XHP70.2 Convoy L6 4,300 Lumen
40 posts / 0 new
vestureofblood
vestureofblood's picture
Last seen: 5 hours 56 min ago
Hi all,
The new version of L6 is out Smile
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
USA
USA's picture
Last seen: 5 months 5 days ago
Nice light and video, seems like a bright light Smile
Dioda
Last seen: 1 month 1 week ago
Matt, which XHP70.2 tint do you find most eye appealing? Im considering getting one on sale, how good is the 5000k version? Im not planning dedoming, but the resistor wire bypass looks easily doable.
Blinkinglights
Last seen: 1 week 5 days ago
I just bought mine with regular 70, OP reflr. I ordered the SMO separate. I have bunch of 70.2 laying around, will do the mods to emitter and driver. Need the the throw, but I do not like the darker yellowish tint.
Me love lights lonng tyme!
FlashPilot
FlashPilot's picture
Last seen: 2 hours 10 min ago
Well done! As always, thank you for a great analytical review and comparison. Is Simon still running the game?
vestureofblood
Dioda wrote:
Matt, which XHP70.2 tint do you find most eye appealing? Im considering getting one on sa sťahujesale, how good is the 5000k version? Im not planning dedoming, but the resistor wire bypass looks easily doable.
I am partial to cool whites myself, but 5000k has a nicer blend on it. They are both P2 bin so if you have an inclining toward neutrals I would go with that.
Indeed.
JordanZHP
Last seen: 2 weeks 20 hours ago
Thanks for the review! How soon can we expect X70 review? Smile
pennzy
pennzy's picture
Last seen: 2 min 13 sec ago
I just ordered a L2 with XPL HI. What current do you consider max for this and is 0 ohm in parallel also ok? A wire in parallel?
Tweakmeister
Last seen: 2 days 10 hours ago
Does anyone have a lumen chart? What does it settle down to after turbo and when?
vestureofblood
Probly this week, but if not next week. I’m already working on it.
I don’t have an L2 so I can’t say for sure.
There is no turbo timer on the L6
polarweis
polarweis's picture
Last seen: 1 month 3 days ago
L2 uses another driver(ld-25)
You can direct drive a xpl hi.
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
pennzy
pennzy's picture
So basically shorting the resistor is ok?
vestureofblood
Not necessarily. You can direct drive an XPL hi on one 26650, but two would certainly kill it.
pennzy
pennzy's picture
Thanks for pointing that out. So not a good idea. What would be a good amperage to shoot for that leaves the 2 cell option open but gives the L2 some oomph. Also, are low and med. affected with this mod?
vestureofblood
I like to run XPLHI at around 5 amps myself. You can go a bit higher, but it gets hard to sustain the higher output.
http://budgetlightforum.com/node/52227
In TAs chart you can see he is getting some gains at 6 amps but basically nothing after that, and this is a control test, so if you drive the LED at 6 amps for 10 minutes you might actually have lower output than if you were at 5.5A for 10 minutes because of the heat.
Blinkinglights
I got my L6 with OP two days ago, just was ok, it did I think 3200L’s. I swapped out the OP for an SMO, ditched the 70 for 70.2. 65k, bypassed both spings with 20awg wires, change the power wires for 20awg, and just straight bypassed them BA sense r’s with braided wire. 6910 Lumens.
No stepdown, works very well and runs cooler on the handle than my Wowtac A4, MF04S modded, and blfgt70 after 2 mins on highest.
BTW, check your bargain L6, mine came from banggoods fp’d up at the head. 1. screw hole that holds down mcpcb, one was larger than the other and had no threading in it. It served no purpose. 2. Top of threads on the head was damaged, looked as though it fell at the factory on dull sword then banged on the assembly table to ovalize it for good measures to maybe prevent it from sealing out moisture just before they screwed on the lid.
Satan@103TFS
Last seen: 1 day 3 hours ago
What different of boost current between stack R100 resistor and wire bypass ?
