【convoy】L6 GT-FC40 high CRI on sale now
4720 posts / 0 new
Caleb
Caleb's picture
Last seen: 1 day 18 hours ago
MascaratumB wrote:
I would like a 50% mode only
+1
Caleb
Caleb's picture
Chatika vas Paus wrote:
… maybe replace it with two mode group – 20%, 100%.
+1
treellama
Last seen: 5 hours 19 min ago
I definitely use ML mode a lot on small lights…but I also hate memory mode. Decisions, decisions.
texas shooter
Last seen: 5 min 14 sec ago
Simon Mao wrote:
texas shooter wrote:
Simon is there a chance for a few body tubes for the 26800 battery? Specifically for the M and L series single cell. https://www.e-cigarette-forum.com/threads/bench-test-results-queen-batte...
https://www.thunderheartreviews.com/2019/01/queen-battery-qb26800-6800ma...
26800 batteries are not very popular currently
and here is a problem.it’s hard to find a suitable charger for 26800.
Repurchasing the charger will also increase the user’s cost.
If 26800 batteries become popular, I will consider producing extension tubes,
Thank you for looking into it. As far as chargers I’m using Olight Portable Universal Magnetic USB Charger and at 750mah charging it’s an all night affair.
stephenk
stephenk's picture
Last seen: 1 hour 32 min ago
Simon Mao wrote:
jasontheguitarist wrote:
Back in march there was some talk about the 12 group firmware for the AA/14500 driver in the T2.
There was another thread here recently asking about disabling the memory on T2 driver, I don’t know if that’s possible but it’s further evidence that not everyone wants memory and that a programmable version would be great.
You said you were going to restart the plan to have this driver manufactured, is that still the plan?
Taking into account the cost and supply issues, the manufacturer does not plan to use higher-precision chips, and the 0.1% brightness mode will be removed.
The mode will be modified as follows:
  • ——————-sub-option 1.1 (normal-flash 1 time) : tap the switch to select mode group 1 (1%, 10%, 35%, 100%, strobe, biking, battery-check)
  • ——————-sub-option 1.2 (normal-flash 2 times) : tap the switch to select mode group 2 (1%, 10%, 35%, 100%)
  • ——————-sub-option 1.3 (normal-flash 3 times) : tap the switch to select mode group 3 (100%, 35%, 10%, 1%)
  • ——————-sub-option 1.4 (normal-flash 4 times) : tap the switch to select mode group 4 (1%, 20%, 100%, strobe, biking, battery-check, SOS)
  • ——————-sub-option 1.5 (normal-flash 5 times) : tap the switch to select mode group 5 (1%, 20%, 100%)
  • ——————-sub-option 1.6 (normal-flash 6 times) : tap the switch to select mode group 6 (100%, 20%, 1%)
  • ——————-sub-option 1.7 (normal-flash 7 times) : tap the switch to select mode group 7 (1%, 10%, 50%, strobe, biking, battery-check, SOS)
  • ——————-sub-option 1.8 (normal-flash 8 times) : tap the switch to select mode group 8(1%, 10%, 50%)
  • ——————-sub-option 1.9 (normal-flash 9 times) : tap the switch to select mode group 9 (50%, 10%, 1%)
  • ——————-sub-option 1.10 (normal-flash 11 times) : tap the switch to select mode group 10 (100%, 20%, strobe)
  • ——————-sub-option 1.11 (normal-flash 12 times) : tap the switch to select mode group 11(100% only)
I want to know what you and other BLFers think about this,
Or do you need to add other modes
Please make strobes 10Hz constant frequency. Not the horrible alternating strobe frequency in Biscotti.
Tartarus
Last seen: 3 hours 38 min ago
It would be nice if the primary mode was not the 1.1 with flashing , but the 1.2 without flashing. If it were to revert to default for some reason, it would not revert to the annoying flashing mode. For me, the most important thing is the ability to disable the memory.
d_t_a
Last seen: 16 hours 42 min ago
Will the above apply for the planned Convoy T2 with 12-mode groups, or will this be applied to all new Convoy flashlights that have the “12-group” firmware?
AlexLED
Last seen: 9 hours 23 min ago
Hi Simon, rather sad …. would appreciate if Convoy would continue in the “high quality” space. Wink
And I indeed would appreciate moon for AA lamps as well – even more than for 18650, because the former are more used in low-light conditions.
And of course, this would be a USP vs. many other AA lamps ! Smile
Reg. the sub-options: why is bat-check only available together with the strobe modes ??
Other than that, I prefer 1/20/100 (1.5) and 1/10/35/100 (1.2). For special cases maybe 1/10/50 (1.8). Never would use any of the other mode grps. Smile
Btw: any plans for colored bodys for AA ?
Edit: ah, and I prefer no memory, or at least be able to disable mem !
Regards,
Alex
ggf31416
Last seen: 3 hours 3 min ago
There is a global chip shortage, many companies are struggling to maintain their supplies.
Simon Mao
Simon Mao's picture
Last seen: 23 hours 20 min ago
So, now you have 11 groups. Instead removing original 10 (1, 10, 35, 100%), maybe replace it with two mode group – 20%, 100%.
ok ,good idea
Simon Mao
Simon Mao's picture
Memory is turned on by default, you can also turn it off.
Simon Mao
Simon Mao's picture
only for T2
JonnyBorneo
Last seen: 3 days 18 hours ago
Sorry to say, but I have grown tired of waiting for SBT-90.2 L6.
Time to get something else.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 4 hours 5 min ago
JonnyBorneo wrote:
Sorry to say, but I have grown tired of waiting for SBT-90.2 L6. Time to get something else.
Well, there's this saying: "Good things come to those who wait." Wink
Anyway, maybe you should have a look at WildTrail's WT90 which is meant to be launched anytime soon.
Bunbury
Last seen: 4 days 1 hour ago
Hi Simon, can you recommend which solder to use when assembling a host? What type do you use in your flashlights? Leaded or lead free?
Unloco
Last seen: 4 days 11 hours ago
Lux-Perpetua wrote:
Well, there’s this saying: “Good things come to those who wait.” Wink
+1
I’m sure it will be worth the wait.
jasontheguitarist
Last seen: 25 min 54 sec ago
Not sure what Simon uses, but I like 63/37 leaded solder. It has a lower melting point and it’s easier to work with.
Simon Mao
Simon Mao's picture
Tin wire brand “MECHANIC”
The key is the soldering iron,
T2 solder iron , The temperature can reach 400 degrees Celsius, and use use D24 soldering iron tip
Sunnysunsun
Sunnysunsun's picture
Last seen: 5 hours 18 min ago
It’s much easier if you preheat your host. A little while in the toaster oven to get it near 100c makes it much easier on your soldering iron.
darosk
darosk's picture
Last seen: 1 day 1 hour ago
How are the LH351D bins from Simon?
I’m looking at getting a couple T2’s maybe in 4000K, or 3500/2700K
My Lights (Updated: Feb 5, 2021)
stephenk
stephenk's picture
I’ve have some S2+ with 2700k and 5700k and the tints are fantastic. The 5700k has a very slight green tint but hasn’t caused any issues with photography. If you follow the Instagram link in my signature you can see some photos taken using these lights.
darosk
darosk's picture
Awesome!
g_damian
g_damian's picture
Last seen: 7 hours 51 min ago
Does S21A and S21B have the same size reflectors?
I need replacement for S21B, however in the store is only for S21A
Sari33
Last seen: 1 hour 14 sec ago
Oh no, I whished for 0.1%mode on T2 but also 0.2~0.5% should be fine
Simon for your others FW Drivers can you consider to put 3 more groups?
0.1% 1% 10% 45% 100%.
0.1% 1% 10% 35% 70%
1% 5% 20% 50% 100%.
It will give more flexibility based on the type of driver used and limit the maximum power for extend runtime.
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 4 hours 55 min ago
Can confirm that it fits.
g_damian
g_damian's picture
Thanks Smile Beer
DTales
Last seen: 1 hour 4 min ago
You could just replace the driver with another 17mm driver that has whatever modes you prefer.
Bunbury
Thanks. Do you use leaded or lead free?
adam7027
Last seen: 1 hour 31 min ago
Hello Simon,
Can I ask for an option for ordering Convoy L21A with the B4-40E tint choice of XHP35 HI on the product page? (B4-40E is currently available as a separately purchased LED, but I would like to purchase L21A already assembled with B4-40E)
Also, I would like to ask that choice for the other two flashlights (M21C, M21B).
Ma3oska
Last seen: 3 days 4 hours ago
Hello Simon,
You had 18650 and 21700 battery from Samsung, Sony… in your store. Now you have liitokala batteries. Would you offer them again? Should I wait? What happened, when you do not offer them no more? Thank you very much.
