I hope you have read my post where I explained that this is the expected behavior in Anduril 1 and that it has changed with Anduril 2.
SammysHP wrote:
Kiki wrote:
Is it a documented feature or a bug in Anduril that if the ramping mode setted to smooth ramping, and the lamp is in locked mode, the 1h lowmoon and the 2h highmoon, while it setted to stepped ramping, the locked mode is 1h highmoon and the 2h lowmoon?
That’s a documented feature. 1H is floor of current ramp style, 2H floor of other ramp style.
It has changed with Anduril 2: 1H is lowest floor, 2H is other floor or manual memory if enabled.
You guys would probably like my version of Anduril then. I got rid of the blinkies on the 3 click menu – all it does it voltage readout, temp read out, and version num blink I up’ed the max temp to 90C as well.
Thank you, ToyKeeper for all of this! I'm usually not a huge fan of learning a new "language" to use a new tool, but I recently acquired my first Andüril Light and it's been a lot of fun to learn and use. I'm a fan. I've since placed orders for more than a few more lights with this U.I. Mad props.
Gonna be my EDC U.I. if I can remember to electronically lock 'em out. Just retrieved my LM-10 from my side to find out it's been on for who knows how long, luckily not on too high of a brightness level though.
Not sure if this is where I might find an answer (I suppose the answer is out there, but I can’t find it using search terms)..
Regarding “Beacon mode”, for Anduril 1 & Anduril 2,
what is the shortest time for beacon mode (ie. no light for xx second, up to what’s the longest time in-between each beacon flash)?
I seem to remember beacon can be as short as once every second (or can it be faster?) and as long as 10 seconds between flash (but maybe it can be set even longer?)
I think this might be the right thread to ask my question….
I hate stepdown and for that reason want no or a hidden turbo.
I’m once again considering Emisar D4V2 and Noctigon KR4 quad.
The Noctigon highest non step down level seems to be 400lm click for review
Is it possible to set 400lm as high and remove/hide anything above that?
My ideal setup would be High, mid, low and hidden turbo and moonlight.
FWIW: Anduril 1 manual – text Anduril 2 manual – text
Of course, these are generic (flashlight model independent). Anduril is tailored to some flashlights for certain special features like tint ramping, dual channel, and aux LED control.
Yeah, i’ve read it just interpreted in other way, sry
Where can this be found?
Hi, Tom E
Is this – https://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/files/... – latest revision of anduril? And if it is available, is anywhere sources of Anduril2 available to look how temperature control changed over Anduril 1.
Thank you.
Can I set turbo level of my Sofirn IF25A?
Turbo is always full power.
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88 4/5, LiitoKala: 3x100 3/5, 2x202 3/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, DQG Tiny III 18650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Skillhunt H04FRC 4/5, Sofirn C01 BLF 3200k/5600k 2/5, Zebralight H600Fc 3/5.
Powerbanks: Romoss 30000 4/5, xiomi 1000 4/5, Xtar PB2 4/5, Xtar PB2S 5/5
Yes that's possible.
Go to http://toykeeper.net/torches/fsm/anduril2/anduril-manual.txt
and search for "Ramping / Stepped Ramping Modes" and "Ramp Config Menu" and give that a quick read and you'll see that you can config it just the way you like.
FWIW:
