【convoy】SFT40 LED on sale now
4973 posts / 0 new
max
max's picture
Last seen: 25 sec ago
Simon Mao wrote:
flightless22 wrote:
Simon, can you re-upload STF-70 datasheet and SFT-40 datasheet if you have it.
"SFT40 datasheet":https://drive.google.com/file/d/1wMiNLSKxaFGuwChkFbbA1t6CEMnZTm_J/view?u... "SFT70 datasheet":https://drive.google.com/file/d/1d9eumWrKmoyRcwBCc-8Npmjyd9BZM3h6/view?u...
Thank you for the links Simon.  I also googled and could not find the datasheets so these links are appreciated. I'm anxious to try these out.
 max
Artiet59
Last seen: 2 hours 37 min ago
Thanks Simon!
wow.. if you look at bottom of page #1 on both data sheets, in "applications" the first thing Luminus lists is FLASHLIGHTS. I've never noticed that on other data sheets before!
EDIT: never mind i see it says the same thing on the sst40 datasheet too...
also, looks like sft40 = 3v, sft70= 6v / 12v.
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
Sirstinky
Last seen: 29 min 36 sec ago
Simon Mao wrote:
SFT40 datasheet
SFT70 datasheet
Hi Simon, thanks for the datasheets. Can you sell us sft-70 leds also?
Correllux
Correllux's picture
Last seen: 1 hour 15 min ago
Thanks for the datasheets, Simon!  I was about to ask if you could share them again since the previous hosting links are dead.  Been very curious about the SFT40.
max
max's picture
The links are working for me.
 max
raccoon city
raccoon city's picture
Last seen: 2 hours 34 min ago
Yup, me too.
Correllux
Correllux's picture
I meant the handful of links from some weeks/months back in previous posts
darosk
darosk's picture
Last seen: 10 hours 33 min ago
What’s the advantages of these sft40? I read the data sheet but I don’t know what to make of it.
My Lights (Updated: Feb 5, 2021)
Funtastic
Funtastic's picture
Last seen: 2 hours 55 min ago
Factory dedomed SST40 which gives a good increase in range
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Tater Tot
Last seen: 1 week 9 hours ago
Any chance of warmer color temperature like 5000k or 4500k SFT40 being available for sale?
darosk
darosk's picture
Thanks!sounds good.
How about that fct40? Edit: I meant fc40
djozz
djozz's picture
Last seen: 41 min 29 sec ago
If this follows what happened to the SST40, here may be a 5000K at some point but not lower, and only low CRI versions.
ferrat_val
Last seen: 36 min 56 sec ago
I really enjoy the balance between flood and throw in SST40. I guess SFT40 will be a bit floodier than CULPM1, but I wish someone post a beamshot comparison.
EasyB
Last seen: 44 min 51 sec ago
Looks like the SFT40 has 4 bond wires. Not sure I’ve seen that before; a bond wire at each corner of the die. If that is the case that should mitigate the burning bond wires failure mechanism of the SST40.
Funtastic
Funtastic's picture
Thought that was only with the SST40 Gen 1?
Simon Mao
Simon Mao's picture
Last seen: 57 min 43 sec ago
Sirstinky wrote:
Simon Mao wrote:
SFT40 datasheet
SFT70 datasheet
SFT70 LED will not be available until next year
Simon Mao
Simon Mao's picture
I have put forward this suggestion to the manufacturer, but I think it is difficult to implement.
ggf31416
Last seen: 9 hours 19 min ago
Is the SFT40 LED going to be available for the Z1 and other flashlights?
EasyB
I don’t know, maybe later versions are tougher. Even when they did fail by burned bond wires it was at >8.5A, so it was usually not a problem, but it will still be nice not to worry about that failure mechanism.
scotlarock
Last seen: 1 hour 30 min ago
Does the SFT40 fit standard XML mounting stars (MCPCB)?
max
max's picture
I just ordered mine and don't have any on hand, so I can't say for 100% positive.  However, the pdf datasheet shows the die size as a 5050 which is the same as Cree XML.
 max
Sirstinky
Simon Mao wrote:
Sirstinky wrote:
Simon Mao wrote:
SFT40 datasheet
SFT70 datasheet
Thanks Simon. Will be looking forward to that one!
Scallywag
Scallywag's picture
Last seen: 15 hours 20 min ago
The SST40 does, so this should as well.
Simon Mao
Simon Mao's picture
yes,
Simon Mao
Simon Mao's picture
yes
Simon Mao
Simon Mao's picture
26800 extension tube for M3-C sample
texas shooter
Last seen: 19 min 50 sec ago
Thank you Simon. When might we see them for sale?
Artiet59
Ordered 5 sft40 leds today, oh do I have plans for this LED!
Simon Mao
Simon Mao's picture
i’m ready to produce silver / red / blue / gold version ,
i’m finding 26800 7000mAh battery with good quality
texas shooter
Could you please list some of the 26800 batteries and sources you’ve discovered. Also please consider Black as one of the colors.
