nt wrote:
Hello Simon,
Thx
Screw off the front lens and zoom out (wide Ray) . The rotating head must be crewed down, it comes off through the back of body.
Simon Mao
Simon Mao's picture
pls leave me your email address via PM, i will take time to record a video
helicoil
helicoil's picture
Last seen: 3 weeks 3 days ago
Nice beamshot comparison featuring Convoy’s new L21A CULPM1.... (link to original post on Baidu)
2 examples
1. L21A against the Acebeam L17.....
2. L21A against the Amu XT45 with SBT90.2
With a thankyou to the Baidu FC and the poster G_w_t_F.
Thanks,
Martin
hasddie293
hasddie293's picture
Last seen: 1 day 7 min ago
At what point should culpm1 consider optimal distance? If you look the picture above, you see its beam small vs xhp35 and sbt90.2 which apparently much wider range, but those distance are fall short for this culpm1 bcos closer look it has much higher intensity of light, as in the picture, I think this light should aim further to make it clear. I still wait for more beamshot from Convoy new L21A CULPM1…
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Funtastic
Funtastic's picture
Last seen: 29 min 33 sec ago
Sadly the Osram red driver is only 2.5A. It performs best at 3.5A but 3A would have been ideal….oh well
At 2.45A I get 178 lumens
At 3.5A I get 235 lumens
That’s a large difference for the red led
I’m still happy to have a driver though. At 2.45A it’s still good usable lighting up to 200m. It still gives 4 times the performance than using a red filter.
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
Artiet59
Last seen: 2 hours 21 min ago
Which light are you referring to? Or this a driver Simon sells?
Funtastic
Funtastic's picture
This entire thread is of Convoy’s torches etc, so yes, Convoy’s red Osram driver that was just added to the AliExpress store
id30209
id30209's picture
Last seen: 1 hour 38 min ago
Funtastic wrote:
Sadly the Osram red driver is only 2.5A. It performs best at 3.5A but 3A would have been ideal....oh well At 2.45A I get 178 lumens At 3.5A I get 235 lumens That's a large difference for the red led I'm still happy to have a driver though. At 2.45A it's still good usable lighting up to 200m. It still gives 4 times the performance than using a red filter.
But what about using it with SST-20DR?
WTB Titanium 4sevens 2xAA tube
Funtastic
Funtastic's picture
I don’t have one to know but the 20DR has a max current spec of 3A so you won’t see max output with this driver
I wonder how easy it is to increase the current
Artiet59
Yea I understand what the thread content is, I have not seen the driver hit the store and was looking for something similar recently. Thanks for patronizing response though.
Artiet59
In my experience (and probably most others)- the osram LED’s have a relatively smaller “spill” area then other LEDs used for throwers like the sst40, xhp35 and sbt90.. I also feel that the way the picture was taken (looks like from elevation off of the ground), that the spill area on both LEDs are not really apparent and we’re only seeing the hotspots. This new(?) osram CULPM1 should technically have the largest spill/lumen output of all the osram emitters though. I found the release of this flashlight, especially with an 8amp driver, very exciting! I’m not a huge fan of small spill throwers but I will buy this convoy, because I believe the spill area will be sufficient. I know the W2 in my KR1 has sufficient spill so this L21a host should be awesome for this LED / driver!
rdhood
Last seen: 5 hours 27 min ago
What is the tint on the L21A CULPM1.TG ??? It looks like a great handheld single cell thrower.
Sirstinky
Last seen: 1 hour 7 min ago
They come in CW only currently, so 5700’ish k to 6500k which is totally fine for throwers.
hasddie293
I mean, should CULPM1 be consider 1 Km light contender? Not below 1 km as such the sst40 I supposed so..this is consider thrower light stage two.
That would mean, the same level as the W’s which now had claimimg 2km.
Most of led that surpass 1km, it seem they ussually had a tight beam, for its reason. Its looks tight at closer but what it really matter is in the long distance. It like buggati Veron for long distance vs gtr for short drag race. You know what i mean?
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Funtastic
Funtastic's picture
I think any led could do over 1km with a big enough reflector Silly
All of the Osram white flat’s achieve 1km+ , the CULPM1 is the brightest white of them all. Using it in the Convoy L21A at 7A I get 1350 meters but my meter gives a higher number than others so I sell it at 1250m.
If I point it just above a hill on our farm I can see the outline of it and that’s 1300m so it’s at least that much
Funtastic
Funtastic's picture
Sorry buddy, I replied at 3:30am, wasn’t meant to come out that way, I realized as I read it back but too tired to change it
Artiet59
Just ordered L21a with CULPM1 8amp ! Also ordered the m21a with CSLPM1 6a driver! By the way, my first Convoys! Can’t wait!
Funtastic
Funtastic's picture
Convoy L21A CULPM.TG or otherwise known as the W2.1 driven at 7 amps
200 meters to the trees.
Barkuti
Barkuti's picture
Last seen: 11 hours 28 min ago
I find it curious to see many of you driving these emitters quite hard. Of course this also is because how these drivers are set at, namely the newest ∅22mm 8A switching driver (very smart choice, efficient cool running driver).
Curious because we don't really have any formal CULPM1.TG tests yet, hope they are ready soon. The CSLPM1.TG peaked at 8A, and so I wouldn't expect the CULPM1.TG to peak much above 9A. But we'll see.
Sun, 10/25/2020 - 16:09
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
Artiet59
Thanks for the beam shot! Makes me even more excited to receive mine seeing it in action!
And no worries about the comment, I get being tired. Definitely no need to go back and fix it Thumbs Up
Funtastic
Funtastic's picture
Curious because we don’t really have any formal CULPM1.TG tests yet, hope they are ready soon. The CSLPM1.TG peaked at 8A, and so I wouldn’t expect the CULPM1.TG to peak much above 9A. But we’ll see.
Sun, 10/25/2020 – 16:09
6.6A is the max in the specs and 8A – 10A pulsed.
I tested it using that ramping driver from Convoy.
- 50E 3.8v 6A = 1200 ish
- 50E for 7A = 1313
- 40T for 8A = 1318
djozz tested an early chip from hank and he said his peaked at 7A, my testing confirms it. Even at turn on it didn’t go above 1380.
That’s very disappointing that it’s not really any improvement over the cslpm1
lightdecay
Last seen: 19 hours 15 min ago
djozz tested XP-G3 Photo Red. If SST-20-DR performs similarly to XP-G3 Photo Red (it probably does), it does not seem useful to push the LED beyond 3A.
http://budgetlightforum.com/comment/1683223#comment-1683223
Funtastic
Funtastic's picture
….yes, but I’m talking about the driver which is only pushing 2.5A
LTC
Last seen: 5 hours 17 min ago
Received my L21A CULPM1… I will say nothing more you can ask for with such price tag.
IMHO, the L21A CULPM1 is probably the best value for money pencil beam thrower thus far. If not, at least for now.
Barkuti
Barkuti's picture
Questions for Simon:
Let's say I would like to get a Convoy L2 smooth replacement reflector. The part is not for sale, which is weird because all other reflectors are (L6, M1, M2, M3, M21C, M26C, and so on). So, how do I order something like this? Custom order? How does it work?
Are you still offering discounts?
Thanks in advance.
Simon Mao
Simon Mao's picture
Let’s say I would like to get a Convoy L2 smooth replacement reflector. The part is not for sale, which is weird because all other reflectors are (L6, M1, M2, M3, M21C, M26C, and so on). So, how do I order something like this? Custom order? How does it work?
Thanks in advance.
I will add the link as soon as possible.
L2 has two kinds, 9mm bottom hole for 5050 and 3535 LED, 11mm bottoom hole for 7070 LED
id30209
id30209's picture
Orange-yellow Osram just showed up in store Smile
If we could get royal blue CSLNM1.14 That would be great. All colors covered
1stein
1stein's picture
Anybody knows the wavelength of this?
