【convoy】219B R9080 TEST
5862 posts / 0 new
Simon Mao
Simon Mao's picture
Last seen: 8 hours 24 min ago
JaredM wrote:
Simon Mao wrote:
Post#4877
SFT70 LED will not be available until next year
Is there any updated or more accurate info on this emitter becoming available?
There is currently no relevant specific information
Rusty Joe
Rusty Joe's picture
Last seen: 9 min 51 sec ago
Does the GT-FC40 in M21C have good throw and beam rendition?
Rusty Joe
Rusty Joe's picture
Also, can all Convoy L6’s be run on 2 × 26350s in shorty mode?
id30209
id30209's picture
Last seen: 34 sec ago
Oh yes...
WTB Titanium 4sevens 2xAA tube
id30209
id30209's picture
Rusty Joe wrote:
Also, can all Convoy L6's be run on 2 x 26350s in shorty mode?
Yes, I have one Smile
stephenk
stephenk's picture
Last seen: 1 day 8 hours ago
Yes, there are a couple of real world photos in my review – see link in my signature. The light is half way between being floody and throwy.
Pyrokiwi
Last seen: 8 hours 27 min ago
Simon, did I see you are working on a larger cutout reflector for the M21B?
I just received my S11 GT FC-40, and love it. I would like it even more in a single 21700 host like the M21B though!
zoulas
zoulas's picture
Last seen: 9 min 5 sec ago
ZILZAL wrote:
Hi Simon,
Few hours ago i received my new C8+ CSLNM1 and M21A CULPM1, unfortunately the M21A LED is not centered correctly cry
I had a similar problem on another convoy light with osram. IMHO that light you have is capable of 1000m throw. Shining it on a wall just 10 feet away with produce artifacts from the lobes. When I took mine outdoors, The distortion all went away or was impossible to detect. Again, IMHO there is nothing wrong with your light. The Osram led is less forgiving than say an XHP70.2.
Simon Mao
Simon Mao's picture
M21B reflector for XHP70.2 and FC40 is in production
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 52 min 52 sec ago
Simon Mao wrote:
Pyrokiwi wrote:
Simon, did I see you are working on a larger cutout reflector for the M21B? I just received my S11 GT FC-40, and love it. I would like it even more in a single 21700 host like the M21B though!
I wish that was also available in S16. This is on the wishlist for my next order… Love
S16 or M21B with SFT-40 5000K/6500K (8A constant current driver)
S16 or M21B with FC40 3000K/4500K
S16 or M21B with XHP70.2 4000K
… plus some more of your great flat top adapters for 3X21A and 4X18A.
Tom E
Tom E's picture
Last seen: 12 hours 47 min ago
Received the 3X21A SFT-40 model today from Simon - Thanks! Posted some first  impressions here: https://budgetlightforum.com/node/78424
Tangra
Last seen: 17 hours 2 min ago
L6 can not work with 26650 without additional 5mm magnet spacer.
Can Convoy make any flashlight without bug, or you get what you pay for?
Kit Latura
Last seen: 6 hours 19 min ago
Tangra wrote:
L6 can not work with 26650 without additional 5mm magnet spacer. Can Convoy make any flashlight without bug, or you get what you pay for?
I think you should have more respect for one of the few people who has always cared about our community.
Simon does not deserve a comment like this.
Yokiamy
Yokiamy's picture
Last seen: 1 day 5 hours ago
Simon, are you planning a S21B with GT-FC40?
cothyhu77
Last seen: 4 days 5 hours ago
This was asked a few pages back:
Simon Mao wrote:
ch1ir wrote:
Simon will the GTFC 40 be offered in the s21? Also will the sft be offered in warmer tints? Thank you as always
The size of the S21 flashlight is too small. If the FC40 LED is installed on it, the heat will be too large, so I have no such plan.
At present, the factory only produces the 6500K version of sft40. I have not heard that they have plans to produce medium white light and warm light.
Simon Mao
Simon Mao's picture
… plus some more of your great flat top adapters for 3×21A and 4×18A.
I worry about the heat……
zoulas
zoulas's picture
I am using L6 with 2×26650 W/O any problems.
Simon Mao
Simon Mao's picture
Because the flashlight must be compatible with 65mm to 70mm batteries, if you use 65mm batteries. It will be significantly shorter, and now I provide the corresponding accessories.
26mm PCB board for series connection
zoulas
zoulas's picture
Simon Mao
Simon Mao's picture
It’s not difficult to produce corresponding reflector. I just worry about the heat.
id30209
id30209's picture
Simon Mao wrote:
It's not difficult to produce corresponding reflector. I just worry about the heat.
1S 6V 3A driver runs well my S21A with xhp70.2.
Heat is quite good on medium modes and of course it gets hot on 100% but regulation steps down accordingly.
FC40/XHP70 reflectors for M21B, S16 and S21 would be awesome.
Also XHP50.3HI 90CRI is coming
https://hr.mouser.com/ProductDetail/Cree-LED/XHP50D-H0-0000-0D0UH245G?qs=ljCeji4nMDnxlRN1Ckk1mw==
Simon Mao
Simon Mao's picture
This requires customized drivers. For example, turbo mode needs to be turned on by double-clicking the switch, and the working time will not exceed 30 seconds.
Tom E
Tom E's picture
Heat can be managed in a couple ways. Either by amp limiting in the driver design (permanent), or a driver design that gives you the best of both worlds:
  • support max amps via a direct FET channel, or amp limited depending on the emitter used (ex: linear regulated)
  • smart thermal management, as implemented in Anduril or Anduril 2
It may require high quality springs, or double springs, or bypasses.
This is why a few of us have been mentioning an Anduril or Anduril 2 option because you can get the best amps a LED supports, but with the safety of true thermal regulation/management by limiting the max temperature via an MCU internal sensor, or external sensor.
I would like to see more aggressive thermal fins on some lights as well. For example with the new 3X21A, there are many fins in the proper area but they are too shallow - they need to go deeper into the body, and if they did, it should reduce the weight as well -- another advantage.
Less aluminum mass if possible, more surface area -- good goals.
id30209
id30209's picture
Not at all. Your drivers are perfect for it (6V/3A and 12V/2.5A)
Tangra
Sorry. L7. And it does not have spring from driver side.
zoulas
zoulas's picture
Ok, no spring then fuggetaboutit.
Tangra
Rear spring is very small.
Actually, this model is springs-free!
Di_Joker
Di_Joker's picture
Last seen: 10 min 22 sec ago
Simon Mao wrote:
3*XHP70.2 is in design now
Any news about Convoy 3×21A 3*XHP70.2? When will it be available?
Sorry for my poor english.
Champfc3000
Last seen: 6 hours 53 sec ago
Any update on l7 26800 extension tube?
texas shooter
Last seen: 7 hours 45 min ago
Simon, if possible I’d like to request you to make a special run of 2-26800 tubes for your L series. Maybe a sample run? I now you’ve stated that you’ll be making extensions, however a few may prefer solid one piece tubes. Part of the Convoy success is you make a very solid product.
