The 3 and the D look like they should be legit, at least look as they should on flat tops. I have fake flat top 30Q’s from Az and real 30Q’s from Mtn. Electronics and that is the difference that I was told to look for and noticed with mine. Not sure if this is the case with button tops.
I don’t think yours will fit in the battery carrier. The top is to big, it looks like to me. They look more like a very slightly raised flat top “to me”. Hard to tell from a picture for sure though.
Can you try them in the battery carrier before you buy them?? (If the light you plan to use has a carrier that is.)
They look like the 30Q button-tops I bought from Banggood last year. I use them in battery carriers and lights that require button tops, so he should be good to go with those.
Exactly from all the images they do look like 99% Banggood 30Q Button tops.If you go to BG link of BLF GT for sale those batteries are recommended by them
I agree. As I said above, it is very hard to tell by the picture; but something looks off about those to me. The diameter of the button tops looks bigger than normal or something.
But, if they end up fitting; so what.
I got some 35E’s with the crappy button tops like the one in the middle with the BLF Group Buy.
They just barely make contact with the carrier, and I mean BARELY!!!
I would much rather have the “Robust Button Top” from LiionWholsale. All the 30Q Button Tops I have bought from them were of the “Robust” vintage. . :+1:
