Dear Simon,
Is it possible for you to add the H1, H2, S21E silicone button/cap to your store?
I have many similar (10mm) button mounted lamps and there are almost no spares available anywhere.
i can add some for free in your order for free
Thank you Simon, you are great. I received them today and installed two of them in my Mateminco lamps. They’re much better than the factory ones, they avoid accidental activation in the pocket and are nicer too. You really should upload them to your store, I think a lot of people would need them.
Hello Simon, I am looking for a MOSFET driven remote switch not to loose too much brightness with the internal resistance of the long wires. is it something you can make or know someone that sells some?
thank you
Hi Simon!
I want to buy next to three flashlights from your T-series several smaller parts.
Drivers, LEDs on boards, holsters, lanyards, gaskets etc. As a part of the prices are always shipping costs, how can I avoid them summing up several times?
Do not pay after placing the order, I will remove the shipping charges.
Dear Simon,
I didn’t think it could be used on other brands of flashlights.
thank you
This requires the use of very thick copper wire.
You need a lot of strength to stretch spring-cable.
thank you
That’s why I’d like not to put all the amps though the remote wires but use a MOSFET embedded in the flashlight tail, the MOSFET being the flashlight Switch and the remote switch being the MOSFET switch
hey simon, is the T3 titanium compatible with T3 copper? Can you swap the head?
Are the T3 driver a 13 group with 100%-20% mode?
Sorry, I didn't produce additional metal parts. The threads are the same. Currently Group 10 is 20%-100%
On the T3 titanium version, there's a 13 group driver with the 100%-20% mode (on 12 Group if I remember correctly). Is it wrong on the aliexpress listing?
Ps. If the CU and Ti T3 version are compatible, consider doing a CU-Ti T3 version, I wonder how popular it would be. I would buy a T3 copper head (driver + led and gaskets) for my T3 titanium if you have it available.
Good to see that your copper S2+ beauties are back (while they last) Simon!
If I didn’t buy them with your scratch and dent sale last summer, I’d be all over these. I removed the coating on my textured copper and it turned out to be my favorite S2+ color.
I’d rather use my flashlight around the house than turn on the lights.
3) To charge the 21700 cells I want to buy I need a “dedicated” 21700 charger. Is this one good or should I pick another one? If so, any suggestions?
Liitokala lii-S2 Liitokala Lii-S2 Double slot 18650 Battery Charger – https://www.aliexpress.com/item/4000090139954.html
4) Has anyone used this retaining ring in a Convoy S21A in order to use a 17mm driver? Do you have any pros or cons in its use?
20mm to 17mm brass ring adpater for S21A – https://www.aliexpress.com/item/33023608406.html
@ Simon Mao
Do you ship batteries regularly to European countries (Portugal) or are there any restrictions or should I mention something about that when making the order?
Thanks in advance for any replies on these questions
Why not buy from Nkon, they have high quality cells from top manufacturers and chargers, it shouldn’t cost more shipping included and it will arrive faster.
Honestly, when I bought from Nkon, I paid 16€ for the 3 cells I bought and 11€ for the shipping, so…it is not the best deal for me.
For the same amount of money I can buy more things from Simon store or other AliExpress stores with the same quality.
And actually, I had things arriving faster from China (with normal shipping) than those that came from NKON.
As for the charging, I tried the Opus BT-C3100with the Vapcell T50 and it works but I’d like to have one charger just for the 21700s, while the Opus I normally use for the other cells.
I didn’t realise that shipping to Portugal was that much higher.
In 2018 it was, so I can only guess that now is even more expensive
So, shopping and shipping from AliExpress still has some advantages. And in this case, buying from Simon has even more advantages, knowing he is a reputable seller.
@ Simon Mao
Both 50E and Li-50E not very good choice for flashlight, try to find Samsung 40T . I have both 40T and 50E , the 40T is brighter than 50E 15‰
I have Litokala Li-M4 can charge all niken AAA , AA , li-po , lithium 14500 , 18650 , 26650 , 26850 , 21700
@ Simon Mao
Unless you’re chasing numbers 15% difference in max output isn’t gonna make much of a difference and I’d rather have the extra 1000mAh for longer runtime.
@ Simon Mao
Yes , he has to choose lumen or mah , I choose lumen
I've made some corrections to the mode, if flashlight is turned on,tap the switch 20 times quickly to enter into config mode.(On a visual interface,as long as you click on an option, it means that the option is selected. The flashlight has no visual interface. It flashes to represent an option, and "tap the switch in the flashing process" means to select the option.) Option 1 (normal-flash 1 time + buzz-flash): tap the switch to enter into sub-option to select the mode group,If the user has no operation, the config mode will enter option 2.
-------------sub-option 1.1 (normal-flash 1 time) : tap the switch to select mode group 1 (1%、10%、30%、100%)
-------------sub-option 1.2 (normal-flash 2 times) : tap the switch to select mode group 2 (1% 10%、35%、100%、strobe、biking、batcheck)
-------------sub-option 1.3 (normal-flash 3 times) : tap the switch to select mode group 3 (100%、35%、10%、1%)
-------------sub-option 1.4 (normal-flash 4 times) : tap the switch to select mode group 4 (1% 20%、100%、strobe、biking、batcheck)
-------------sub-option 1.5 (normal-flash 5 times) : tap the switch to select mode group 5 (1%、20%、100%)
-------------sub-option 1.6 (normal-flash 6 times) : tap the switch to select mode group 6 (100%、20%、1%)
-------------sub-option 1.7 (normal-flash 7 times) : tap the switch to select mode group 7 (1% 10%、50%、strobe、biking、batcheck)
-------------sub-option 1.8 (normal-flash 8 times) : tap the switch to select mode group 8 (1%、10%、50%)
-------------sub-option 1.9 (normal-flash 9 times) : tap the switch to select mode group 9 (50%、10%、1%)
-------------sub-option 1.10 (normal-flash 10 times) : tap the switch to select mode group 10 (20%、100%)
-------------sub-option 1.11 (normal-flash 11 times) : tap the switch to select mode group 11 (100%、20%、strobe)
-------------sub-option 1.12 (normal-flash 12 times) : tap the switch to select mode group 12 (100%)
Option 2 (normal-flash 2 times + buzz-flash): tap the switch to active the mode memory or inactive it,If the user has no operation,flashlight will enter into the last mode.
battery-check instructions:
<2.95V 1 flash,
2.95-3.25V 2 flashes,
3.25-3.55V 3 flashes,
3.55-3.85V 4 flashes,
>3.85V 5 flashes
Notice that there is no battery-check function if flashlight is powered by the 1.5V battery
@ Simon Mao
Batteries are shipped via sunyou logistics. You can order it directly ,there are no restrictions
AliExpress automatically blocked pages from the US site, and I didn’t understand why.
The grey INR18650 is manufactured by EVE Energy Co., Ltd. in China.
thank you
Sorry, I didn’t produce additional metal parts. The threads are the same. Currently Group 10 is 20%-100%
Simon, any update on the 17mm 6V boost driver and Ti S2+? Do you think it will be available around Jan/Feb?
Simon
How’s the 3×21a highter output driver plan going ?
Hi Simon. Order is placed. Looking forward to finally pay.
Hi folks and Simon!
@ folks
I have some questions for you, I hope some people can help on this.
1) How good are these cells? Did anyone buy and use them?
INR21700 5000mAh lithium battery 21700 50E – https://www.aliexpress.com/item/1005004982166747.html
2) Should I get those above or the LiitoKala?
LiitoKala Lii-50E 21700 5000mAH lithium battery – https://www.aliexpress.com/item/1005002311598364.html
@ Simon Mao
MY REVIEWS THREAD /// My Flashlight Collection /// YouTube Channel
Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Review's Blog (PT) /// OL Contest 2019 /// OL Contest 2020 /// OL Contest 2022 /// GIVEAWAYs: 1 / 2 / 3
FYI MascaratumB, the 2 battery links don’t work for me.
I just charge my Samsung INR21700 50Es in my Opus BT-C3100 charger.
Maybe it has something to do with the AliExpress page configuration?
I will try differently:
Any of Convoy’s offerings can beat Sofirn SP35 in terms of sustained brightness and runtime?
i got XHP50.3 Hi, After testing, I was ready to start producing the driver.
<2.95V 1 flash,
>3.85V 5 flashes
28A and 54A FET driver are in stock now,but the new flashlight host is still in production
pls tell me the order number via PM
