【convoy】219B R9080 TEST
5990 posts / 0 new
hasddie293
hasddie293's picture
Last seen: 8 months 1 week ago
aors10 wrote:
Simon, could i order L21A with XHP70.2 ?
Plus OP reflector for dedicated long/medium range flood flashlight…
A nicer tints selection 6500k-5000k-4000k..
Kit with battery?uhm…
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Simon Mao
Simon Mao's picture
Last seen: 1 day 14 hours ago
Mocarny wrote:
Simon, will the new flashlights have 1%, 10%, 40%, 100%, or 0,1%, 3%, 30%, 100%? I think second option is better, moonlight is sometimes needed.
M3 1%, 10%, 40%, 100%
other 0,1%, 3%, 30%, 100%
Mocarny
Mocarny's picture
Last seen: 1 hour 12 min ago
Tally-ho wrote:
I don’t want to discourage you
I finally found this UI and will contact the guy who makes it, maybe I can get only driver, without flashlight Smile
So if Convoy or anyone else don’t want to have it, at least I will get it Big Smile
If you struggle choosing your perfect headlamp, check my headlamp guide, I compared 15 most popular headlamps there: CLICK
Ryzbor
Ryzbor's picture
Last seen: 2 weeks 4 days ago
Mike C wrote:
Double press on a clicky for previous mode? Interesting, I’ve actually never heard of that before.
Personally I can’t see that as being superior to long press for previous mode, but long press has to work consistently and that has higher hardware requirements.
It’s very common in polish custom dual/triple channel drivers. It works pretty damn well, I would argue it’s superior over long-press for a couple of reasons. It’s fast and as Mocarny stated, you can’t really get it wrong, while I keep holding the switch too long or too short while using Biscotti. Here you have a short video demonstrating it:
It’s this super-customisable UI: https://www.swiatelka.pl/viewtopic.php?t=22154
Also the one Mocarny is talking about. The google chrome translation is very good.
But I think we all agree that Simon’s driver need a way to descend modes, either by long press or by double click.
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 ; Sofrin C01R 660nm, Mf01 Mini Nichia 219B sw35+sw40
Di_Joker
Di_Joker's picture
Last seen: 14 hours 44 min ago
Simon, could I order S11 with xhp70.2 ?
Sorry for my poor english.
oweban
oweban's picture
Last seen: 7 months 1 week ago
Reflector hole is 7mm iirc, so most likely won’t fit.
RelakS
Last seen: 1 day 17 hours ago
What would be good in it? M3 gets pretty hot in High mode, and it can’t even run a minute on maximum, because the driver and the LED gets so hot. In the end, M3 provides as much light (in high) as a normal S11 (in max).
Di_Joker
Di_Joker's picture
I am not interested in the turbo mode, I need more flood light in a more compact body S11.
Mike C
Mike C's picture
Last seen: 12 hours 51 min ago
With double press you can’t go wrong, double press is always previous mode, single is always next. With this long/short press you can press a bit too long, or too short and have wrong mode. You would love it Wink
I have done some rather extensive testing with double press, but for boost mode, not previous mode. It was brought to my attention in a thread I made asking for these kind of things: http://budgetlightforum.com/node/63771 (double tap discussion started at post #123).
So I have to disagree a little. I noticed with double press on a clicky that you can go wrong. There is a timing issue that must be dealt with, and that is you have to have a time difference between double press and two single presses. If I want to go up two modes I need to do two single presses. If I do them too fast they are interpreted as a double press. Too me this timing distinction faces the exact same issues as short press vs long press. I implemented it and settled on 200ms time limit for double press.
Believe me, I have tested this stuff a lot. I don’t get short press vs long press wrong. If the time limits are set fine, and you have hardware to support exact timing (like OTSM), messing up short press and long press is as difficult for me as it is for you to mess up double press vs two single presses. With that said, I now have support for double press so I’ll have a look at making a UI that uses it for previous mode. I have the space for it.
Interesting, thanks for posting. I’ll have a closer look at that, might give me some suggestions.
