Convoy L2 XHP50.2 K2-1C outdoor performance
151 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 2 weeks 2 days ago
Looking forward to it Simon, Thank you for going to the extremes for us! Smile
1stein
1stein's picture
Last seen: 15 hours 4 min ago
Thank you Simon, in return I’ll keep buying Convoy as most often of all Beer
HONDARIDER
HONDARIDER's picture
Simon Mao wrote:
mhds wrote:
Simon Mao wrote:
driver for XHP35 HI?
The entire L2 flashlight with XHP35 HI Smile
i’m ready to launch L6 with XHP35 HI ,
the original reflector of L6 is not suitable .
manufacturer is designing new reflector and gasket
This is going to be awesome. Be a great addition to the collection.
Simon Mao
Simon Mao's picture
Last seen: 19 hours 44 min ago
Lux-Perpetua wrote:
Hi Simon,
Can you please give us some more information about the XHP35 HI driver?
Is it a new developed driver from your usual supplier or does it come from KD?
Will it also work 1S (1× 26650) or 2S (2×26650) only?
What is the maximum current it can apply to the XHP35 HI?
What diameter sizes of the driver can you offer?
Thank you!
2A output ,diameter 30mm ,
only runs on 2*26650
what’s the max intensity of BLF GT?
i got a L6 reflector today ,it’s bad ,
i use L2 reflector ,i got 160000CD if XHP35 HI runs on 2A current
(the bin of XHP35 HI is D4 50E)
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 month 1 week ago
Okay, so it’s not possible to boost to 12V with only one battery. Sad I guess Kaidomain’s H1-A will still need some tuning for providing 1.5A to the XHP35HI from a single cell. But I see that Sofirn will soon launch the C8G (1× 21700 with XHP35 HI, SMO and 2.000lm). In my opinion the Convoy L2 makes much more sense with XHP35 HI. The L6 is quite a large light for this little amount of lumens (max. 2.000lm), its small reflector diameter in comparison to its length and its moderate power consumption. The XHP35 HI is – to my mind – for throwers and the L6 is more or less an allround-like flashlight but no thrower, perfect for XHP50.2 or XHP70.2. Just sayin’… Wink
Barkuti
Barkuti's picture
Last seen: 15 hours 37 min ago
According to Jensen567's figures the H2-C still did well at “2A” gear, but pay attention to the already low efficiency at that point (1S input with R075 + R075 sense resistors). Since high mode uses a 60 second stepdown you may try an R100 over the stock R050 (2.25A maximum), but beware of the low efficiency risks, high current losses in switches, springs, etc.
If I were Simon I would go to driver designers and manufacturers and tell them to “stop complaining and make an outstandingly powerful driver, this is for enthusiasts”.
Party
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
Simon Mao
Simon Mao's picture
boosting to 12V with only one battery can be designed,But the efficiency is too low,
ZozzV6
ZozzV6's picture
Last seen: 2 months 5 days ago
The BLF GT has 800 to 1200kcd. Depends on how good batch one get.
DB Custom
DB Custom's picture
Simon, just so you know, Richard at MTN Electronics has designed a Boost driver that works with one or two cells and delivers 2.3A to the XHP-35. This is good for over 2000 lumens in your C8+. Smile Perhaps you should work out a deal with Richard?
For what it’s worth, this same driver of Richards also excels in the L2, amazing lights these 2! Big Smile
BlueSwordM
BlueSwordM's picture
Last seen: 2 weeks 6 days ago
Oof that would be super expensive.
Maybe a special BLF edition at 70-80$US?
Simon Mao
Simon Mao's picture
uh ,thanks,i still want to install XHP35 HI in L6,
At present, the design of the reflector is not ideal.
Eleziel
I put a 3v XHP50.2 in my L2 @12A (single cell). it’s a nice light, easy to focus. just guesstimating by eye, CD is a little higher than stock, but quadruple the lumens.
About the anodizing, my l2 came like it was wrapped in sandpaper compared to the super smooth ano from the S2+‘s
vietnamreviews
DB Custom wrote:
In my experience with modding the L2, the XP-L HI will give the most throw even over the XHP-35. Sufficient to say though, the XHP-35 comes close and gives more total output in the process. Significantly more light.
