【convoy】M21G XHP70.3 HI 2*21700 flashlight available
8576 posts / 0 new
stephenk
stephenk's picture
Last seen: 3 hours 12 min ago
LTC wrote:
Sorry to hear that. But pictures tell a thousand tales.
I’m a fan of Convoy. So far, I have 519A 4500K alone on S2+, M1, M2, C8+ and S12. On the S2+, M1 and C8+ with new AR Lens, they are rosy. On the M2 and S12 with old AR lens, they are very neutral.
I was thinking 2 reasons for the green you see :
1. Old lens used for S21E
2. Driven a bit too hard with 6A driver on S21E
maba wrote:
Arrived S21E with 519A (4500K) and it’s awful green, ugly batch, don’t recommend Sick
As per my review https://www.stephenknightphotography.com/post/flashlight-review-convoy-s... there is a noticeable visual difference in DUV between the 519A 5700k in the S21E with purple AR lens and S2+ with green AR lens. I would expect these are from the same batch. However, I only see this when they are side by side. Compared to my LH351D 5700k, they are both very neutral. However, I’m holding off purchasing more S21Es to see if Simon changes to using green AR lenses in the S21E. In the meantime I’ll keep using my S2+ 519A for night/urbex photography.
Also, the packaging for the S21E is not fit for purpose, with my sample arriving with a dented battery positive pole (I’ve never had a battery arrive damaged in any other light). This light has fantastic potential as a “consumer grade” light with optional battery and USB-C charging. The packaging should be adequate enough for the light to arrive intact. I would happily pay a few more $ for packaging of the quality of Sofirn/Wurkkos lights, or the gift boxes that the S2+ CSLNM1 coloured lights arrived in.
maba
Last seen: 10 hours 44 min ago
Previously I had an S2+ with the same LED from the first batch and the tint was great, only Simon put in a meaningless SMO reflector.
Kakapo
Kakapo's picture
Last seen: 1 month 1 day ago
elendur wrote:
Yeah, Simon said he would try a batch of anduril drivers, but we haven’t got any news about which hosts will be compatible. The small to medium size hosts with side eswitch would be the best candidates. It would fix all the quirks of the current ramping drivers.
In the default simpleUI mode, functionality would be very similar (simpler actually), with good, visually linear brightness ramping, good thermal regulation, shortcuts to turbo amd moonlight and lockout with excellent unlock features.
Yes, I think Simon might appreciate Anduril 2 Simple UI, it fixes most of the confusion that Anduril 1 causes!
Especially if he uses the TINY1616, which does not need thermal calibration (calibrated from factory)
NeutralFan
NeutralFan's picture
Last seen: 4 hours 12 min ago
I replace 8 of my purple AR 20.5mm lenses with the new green ones in flashlights with 219Bs, 219Cs, 519As, SST-20s, and LH351Ds.
  • With the 219Bs, they became slightly more rosy which is what I was hoping for. Though with the sw45k, I kept the purple lens since it was already very rosy.
  • With the 519As, it didn’t really matter since they were all dedomed and already rosy.
  • With the others, they became less green and/or slightly more rosy.
It was definitely worth replacing them to me!
I’d rather use my flashlight around the house than turn on the lights.
Blggg
Last seen: 1 month 5 days ago
I am also thinking about buying 519A, 4500K. Can you try taking off the glass lens and see if it might be the cause?
I’ve got Convoy lights from some 3-4 years ago and the glass lenses definitely made tint more greenish (but I didn’t rule out the fact that the greenish tint might come from the emitter itself).
maba
Without glass it continues to be green, maybe a little less but still more than the LH351D 2700/5500K mix. Sorry no photo.
prikolow
Last seen: 3 days 23 hours ago
The S21D gets extremely hot with 219B Leds.
I measured above 60 °C on the case.
Is this because of the 219B or do other LEDs have this problem as well?
How hot will the S21D get with 519A LEDs?
NeutralFan
The max temp should be the same since it has temperature regulation. Running 8 or more amps in a relatively small flashlight will heat up fast regardless of the LEDs.
The 519As are more efficient than the 219Bs (Nichia 519A), but in the end they’ll both get to the same max temp and then the driver will take over.
g_damian
g_damian's picture
Last seen: 2 weeks 1 day ago
Is T3 driver compatible with red sst-20?
captainkirk
Last seen: 11 hours 54 min ago
I don’t think so. I’m pretty sure someone else has tried it and was disappointed.
I asked Simon about it some time ago and he said there was no suitable driver for the t3 + red.
This space for let.
tactical_grizzly
tactical_grizzly's picture
Last seen: 5 hours 24 min ago
In my testing of Convoy lights, I’ve found that they have thermal regulation but only between 100% mode and 35% mode. They won’t dip below 35% mode no matter how hot they get. That’s just based on runtime graphs & how hot they feel to the touch though, so I could be wrong. It would explain prokolow’s experience though.
NeutralFan
Convoy states the S21D driver has:
  • “Temperature protection management inside,After triggering the temperature control, the current drops to a minimum of 20%”.
For the SST-40 drivers it states:
  • “It can control the flashlight temperature not to exceed 55 degrees Celsius, If the flashlight temperature is below 55 degrees Celsius, it will output full current. If it is above 55 degrees Celsius, it will constantly adjust the current so that the flashlight will not overheat.”
I have many of the SST-40 drivers and they do a great job to regulate the temp. Actually I wouldn’t mind if they got a tad bit hotter.
But regardless, with the same S21D driver, I would suspect a similar max temp would result from either the 519A or 219B LEDs.
tactical_grizzly
If that 20% thing is true, that’s a nice improvement.
I know almost all of Convoy’s lights say the 55C thing. That’s just not what I’ve personally observed on half a dozen lights I’ve tested.
I agree that 519A vs 219B in S21D should result in the same max temp.
Maverick1947
Maverick1947's picture
Last seen: 3 hours 20 min ago
Hello Simon! Do you ever plan on offering the E21 Nichia LEDs on your lights??
There’s no replacement for displacement.
merlot
Last seen: 16 hours 12 min ago
I’m pretty keen to see Anduril on some of the Convoy drivers. I would replace the driver in my M21C-U if one were available, or simply buy an M21D for the onboard charging
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 16 min 34 sec ago
Actually, you can buy the Anduril driver for the M21C-U from Hank. The one from D4v2 fits perfectly and you can make an RGB button.
kiriba-ru S2+ and S21a spacers are available in EU. PM me. A few details here
tactical_grizzly
What switch did you use? I did that same mod to an M21D with a K1 driver but I wasn’t able to fit the K1 RGB switch.
Chatika vas Paus
I had to make a custom pcb
Simon Mao
Simon Mao's picture
Last seen: 1 day 17 hours ago
what about B35AM?
tactical_grizzly
Large 3×21700 SBT90.2 thrower prototype shared on Facebook and then Reddit. It looks awesome! I hope that the Anduril 2 driver Simon said he’d work on will be compatible.
PyriteParachute
Last seen: 15 hours 7 min ago
Hopefully there is a high regulated mode like the l7. But given the use of the same battery carrier, it will likely use the 4×18a driver…
merlot
I can’t find any anduril drivers on his website, does he offer the D4V2 driver in 6V?
Maverick1947
Simon Mao wrote:
what about B35AM?
I’ll soon buy a S21A with the B35AM 4500k, but I really wanted something small with a 1800k LED in it. Something like a T3 or even a S2+, perhaps a triple E21 S2+??? That would be awesome. Btw, do you still have plans for a triple S2+??
Chatika vas Paus
This is the “secret menu” option. You have to email him.
There are no 6V drivers. Only 3V 5A, 7.5A and 9A and boost drivers 12V (idk amps)
Sirstinky
Last seen: 8 hours 19 min ago
!https://preview.redd.it/obfdhw72kwh91.jpg?width=640&crop=smart&auto=webp...!
Ahhhhhh it’s a WT90 lookalike. Yep, FET driver for sure with this. Sadly just another hotrod thrower probably. If he did a constant current channel like 15-20 amps and a FET channel for turbo I’d be all over it. Amutorch did a buck driver for the DM90 that pulls over 20 amps sp it’s possible.
Delta_V
Last seen: 5 hours 52 min ago
Doesn’t Hank have a 6V 22mm driver now for the B35AM in the new D1?
Speaking of 6V drivers, I think one of the best things Convoy could focus on next would be getting some XHP50.3 HI and XHP70.3 HI in 90 CRI. The 50.3 HI in particular would fill the niche of a reasonably throwy High CRI light. Could likely pair it with the XHP70.2 driver, since I think it can take a fair bit more than the 3A from the XHP50.2 driver.
Chatika vas Paus
Of course you’re right. I forgot about it because I don’t have new D1.
lg.tech
Last seen: 15 hours 39 min ago
Yes, please.
id30209
id30209's picture
Last seen: 9 hours 15 min ago
WTB Titanium 4sevens 2xAA tube
lg.tech
id30209 wrote:
T3 TITANIUM  AVAILABLE!!!!
5700 and 5000K gone already.
Looks like I’m gonna be waiting for the S2+ 18350 Ti.
