Test/review of Molicel INR18650-P26A 2600mAh (Gray)
12 posts / 0 new
HKJ
HKJ's picture
Last seen: 10 hours 23 min ago
DSC_5276
Official specifications:
  • Rated typical capacity: 2.6Ah
  • Rated minimum capacity: 2.5Ah
  • Discharge capacity at 20A: >2.3Ah at 23°C
  • Nominal voltage: 3.6V
  • Rated charge: 2.6A, 4.2V, 50mA cut-off
  • Rated discharge: 0.52A down to 2.5V
  • Internal resistance: <20mOhm @ 1kHz
  • End of charge voltage: 4.2V +/- 0.05V
  • End of discharge voltage: 2.5V
  • Maximum charge current: 6A
  • Maximum discharge current: 35A
  • Cycle life: 500 cycles at 2.6A charge and 10A discharge
  • Operating temperature: Charging: 0°C ~ 60°C, Discharging: -40°C ~ 60°C
  • Storage temperature: <35°C, recommended
Molicel%20INR18650-P26A%202600mAh%20(Gray)-info
This is a high current cell from one of the top brands.
DSC_5275
DSC_5277 DSC_5278
DSC_5279
DSC_5280
Molicel%20INR18650-P26A%202600mAh%20(Gray)-Capacity
This is very nice discharge curves where the two batteries tracks at all currents and capacity do not drop much with current.
Molicel%20INR18650-P26A%202600mAh%20(Gray)-Temp-20.0
Molicel%20INR18650-P26A%202600mAh%20(Gray)-Temp-30.0
Molicel%20INR18650-P26A%202600mAh%20(Gray)-CapacityTimeHours
Molicel%20INR18650-P26A%202600mAh%20(Gray)-Energy
Molicel%20INR18650-P26A%202600mAh%20(Gray)-PowerLoadTime
Molicel%20INR18650-P26A%202600mAh%20(Gray)-TripCurrent
Molicel%20INR18650-P26A%202600mAh%20(Gray)-Charge
Conclusion
This is one of the best high current cells at the current time (Early 2019).
Notes and links
The batteries was supplied by N-Power Energy for review.
Graphical comparison to 18650 and other batteries
Edited by: HKJ on 01/21/2019 - 11:24
Shadowww
Last seen: 8 hours 8 min ago
Your formatting is a little bit broken in the beginning of the post.
Looks like a great battery, although I’ve never heard of Molicel before.
HKJ
HKJ's picture
It is fixed now.
wolfdog1226
wolfdog1226's picture
Last seen: 2 years 7 months ago
Thanks for the review,,,been waiting for this one! Thumbs Up
These are GREAT cells. My Hometown dealer[Liinonwholesale.com] is the ONLY authorized USA dealer…0.9 miles away!
FRESH CELLS! A=2010 B= 2011 ECT,,, I919= I2018 919=September 19th……….yours are 2018 Sept. 18th!
You got 2533Mah @ 1Amp
My 4 Slot median is 2614mAh
P.S. MORE proof that the Apexium INR 18650 2600mah and the Vapcell INR 18650 2600mAh [Green] are using this cell as the voltage curves are basically identical for ALL Three cells.
Invigorating hike w/ CAPO this morning,,,Chill factor was Minus 17F/ Minus 27C!
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
BlueSwordM
BlueSwordM's picture
Last seen: 4 hours 27 min ago
@wolfdog, the tester used by HKJ is a constant current tester.
The tester you have uses a resistor based tester. Meaning current drops as the voltage drops, and therefore, the capacity is overestimated.
teacher
teacher's picture
Last seen: 2 years 5 months ago
Yep, all Opus chargers read a little high on a discharge test, I know mine does. No big deal as long as that fact is recognized & accounted for.
Nev
I’ve got one molicel P26 ,had it for about a week ,on my skyrc mc3000 the IR is 17 ,& after first use ( after a full charge ) from just over 3 volts it put just over 2600 mah in when charged @ 1amp , I havnt done a discharge test yet.
wolfdog1226
Thanks,,,I know that. My Opus is usually 3% to 5% higher than HKJ.Although I have had some numbers in the last few years that were less than 0.1% higher. Wink
In this case my numbers are 3.1% higher. Big Smile
        WOLFDOG
teacher
teacher's picture
/\ …. Thumbs Up
Nev
I think the opus is about right & here’s why , firstly it undercharges ( unless the solder bridge has been desolderd ) secondly it over estimates , so therefor one cancels the other out & it’s more or less on the money.
contactcr
Last seen: 4 hours 59 min ago
The people buying this cell are going to care more about the high drain performance rather than the total capacity. I guess it appears to be right in line with the VTC5A. Is it better? VTC5D is probably better but at a much higher cost
wolfdog1226
I use it in my TN42vn90. Get 25 minutes of max output w/ voltage @ 3.54V. I have 2 carriers[8 total batteries] ,,,,,,,,,,just swap the carriers instead of messing with the batteries.
Another testers opinion: NO mention of the VTC5D,,although he tested that battery.
Bottom Line
This appears to be the cell that was rewrapped for the green Vapcell 25A 2600mAh and Ampking 35A-45A 2600mAh cells. It is a great performer that beats the Sony VTC5A, equals the Samsung 25S, and almost equals the Samsung 24S or Sony VTC6A.
        WOLFDOG
