led4power build: osram CSLNM1 in c8+ and EE X6
20 posts / 0 new
netprince
Last seen: 1 hour 25 min ago
Bought a couple of the OSRAM KW CSLNM1.TG leds (and some ld-a4 drivers) from led4power so that I could install them over the holiday break.
Took a few shots.  This build was pretty fun, and the results are amazing.
The business end.  I definitely spent most of my time focusing these LEDs.  Used a 3D printer, along with trial and error, and finally hit a decent centering ring.
This is the EE X6.  (note I cropped the picture to remove my license plate)
This is the c8+ (note I cropped the picture to remove my license plate)
Swib
Very nice. I have all the parts to make a C8+ myself, just waiting to get some time off. What current did you set in the driver?
If you don’t like what it looks like on the wall, take it outside.
Lexel
Lexel's picture
LED should be driven at 4 or 4.5A
netprince
At first I had it set to 5.5a, but I am going to set it to 4.5a now…
blueb8llz
Last seen: 3 hours 43 min ago
Looks amazing bright and intense.
HONDARIDER
HONDARIDER's picture
Last seen: 5 months 3 days ago
Sure would like some good centering rings. How do the rings hold up to heat?
netprince
I’ve never had a problem with my home-made centering rings, but its always in the back of my mind, wondering if they will melt from the heat.
This is the best I’ve got for now…
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 5 hours 27 min ago
Good work mate do you have any numbers for the C8?
I think international outdoors has centering that work with these LEDs now.
netprince
I dont have any way to measure lumens or lux, sorry.
Thanks for the tip, I’ll have to look there for the centering rings.
10fp
Looks fantastic, i hav some coming with a Emisar D1S and also hope to fit one to my Nitecore P30 ( hope it has enough led amps in std driver )
BLF A6 S2+ SST40, GT Micro
a few C8`s , C8+ SST40, M21A SST40
HS 802, dd SST20 5k @4.6 amps,
P30,
Emisar D1S xp-g2 dd S4 2b
EC01
S70s,
UT02 - 5 amps and luv it ! with E2 3C
Klarus G35
Maxtoch New Sniper M24 dd U3
MF02 ,
FT03 SST40
Emisar K1
i think iv got it covered ! Wish list SP70 , SP36 BLF
malkoff junkie
malkoff junkie's picture
Last seen: 16 min 59 sec ago
excellent .
Malkoff !
voip
voip's picture
Last seen: 6 months 3 weeks ago
what a great build! thanks for the pictures and showcasing the challenges.
Yourrid
Yourrid's picture
netprince that’s an awesome build! I think I’m going to try my hand at an Osram C8 combo. What illuminated tail switch and boot are you using? Also, how long did it take to get the drivers?
Thanks!
ZozzV6
ZozzV6's picture
I got 191 kcd with C8+ at 4,5A
netprince
Thanks!
Its the illuminated switch from led4power…
This is the discontinued one here:
https://led4power.com/product/ilc-1-illuminated-tailcap-moduledrop/
I usually get my stuff in about 2 weeks, tracking usually works well too.
F.i.l.a.s
F.i.l.a.s's picture
Last seen: 3 months 2 days ago
netprince, wouldn’t you mind upload a 3D model of gaskets? For example there:thingiverse.com
This would be really nice having a 9mm cent. gasket.
I only have a 7mm gaskets from Hank. (for S2(+), M2 etc.)
netprince
Here is the c8 gasket which worked the best for me:
http://files.oneitguy.com:8008/c8+_osram_ring3.stl
edit: fix link
F.i.l.a.s
F.i.l.a.s's picture
Thank you :). I let you how succesfup I was in this project.
BobbyMK
BobbyMK's picture
Last seen: 5 hours 21 min ago
Thats right about the same as my black flat C8. If i remember corectly i got 196kcd. The black flat was hard to focus properly, i wonder how hard is to focus this one.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
BigPop96
I cannot see the photo. Can you please upload again.