Anyhow, this is a Convoy thread, I should stop hijacking it.
Simon Mao
Simon Mao's picture
sorry ,the reflector is not suitable
LarryLumens
Last seen: 6 months 6 days ago
Hello Simon, is Convoy going to add 21700 and 18650 cells? It would be very good to have 1 stop shopping from Convoy.
Give me thrower or give me pizza.
passive101
Last seen: 5 months 6 days ago
What are the run times for the 4 brightness settings for the S21A?
Terry Oregon
Terry Oregon's picture
Last seen: 18 hours 10 min ago
I'll post some graphs when mine arrives in a couple of weeks. I generally do runtime graphs on ALL my new lights.
Don't think I've seen Simon list runtimes.
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK,  Convoy S21A LINK
Pete7874
Pete7874's picture
Last seen: 10 min 6 sec ago
Do we know beam intensity (cd) for S21A yet?
Pete7874
Pete7874's picture
Description of S11 XHP50.2 states “maximum output 3A” and yet it delivers 2400 lumen? Is this correct??
oweban
oweban's picture
Yep – should be on the money. 6V @ 3A, 18W…
http://budgetlightforum.com/node/53086
passive101
The S21A days max is 6amps, yet the output is slightly less?
oweban
oweban's picture
SST40, 3V @ 6A. 18W also.
passive101
Does this mean the s11 is twice as efficient for 2x the battery life if it runs at half the amps?
oweban
oweban's picture
It’s the same wattage though – the XHP50.2 is a 6V emitter, so it’ll have a boost driver. Unsure how that affects the efficiency, but the S11 also uses a 26650, so longer runtimes.
Pete7874
Pete7874's picture
Oh… ok. I guess my question is how many Amps does it draw from a cell? About 5-6A?
oweban
oweban's picture
My (semi-educated) guess is about that, yep. 18w/4.2v = 4.28, throw in some inefficiency, that’ll be ~5-6.
passive101
oweban wrote:
Pete7874 wrote:
oweban wrote:
Yep – should be on the money. 6V @ 3A, 18W… http://budgetlightforum.com/node/53086
How many amps does the S21A draw since it says 6amps on the website?
oweban
oweban's picture
Most emitters will go above 3V at 6A, but still, a 10A battery will well and truly be sufficient.
Sorry, I’ll start again. Some other data I’ve come across since.
An XHP50.2 at 3A will have a voltage of around 6.2V, giving 18.6W.
An SST40 at 6A will have a voltage of around 3.4V, giving 20.4W.
If you go by a full battery, then 4.2V:
  • XHP50.2 is pulling 4.42A (without efficiency drops)
  • SST40 is pulling 4.85A (without efficiency drops)
If by a “half empty” battery, then 3.7V (assuming it can maintain full draw, which is more of a buck booster thing):
  • XHP50.2 is pulling 5.02A (without efficiency drops)
  • SST40 is pulling 5.51A (without efficiency drops).
Again – 10A batteries will do this well and truly.
Simon Mao
Simon Mao's picture
guys ,who can do me a favor?
i want to know the correct diameter of sofirn soshine LISHEN vapcell 21700
I originally planned to buy these batteries directly in China. What I am depressed is that these Chinese-made batteries are not available in China or very expensive.
Really awkward Facepalm
Pete7874
Pete7874's picture
Which Vapcell? There are many. HKJ has all that info on his website.
https://lygte-info.dk/info/batteryIndex.html
Simon Mao
Simon Mao's picture
very helpful ,thanks so much
max 21.7mm
Unloco
Unloco's picture
Last seen: 5 hours 39 min ago
Simon Mao wrote:
i want to know the correct diameter of sofirn…
Sofirn 21700 4000mAh 40A that came in Sofirn C8F (bought on last 11.11): 21.6mm (measured at this time)
Simon Mao
Simon Mao's picture
ok ,thank you Thumbs Up
Agro
Agro's picture
Last seen: 2 min 16 sec ago
Yeah, do a 23-click to restore the previous configuration. Facepalm