I have a machined finish L2 with XHP-35 HI using a prototype boost driver and it really seriously rocks. Big Smile (~2300 lumens? Edit: From notes, 2246 lumens at 266.75Kcd for 1033M throw) Run time on a single high discharge 26650 is similar to what a pushed XP-L HI will draw, the extra lumens come in very handy. I also have a black L2 with extension tubes and 4 26350 cells utilizing a tweaked LED4POWER driver to run the XHP-35 at a maximum, it too does a very good job and run time is sufficient for me. I do like the short configuration of the L2 the most though and the machined finish light is just exceptional, jewelry grade. Love Thanks Simon! Thumbs Up
Edit: FWIW a sliced and diced SST-40 also rocks the L2. Just saying… (careful, this one has bond wires!)
Edit: To add, a modified L2 with XHP-70.2 also impresses, just not so much in the throw department. I built one for my Bro-in-Law that he loves, something in the 7000 lumens range. He’s a hunter and uses it regularly, fights my nephew over it all the time! lol
Can I buy drivers on aliexpress or banggood. I want to upgrade convoy L2 with XHP70.2. Thank you
DB Custom
DB Custom's picture
I don’t know of available drivers that will supply the optimum current to the XHP-35 as far as Banggood or even on Aliexpress. The drivers I have used are from members of this forum. One in the US and one overseas. LED4Power’s drivers can be configured to use 4 cells to power the 35, these require extension tubes on the L2 to allow the use of 4 26650’s or a normal 2 cell tube set-up can make use of 26350’s with shorter run times. The US made Boost driver can use one or two cells to power the 35 to 2.3A or so, these are the more expensive but more compact option. This latter comes from Richard at MTNElectronics.
vietnamreviews
Thanks so much my friend
DB Custom
DB Custom's picture
Eleziel
DB Custom wrote:
LD-B4HV 2-12Amp 2S/4S Multi-Cell 17mm Constant Current LED Flashlight Driver
He said he doesn’t plan on making any more of these.
DB Custom
DB Custom's picture
He has new options I suppose. I haven’t looked at his drivers for 12V use lately, bet he could shed light on it though if asked. Wink
Junkwhale
Last seen: 11 months 3 weeks ago
Is there an L2 extension tube available separately? I’ve seen pictures of an L2 that comes with one that looks like it’d screw into the L2/L6:
Asking because I just got an L6 and it’s great, but surprisingly it’s smaller than I’d hoped for. Would love to be able to add an extension tube or two and swap the driver for a 3S or 4S one to have a proper maglite form-factor replacement with modern internals!
Simon Mao
Simon Mao's picture
sorry ,i dont have extension tube
Newlumen
Newlumen's picture
Last seen: 1 year 8 months ago
How about using sst40 shave dome on the l2 ? 200kcd easy.
mhds
Last seen: 2 years 1 month ago
Hello Simon,
Any news about L2 on XHP35HI ? Smile
Candil
Hello Simon!! apart from keeping our pockets empty LOL, is there an interest from your behalf of making a helmet light for mtb or mounted on the front of a bike, thanks!!
vietnamreviews
I am waiting for the driver with 2 cell for Convoy L2. It works with xhp 50.2 or something similar for about 2400 lumens.
Simon Mao
Simon Mao's picture
mhds wrote:
Hello Simon, Any news about L2 on XHP35HI ? Smile
L21A with XHP35 HI will be available soon ,the output current of driver is 2.3A
Redlyne22
Redlyne22's picture
Last seen: 2 days 11 hours ago
Simon Mao wrote:
Delta_V wrote:
Satan@103TFS wrote:
Simon do you have any plane to make L2 with XHP35 ?
Unlikely, as the XHP35 is only available in a 12V configuration, which would require the use of a boost driver. The XHP50 and XHP70 are also available in 6V configurations, which is what Simon is using here. Powering a 6V emitter with two cells in series is relatively straightforward. Developing a 12V boost driver would be considerably more difficult.
i will supply XHP35 driver for L2 flashlight soon Big Smile
This would be awsome, but 1000mah is a bit low. You would get better lumems and lux number with a sst40. 2000mah minimum for the 12v xhp35
Sometimes being a newb is the best part of a hobbie
mhds
Thanks Simon, looking forward… Smile
mhds
Hi Simon,
Any estimated date for releasing L2 XHP35 ?
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 2 days 17 hours ago
Whats wrong with the reflector? Is the opening to wide and it sits to high? People have done it on here already.
Simon Mao
Simon Mao's picture
although the diameter of L2 reflector is small than L6, but it’s more suitable than L6 ,i campared them several times ,
L2 reflector can get more LUX
