【convoy】M21G XHP70.3 HI 2*21700 flashlight available
8637 posts / 0 new
Simon Mao
Simon Mao's picture
Last seen: 16 hours 51 min ago
dropman wrote:
Am I the only one who dont understand how new “ramping” firmware works? Can someone explain? Light starts in max mode. Then two taps brings 1.5A mode, and 3 taps brings strobe (or anything else from function mode selection)? I though ramping is stepless selection of brightness, but maybe I dont understand something…
that’s easy ,first ,turn on the flashlight,second ,tap the button 5 times,then you can enter into ramping
Simon Mao
Simon Mao's picture
x-ray wrote:
Normally ramping works by holding down the power button, light will “ramp” from minimum to maximum brightness, once at maximum it goes in the reverse direction max > min.
You simply let go of the switch when desired brightness is reached.
this operation is for side button ,but this is tail button ,so it’s different
Satan@103TFS
Last seen: 1 week 4 days ago
Hi Simon ,what about XHP50.2 6V and 3V in 5000K range ?
mortuus
mortuus's picture
Last seen: 1 day 8 hours ago
Simon Mao wrote:
Satan@103TFS wrote:
Looking good any C8+ 21700 soon ?
in production now ,about one month
what about s2+, also in production ?
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Convoylover
Last seen: 11 months 2 weeks ago
S2+ 21700 is the most interesting to me! Will it be available in various anodization colors like the normal S2+?
andr3w
Hi Simon,
Could you please tell if the new Convoy S11 will have 12 mode groups (like current S2/S3 models) or similar?
In general I want wide selection of low light modes, so such a mode groups is a very nice option.
Lightbringer
Lightbringer's picture
Last seen: 20 min 44 sec ago
Actually, please please please please please if there are variations in the S2+, can we not call it an S2+?
Just like the Sofirn SP10, where there was the original, the A version, then the B version, then the colored-B-version which was the same as the renamed-black-A-version, with tweaks to the UI (so original UI, new UI which became the older UI, then the new UI, …) and nobody knew what they were getting until they actually received the light.
Different styles, different knurling, different battery-tube, etc., let’s call it something different?
And please, not just an ‘S’ suffix, which drives me buggy when someone would write “18650S” and you have no idea if they mean more than one 18650 cell or the Folomov 18650S flashlight.
Whew. Now I feel better…
andr3w
I’m voting for this. It’s much easier to order with strict model/features correspondence. I’m perfectly fine even with something like “Convoy F123DG45” if it would encode all features exactly.
Delta_V
Last seen: 5 hours 58 min ago
I personally vote for calling the new 21700 S2+ version the “S21”. Plays into the 21700 battery format, and indicates that it is functionally different from the S2/S2+/S3/etc family.
Lightbringer
Yeh. And even with the S2/S2+, if they have different styling, different length, different reflectors and pills, even different threads so they’re not lego-able, it can get confusing to those who’d think otherwise. Like, “the ‘+’ just means improved”.
I’d be okay with the “S21” as noted above. Describes it nicely.
Convoylover
Fine by me, as long as it has the shallow reflector of the S2+ and not the deep reflector (which is less efficient) of the original S2.
S21+ then?
mortuus
mortuus's picture
valid points, makes sense. but its all up to Simon, hes the boss.
              つ ◕_◕ ༽つ
Quadrupel
Quadrupel's picture
Last seen: 3 hours 30 min ago
Simon Mao wrote:
To: sochi111
following one will be available in one week
max output 2500mA
0.1%moonlight-3%low-30%mid-100%high ,strobe(double-click the switch); if the flashlight is turned off ,press the side switch,flashlight can enter into moonlight mode directly.
!http://farm8.staticflickr.com/7862/46399418675_70a74b27ba_b.jpg!
So, where is it?
adam7027
Last seen: 3 weeks 2 days ago
Another important question: will I be able to use the same optics (both reflector and TIR) with S2+ 21700, which are suitable for S2+ 18650 currently?
adam7027
Quadrupel wrote:
Simon Mao wrote:
To: sochi111
max output 2500mA
So, where is it?
Maybe it is worthy to be patient Smile If Simon has already product images, we will be able to buy it soon. For me it is not a problem if it is a bit later.
zak.wilson
Last seen: 1 hour 29 min ago
Something I’m noticing with the H1 is it only has one small groove that could accommodate a pocket clip, and only in a head-up configuration. I usually prefer my angle lights head-down in my pocket, and a larger groove tends to make the clip more secure.
When it comes time to revise the design, better support for pocket clips, in both head-up and head-down orientation might be worth looking at.
Ceilingbounce – flashlight testing and runtime graphs for Android | Zak Reviews – my flashlight reviews, with lots of runtime graphs
Simon Mao
Simon Mao's picture
yes,in production
Simon Mao
Simon Mao's picture
i will get XHP50.2 3V J4-3C and J4-3A soon
each bin 500pcs
Simon Mao
Simon Mao's picture
andr3w wrote:
Hi Simon,
no ,i dont have this kind of driver
what LED do you want to be installed in S11?
Simon Mao
Simon Mao's picture
Good suggestion,i’m ready to name it “S21A”
Simon Mao
Simon Mao's picture
a little large, but i think if you dont remove the glass lens ,
the TIR still can be installed
Simon Mao
Simon Mao's picture
i thought head-down was useless, so i just add one groove.
Where do we use head-down? is there an example
zak.wilson
Simon Mao wrote:
i thought head-down was useless, so i just add one groove. Where do we use head-down? is there an example
This is for using a right-angle light as an everyday carry light in a pants pocket. Head-up usually results in a large amount of the light sticking out of the pocket, where head-down does not.
oweban
oweban's picture
Last seen: 1 year 6 months ago
So if I bump into things (read: constantly) then I’m not scratching the lens Smile
Simon Mao
Simon Mao's picture
i see ,thanks ,i didnt consider this ,i should update it in the next batch
Satan@103TFS
each bin 500pcs
What about XHP50.2 6V K2 5000k ?
zaxar0580
zaxar0580's picture
Last seen: 1 hour 34 min ago
I need H1!!! I want H1!!! Thumbs Up
oweban
oweban's picture
S11 up! Aaaaaand purchased Big Smile
clientequator
clientequator's picture
Last seen: 7 hours 13 sec ago
hello Mr Simon Mao, I see an interesting silver S2+ for 21700 size in your photo! Is this for sale yet?
Convoylover
No, it isn’t if it is not on his site. This is the 1st picture I’ve seen of it, the S21A Wink
