【convoy】219B R9080 TEST
5990 posts / 0 new
jasontheguitarist
Last seen: 1 min 48 sec ago
Mark Piezó wrote:
BlueSwordM wrote:
@Mark Piezo, I wouldn’t risk it.
I would get this driver instead:
https://www.aliexpress.com/store/product/17mm-Driver-for-SST40-4-modes-0...
Same firmware, but lower current.
Thank you! If I understand right there are two version of this driver – 5 and 6 Amper. Yes? You recommend me 5 Amper version for SST-20 HCRI.
How to get this driver WITHOUT memory? I love to start from first mode always!
That’s the problem with Simon’s new drivers. No options like mode groups or memory toggle. After using the Biscotti drivers in his lights, these new drivers are a major step down in UI. The only advantage is the higher current.
If you want no memory and an SST-20 try the 7135×8 biscotti driver. Better UI and still very bright. If you want high current and the ability to disable memory LED4power’s LD-A4 driver has various current options and customizable settings like memory. I haven’t tried the LD-A4 yet but it’s on my list of stuff to try.
RelakS
Last seen: 1 day 15 hours ago
contactcr wrote:
Make batteries to spec and make lights to fit those. The consequences are rattling tubes,
That’s it, discussion is over Smile
Anyway, I could appreciate something which would center the battery within some size range. It would be really nice e.g. to fit a 18650 battery to a 26650 light without adapters, rattling, etc.
How should it work? I don’t know, but I have seen some 3D printed springy marvels already, what I were not able to imagine Cool
One more thing: Is it legal to have so much lumens in a so small light, like in the M3? Big Smile
Mine just has arrived. It has approximately the same brightness as the L6, but in a wider hotspot Shocked Brilliant!
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 23 hours ago
@Mark, tu peux l’acheter ici:
https://led4power.com/product/ld-a4-2-12amp-17mm-constant-current-led-fl...
You can buy it in the luink above.
RelakS
This lens fits almost perfectly to the front ring of the M3. I think, finally, I have the perfect high beam, which has enough power to complement the Busch & Müller Ixon Space? Smile
Actually, it would be nice to have a Convoy bike light, with a bike compatible beam pattern. (something like in the above link)
VaKo
Last seen: 5 days 18 hours ago
SST20’s seem to get hot fairly quickly even with 2.8A drivers, surely 5A would be pushing things too far?
Eleziel
Last seen: 8 months 3 days ago
Seems like it’d survive if heat sinked properly
oweban
oweban's picture
Last seen: 7 months 1 week ago
Agreed, my “6A should be fine” was based on a bit of hopeful dreaming. In an M21A, 5A is about the most I’d do.
BlueSwordM
Yeah.
You’d need the best host possible, and some great thermal paste.
Caleb
Caleb's picture
Last seen: 2 days 19 hours ago
Simon, are your 5 amp and 6 amp drivers designed for forward clicky or reverse clicky switches? Or can they be used in both?
BlueSwordM
They can be used with both. The Convoy S2+ is the proof of that.
However, it is more optimal for the rest of us to use reverse switches.
contactcr
Last seen: 23 hours 39 min ago
Keep in mind based on his photos of his new lights his newer higher powered lights using these drivers have the springs bypassed which will be highly recommended in your own builds.
Terry Oregon
Terry Oregon's picture
Last seen: 16 hours 8 min ago
Ordered the S21A and S11 this morning, the order status said "extended processing time 7-11 days".  However, it then shipped later this afternoon.
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK,  Convoy S21A LINK
Simon Mao
Simon Mao's picture
Last seen: 1 day 12 hours ago
both
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 5 days 9 hours ago
BlueSwordM wrote:
They can be used with both. The Convoy S2+ is the proof of that. However, it is more optimal for the rest of us to use reverse switches.
Je ne suis pas d'accord! Please don't take this as an offence BlueSwordM but there is no high current reverse clicky switch available that can sustain current drain above 8A without causing a significant increase in resistance in your entire current path. Thus, you lose output over the forward clicky switch. Another side effect is the terrible noise these kind of switches will make when applying too much current. Personally, I prefer the forward clicky with momentary turbo and a locked mode when fully pressing the tailcap switch. I have no problems when people ask for a reverse switch version but I do not agree with the phrase that for the rest of us it is more optimal to use reverse switches. Wink
aors10
Last seen: 11 hours 30 min ago
Simon, What about L21A with XHP50.2 ?
RelakS
In this case, I would prefer the L6 style. Switch is on-off (that is a forward clicky, if I am correct), and an electronic switch for the UI. If there are enough space in the tailcap, they could be next to each other, or if it is possible, the electronic switch could be a ring around the on-off switch.
I am very used to change mode after I have turned on the flashlight, maybe this is why I hate forward clicky.
Simon Mao
Simon Mao's picture
xhp50.2 can be installed in L21A
Satan@103TFS
Last seen: 23 hours 34 min ago
Simon could I order M3 with xhp50.2 ?
rooirissie
Last seen: 2 years 4 months ago
Hi, what is the difference between the Convoy l21a en m21a?
Fanus
BlueSwordM
@Lux-Perpetua, I wasn’t speaking in terms of resistance, but of UI choices.
Most people prefer using reverse switches vs forward switches.
oweban
oweban's picture
Black Convoy L21A host (L2 21700 version)
Forward switch
Length / Diameter : 179mm / 64.5mm
Weight: 540g
Black Convoy M21A (C8+ 21700 version)
Forward switch
Length / Diameter :155.8mm / 44.5mm
Weight 168g
L21A is significantly bigger and heavier. Bigger reflector, so more throw.
Nicolicous
Nicolicous's picture
Last seen: 9 months 2 days ago
Mark Piezó wrote:
Simon, why don’t you use MCU Attiny 25, 45, 85 and Crescendo firmware on your 5 and 6 Ampere drivers? It’s almost perfect firmware! Talk to TK. Plz! Your new drivers are a step back. Now we cannot even turn off the memory modes. Just like in Fenix light. Are you serious? Buddy, every time you step on the same rake. The hosts are excellent, and the drivers are not.
I agreed Smile
Nico -.-
SKV89
Last seen: 4 hours 37 min ago
Having the ability to turn off memory mode is very important
caramba
caramba's picture
Last seen: 1 week 1 day ago
Simon Mao wrote:
caramba wrote:
Simon,
Is there a remote possibility to order 5A bin for XPL-HI S2+ Desert Tan? Love
ok ,noted
Simon, so many new updates!!!. Thumbs Up
Any chance on the 5A bin for XPL-HI S2+ Desert Tan ? Beer
Simon Mao
Simon Mao's picture
only XHP70.2
Simon Mao
Simon Mao's picture
the host is different ,you can distinguish them via photos
Simon Mao
Simon Mao's picture
caramba wrote:
Simon Mao wrote:
caramba wrote:
Simon,
ok ,noted
sorry ,only got 4C in stock
aors10
Simon, could i order L21A with XHP70.2 ?
Tally-ho
Tally-ho's picture
Last seen: 1 month 5 days ago
ToyKeeper already proposed to help but it seems that it has remained dead letter and zero progress was made with Convoy’s flashlights UI, maybe Simon prefer to do things in his own way or maybe it’s because of people continuing to buy his drivers that he doesn’t see the point to improve UI, while better UI would make them even more popular.
Bistro UI at least for clicky, please !
oweban
oweban's picture
20mm with Anduril and potential for e-switch – sign me the hell up.
See: mtnelectronics’ 20mm FET + 7135. I’d be all over that except shipping from the US is a killer, so if Simon had something similar… Wink
