【convoy】M21G XHP70.3 HI 2*21700 flashlight available
8620 posts / 0 new
g_damian
g_damian's picture
Last seen: 9 hours 53 min ago
Josh V wrote:
I would like an old style C8 in that color.
me too Smile
Simon Mao
Simon Mao's picture
Last seen: 2 days 5 hours ago
Josh V wrote:
Simon Mao wrote:
Just a sample ,i will produce MAO C8+
Hi Simon, but there will be also old style C8 in MAO finish or just that sample?
This one is just a sample.
Simon Mao
Simon Mao's picture
trakcon wrote:
Simon Mao wrote:
snfx wrote:
Hi Simon, is it possible to build a MAO S2+ Triple LED with 18350 tube + TIR Lens?
i dont have 20mm carclo triple lens ,sorry
Will there be MAO S2+ 18350 tubes available?
Sorry, I don’t have this plan.
Deluminator
Last seen: 4 hours 11 min ago
Simon! Any eta on brass or copper T3? You would probably sell 50 of them on the first day. Just from this thread
Looking for Acebeam M10? PM ME
lg.tech
Last seen: 7 hours 15 min ago
Oh no, that’s bad news to me as I intended to rock it only as an 18350… Sad How about the Ti version? are you gonna produce the 18350 tube? Any update on when the Ti version will be available?
Henk4U2
Henk4U2's picture
Last seen: 1 hour 25 min ago
Second that motion Innocent
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Barkuti
Barkuti's picture
Last seen: 1 week 4 days ago
Bsrkuti wrote:
… is the T4 reflector the same size as the S2+ reflector? Or to say it otherwise, can I install an S2+ compatible TIR lens inside a Convoy T4?
About ∅20 × 12 mm TIR lens for T4, like the S2+? Can you confirm, Simon?
Thanks! Smile
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
LucasRunner
Guys, i’ve purchased a 4500K 519a S2+ a little while ago and it’s lens had a blue/turquoise reflection, i assume its the new coating color Simon is using.
I’ve made another purchase of a couple S2’s recently, two 519a’s and two copper hosts and none of them had coated lenses, did i get an old batch?
andrx
andrx's picture
Last seen: 7 hours 7 min ago
i don’t know, i have:
1 copper with green or turquoise reflection
3 old S2+ with violet reflection
LucasRunner
Funny, my S2s lenses have no coating at all
PyriteParachute
Last seen: 16 hours 2 min ago
Will the MAO s2+ feature a metal or rubber button? I strongly prefer the rubber, and I don’t want to drill out the host just to add one.
trakcon
trakcon's picture
Last seen: 2 hours 3 min ago
Agreed. I want to be able to use lighted switches in them.
tactical_grizzly
tactical_grizzly's picture
Last seen: 14 hours 31 min ago
I also strongly prefer the rubber switch. I can install a forward clicky switch under a rubber boot but not under a metal boot.
stephenk
stephenk's picture
Last seen: 5 hours 45 min ago
+1 on rubber switch. The metal switch is too sensitive and I often change modes accidentally.
alex64
alex64's picture
Last seen: 1 min 23 sec ago
Always with rubber switch. Better feel and more soft to press (ideal for me).
Simon Mao
Simon Mao's picture
I have ordered copper material, but the date of completion is uncertain.
Simon Mao
Simon Mao's picture
The date of completion has not yet been determined.
Simon Mao
Simon Mao's picture
Thanks! Smile
yes
Simon Mao
Simon Mao's picture
it should be light green coated , just not so obvious
Simon Mao
Simon Mao's picture
yes, rubber
Streamtronics
Streamtronics's picture
Last seen: 4 hours 35 min ago
I'd love to have a pebbled TIR optic inside a T2 or T3, I prefer those a lot over reflectors for very close up stuff.
trakcon
trakcon's picture
yes, rubber
Excellent. Thanks, Simon!
Thom986
Thom986's picture
Hi,
I have a little question.
I want to change a lens on a S2+ with 519A.
I’m not sure about what to buy :
- https://fr.aliexpress.com/item/1577614278.html
- https://fr.aliexpress.com/item/1005001963140993.html
Thanks.
Simon Mao
Simon Mao's picture
Thom986 wrote:
Hi,
Thanks.
i recommend bead tir lens
https://www.aliexpress.com/item/1005001973468244.html
4x18a
Last seen: 1 month 1 week ago
4×18a mod SFP55 22.000 lumens , but at the moment driver max output only 18amps = 8000 lumens . Waiting for Simon produce 80amps driver so it can max 22.000 lumens
Original
Mod SFP55
Haukkeli
Last seen: 20 hours 19 min ago
Mod SFP55
Where did you find that monster?
4x18a
Haukkeli wrote:
Mod SFP55
My friend bring it from china . This is the new version of SFH55
LunaLoves
Last seen: 2 hours 26 min ago
4×18a wrote:
Haukkeli wrote:
Mod SFP55
You don’t happen to have a URL?
Asking for a friend Innocent
PyriteParachute
Mod SFP55
At least that driver is fully regulated at top brightness, something I wish was true of the L8.
tactical_grizzly
PyriteParachute][quote=Haukkeli wrote:
Mod SFP55
Unfortunately 4×18A’s 3V driver (the one used in the SBT90.2 model which the user “4×18A” used) is not fully regulated on Turbo (see my regulation testing below). It’s fully regulated on all the other modes though, which L8 is not AFAIK.
L7 is fully regulated on all modes (see my regulation testing below), which is very impressive for the price. Not even Thrunite’s $250 TN42 V2 could manage that.
