【convoy】S21E TYPE-C 21700 flashlight available
8409 posts / 0 new
Maverick1947
Maverick1947's picture
Last seen: 4 hours 17 min ago
Awesome! Thanks buddy!
There’s no replacement for displacement.
SvenEvert
Last seen: 10 hours 5 min ago
Is there any chance of a 14500 H series?
extremesquared
Last seen: 20 hours 34 min ago
I’m looking at mode specs for the T4, specifically the low-high max 50% group.
“sub-option 1.9 (normal-flash 9 times) : tap the switch to select mode group 9 (1%、10%、50%)”
Whereas on other biscotti-like 12/13 mode lights, this is the corresponding description:
“sub-option 1.8 (normal-flash 8 times) : tap the switch to select mode group 8(0.1%, 1%, 10%, 50%)”
The discrepancy in index is due to another mode being slipped in. But where is 0.1% mode? Is that removed from the t4?
Caleb
Caleb's picture
Last seen: 4 hours 54 sec ago
Simon Mao wrote:
Caleb wrote:
For the M21D with GT-FC40, what is the actual measured current draw from the battery on Turbo?
Also, what is the measured battery voltage once fully charged in the light.
10A
4.15V-4.2V
Thank you!
tactical_grizzly
tactical_grizzly's picture
Last seen: 2 hours 59 min ago
T3 & T4 do not have a 0.1% mode. IIRC the reason is that no regulator chips could be found with high enough precision for that.
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 24 min 15 sec ago
What’s the status of 17mm boost driver?
kiriba-ru S2+ and S21a spacers are available in EU. PM me. A few details here
elendur
Last seen: 7 hours 40 min ago
Hi, do the lighted tailswitches work well with the s21a b35am driver and the 22mm xhp70 driver? I would probably upgrade the spring, but apart from that, is it compatible with those boost drivers?
BlueSwordM
BlueSwordM's picture
Last seen: 29 min 42 sec ago
Yeah, they work perfectly fine.
