【convoy】GT FC40 1800-2000K R9050
6434 posts / 0 new
raccoon city
raccoon city's picture
Last seen: 5 hours 3 min ago
Gotta catch 'em all!
tactical_grizzly
tactical_grizzly's picture
Last seen: 1 hour 33 min ago
Hi Simon,
I see that S12 UV’s product listing now says 2.4A maximum where it used to say 6A before, if I remember correctly. Does it come with a different driver now?
m47mu74nt
Last seen: 20 hours 5 min ago
Hello Simon Smile
Could it be possible to list SST20-B (and some other 3535 SMT color LEDs that can be used in place of XPL White LEDs) on your store ?
Thank you!
Simon Mao
Simon Mao's picture
Last seen: 12 hours 1 min ago
bugmenot2 wrote:
Hey Simon,
  1. Any idea when SFT40’s are going to be back in stock?
  2. Also, do you have any plans for adding charging to more lights, such as the M21B?
  3. Will the Remote Tail Switch for the L21B also work for other lights, such as the M21B?
Thanks a lot for how you help the community!
1. It will be available in one week. But the Tc is 5700k instead of 6500k
2. uh ,no plan ,how about M21E? i will add a link of M21E with SFT40 / KW CULPM1.TG in two days
3. It is only suitable for L21B
Simon Mao
Simon Mao's picture
ArtieT59 wrote:
Simon,
I recieved my M21e today, such a nice light!
I installed my sft70 LED in the s21b xhp50.2 light and it worked fine on mode 1-3, turned blue on mode 4 (100% output).
I then installed the SFT70 into my m21e and it worked up until about 75% ramp, then turned blue and the light started smoking. I thought i blue the sft70..
But now my m21e wont turn on with the xhp70 in it either. I put that back in and it wont work.
Can i buy just the driver for the m21e from you?
does anyone know what i did to my driver?  i wouldve thought that just the led would burn out if anything, and i was completely OK with doing that for the sake of expirementing.. I didnt think it would ruin the driver..
 Anyway.. TIA
Can you send me some photos? I want to see how you solder SFT70 and MCPCB.
Simon Mao
Simon Mao's picture
ArtieT59 wrote:
Simon, any idea when SFT40 will be back in stock?
even for sale in your lights again -
Lights with sft40 like the m21a, m21c, or L21a?
Thank you!
Maybe in one week.
Simon Mao
Simon Mao's picture
tactical_grizzly wrote:
Hi Simon,
In fact, the drivers are the same, but this driver was originally designed for SST40 and not for UV LEDs. Because the vf value of uv led is relatively high, the current of the flashlight will be relatively small.
Simon Mao
Simon Mao's picture
m47mu74nt wrote:
Hello Simon Smile
Thank you!
SST20-B?
SFT20?? Do you mean this.
bugmenot2
Last seen: 1 month 6 days ago
Simon Mao wrote:
bugmenot2 wrote:
Hey Simon,
Thanks a lot for your help! Unfortunately the M21E is too big/wide for what I have in mind. The M21B is just perfect other than the lack of onboard USB-C charging.
Maybe others in this thread could chime in if they have an interest in additional USB-C charging lights? I do understand it’s never a simple process to redesign things, but perhaps if there’s a significant community interest and demand, we could see new lights with USB-C charging later down the road?
tactical_grizzly
Simon, I see that Pioneman K80 has been released. It appears to be identical to the thrower you are working on in this post, and I noticed Pioneman has many models that are almost identical to Convoy models. How is Pioneman related to Convoy? Can we expect the Convoy version of Pioneman K80 to be released soon? Has the low current issue with the driver been corrected? Will there be any differences between the Pioneman and Convoy versions of this light?
m47mu74nt
Simon Mao wrote:
m47mu74nt wrote:
Hello Simon Smile
Thank you!
SST20-B?
no, SFT20 is not compatible with XPL MCPCBs
I mean this :
SST-20-B Blue (450 nm) SMT 3.45 mm x 3.45 mm 3.0 A 630 – 830 mW (0.35 A)
https://download.luminus.com/datasheets/Luminus_SST-20-B_Datasheet.pdf
(and I am also looking for a green 3535 LED that can handle 3amps with pads compatible with XPL MCPCB)
thornton90
Last seen: 3 weeks 1 day ago
Hi Simon,
I have an S12 UV and I’m interested in installing one of your 8A 12 Group drivers into it. Is it compatible or would 8A be too much current?
Thanks!
Like Simon mentioned the Vf of these leds is higher than normal white ones. The 8a driver will only result in higher amperage draw if it also allows a higher Vf. Otherwise as the led heats up it will draw more and more current but not get any brighter. You can have all the amps in the world from a driver but if the vf is low it won’t flow through the led. They go hand in hand.
Scallywag
Scallywag's picture
Last seen: 1 hour 41 min ago
Hi Simon,
Thanks!
That’s… Not super clear. I’ll try.
The forward voltage of most UV LEDs is high enough (and goes up quickly enough with current) that you can’t get nearly 8A into them from a single Li-Ion cell without a boost driver. I don’t think they’d handle 8A anyway, but that’s the main issue. For this reason, to really make a high-powered UV lamp you’d probably want to go two-cell with a buck driver. There was a guy around here somewhere running a C8F (for three LEDs) with 2×18650 (via an extension tube) and a buck driver.
bugmenot2
Hi Simon,
Thanks!
Sure, power is ultimately what matters for brightness, but there can be other benefits to different hardware, such as a more efficient driver. I can’t speak as to what drivers are the most efficient in Simon’s lineup but typically running devices such as these at less than their maximum power output results in better power efficiency. That applies to both the LED and the driver itself.
tactical_grizzly
The bit about forward voltage going up as current is applied is new to me. Is that the case on all LED’s or just UV ones? What is forward voltage? Is that the same as Voltage Floor? VF is voltage floor right?
ljtyk
Last seen: 44 min 30 sec ago
Forward voltage is the voltage needed to overcome the junction bias to conduct and create light. Below Vf you get no current (aside from leakage, but that’s another issue). Above Vf you get current and light.
Look at UV led datasheet here: http://www.s-et.com/upload2/CUN66A1G_R1.0_181016.pdf
Specifically pg 4 Fig 2, you see Vf going up with higher current.
for SST20 datasheet: https://download.luminus.com/datasheets/Luminus_SST-20-WxH_Datasheet.pdf
Pg10, shows Vf going up with current as well. This is just a property of diode.
Scallywag
Scallywag's picture
As above, the forward voltage is the voltage required to push any current at all(*) through the LED. Also called Vf (the f should be subscript but many formatting options prevent that). For all LEDs, this voltage increases with current (otherwise you could have a runaway LED that drew more and more power). There’s other factors in play as I recall, like temperature. But it’s the fundamentals of why some LEDs with higher Vf (like XPL-Hi) are fine with single-cell direct drive, and others are not (Osram 1mm would fry itself).
    there is leakage current, but this is valid for our purposes
thornton90
The Vf is what drives the led to allow more amps to flow through it. You can drive leds with constant current unregulated voltage or constant voltage and unregulated current. For the latter as the led heats up it will draw more and more current until it destroys itself. Therefore the safer way to drive leds is to set a current limit and allow the voltage to be whatever it will be. For instance I have a diy 100w light that is really well cooled with a big fan and heat sink. This setup doesn’t need to be current driven I could set the Vf and forget about it. The driver is capable of delivering many more amps than the LED is using but the led will only use more amps if I increase the Vf (voltage differential across the led). Hope this isn’t confusing and somewhat helpful!
Oh and I think a lot of people are confused about how LEDs and current actually works. When you look at some datasheets for LEDs you will see that the Vf is plotted along the x axis aka the independent variable and the forward current is plotted on the y axis aka the dependent variable. This is because the forward current is dependent on the forward voltage.
funwok
Last seen: 4 hours 34 min ago
Hi Simon,
a user has reported a problem with the H1 219b TIR on reddit with the TIR optic not touching the pcb.
https://www.reddit.com/r/flashlight/comments/qmuj8v/convoy_h1_with_tir_t...
Do you have any info on that?
Beam as sold:
Beam after pressing TIR on pcb:
DTales
Last seen: 1 day 7 hours ago
funwok wrote:
Hi Simon,
More info:
https://budgetlightforum.com/node/79676
Simon Mao
Simon Mao's picture
bugmenot2 wrote:
Simon Mao wrote:
bugmenot2 wrote:
Hey Simon,
I will have another flashlight similar to M21E. The head is slightly smaller than M21E, but slightly larger than M21B. It uses the same driver as M21E.
Simon Mao
Simon Mao's picture
Pioneman is my friend’s brand.
I am going to release this flashlight, but I hope to use a driver with a higher current.
If the increase in range is not obvious, the larger diameter head seems meaningless.
Simon Mao
Simon Mao's picture
m47mu74nt wrote:
Simon Mao wrote:
m47mu74nt wrote:
Hello Simon Smile
Thank you!
SST20-B?
I mean this :
I am applying for samples from LUMINUS.
MCPCB is not a problem, I can ask the manufacturer to produce the corresponding MCPCB according to the size
Simon Mao
Simon Mao's picture
funwok wrote:
Hi Simon,
Beam as sold:
!{width:38%}https://i.imgur.com/v0btLRJ.jpeg!
Thank you so much for your feedback.
Next week I will produce some 16*1.5mm copper plates. It can be used to raise the LED position.
I can’t find a suitable TIR lens at present, and all the lenses will be much lower in height than the reflector.
m47mu74nt
Super !
MCPCB might be a problem for me : in addition to my convoys, i’m on modding wurkkos HD20 and sofirn SP40 that have non-standard MCPDB shapes
Thank you!
JaredM
JaredM's picture
Last seen: 1 hour 21 min ago
What luminus emitter are we talking about?
https://fundrazr.com/osturaband
No affiliation, just a fan.
alex64
alex64's picture
Last seen: 3 days 45 min ago
The problem it’s only with 219b or the XML2 TIR have the same problem?
icpart
Last seen: 1 hour 52 min ago
Nice I see today Simon launches new headlamp H2 with USB-C charging port. Interesting replacement of H1 but here also missing feature is magnet in tailcap.
https://www.aliexpress.com/item/1005003514653823.html?spm=a2g0o.store_pc...
Scallywag
Scallywag's picture
This is what separates Simon from others. Swift acknowledgement and response to feedback. This is excellent.
Thank you Simon.
jasontheguitarist
Last seen: 14 hours 5 min ago
Have the group issues with the 13 group AA/14500 driver been fixed yet? The T3 and bare drivers I got have incorrect groups 12 and 13. I wanted to order a couple more drivers if they aren’t still messed up.