Blinkinglights
Well I guess you mean stack like in iHop 3 pan cakes, lol.
Stack of 3 r100 would be .0033ohms or just .003ohms vs. 0 ohms, stock was .082×2= .04, correct me if I am wrong.
I was also pulling 11amps at the tail cap from two efest high drain and around 4.5 amps stock at the tail cap.
Satan@103TFS
XHP70.2 should be fine but is the driver work properly at 11A?
mortuus
mortuus's picture
Last seen: 3 hours 8 min ago
this should have been driven to more then 4300 only, why only so little? i think the host can easy handle 5000+ and more no ? looking mats video its only about a 500 difference in lumens vs the old xhp70 emitter.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
HONDARIDER
HONDARIDER's picture
I put the 0 ohm resistor, installed a 70.2 (4000K) in my older L6 and kept the OP reflector in it, amazing performance. Not sure if I am going to de-dome it because I like the beam profile as is. I may do all the mods to a different one.
Pentaprisma
Last seen: 2 years 4 months ago
I just got myself the L6 XHP70.2 and fitted two brand new Keeppower 5200mAh batteries. For some reason, the flashlight doesn’t light up at all.
Do you guys know if it could be the batteries, not having a high enough max continuous discharge? These batteries do work on the L2, so batteries are definitely ok.
What batteries do you use?
If these batteries should work, then there is a problem with the flashlight.
Please help…!
Thanks Thumbs Up
Tom E
Tom E's picture
Last seen: 9 min ago
Are they flat tops? If so, could not be making contact . Assume you used singles in the L2?
Pentaprisma
No, they are button tops. I’ve tested them both on the L2, 2 cell config, and they work.
Have the Keeppower 5200mAh batteries enough power to work on the new L6?
Thanks
Tom E
Tom E's picture
Oh boy, I got tons of 26650's, and let me see - I got one modded XHP70 with a BLF OSHPark board, and one pretty much fully stock XHP70, maybe XHP70.2. I typically use the blue covered 5000K LK's, but I stay away from KeepPower cells in general - rewrapped who knows, and their history of denials and not telling what they use has been frustrating.
Are they protected? If so, do you know the max amp ratings? Might be maxing out the protection circuit. I also generally stay away from protected - only use them for testing purposes. For example, I bought a set of 4 GA protected 18650's at the time for testing on the Q*, since many BLFers were asking bout protected cells.
The better protected cells nowadays have high amp ratings, like 10A to 12A, or thereabouts but dunno the ratings of KP's - hhm, should google up these 5200's....
Update: Ahhh, here they are unprotected: https://www.illumn.com/26650-keeppower-5200mah-imr26650-high-discharge-flat-top.html?gclid=Cj0KCQjwjMfoBRDDARIsAMUjNZoX5ZepAVoZUbwt2sv2bxZ84JAdjI-U3DrVXAdOldwfpPDv5skcPdMaAjByEALw_wcB
Here they are protected, and 9.5 amp rating: https://usa.banggood.com/Keeppower-ICR26650-5200mAh-3_7v-Protected-Rechargeable-Li-ion-Battery-p-961178.html?gmcCountry=US&currency=USD&createTmp=1&utm_source=googleshopping&utm_medium=cpc_bgcs&utm_content=garman&utm_campaign=pla-usg-rm-all-purchase-pc&gclid=Cj0KCQjwjMfoBRDDARIsAMUjNZqZzKULLiP9Blxmkm7dq5QxG_e_s9Pbb7G9h3kY_j4EXGGyun6mhZAaApGrEALw_wcB&cur_warehouse=CN
So all depends... Hhmm. On a stock L6, 9.5 amps? Hhmm, dunno, might be close, might trip - it's rated at 4300 lumens, so dunno off hand -- any reviews post the amps drawn?
Does the light work at low settings?
Pentaprisma
Hi Tom E, thanks for your reply.
My KP’s are 5200mAh button tops protected cells rated at 9.5A max discharge.
These cells work on other flashlights. All I need to know is if these cells would work on the new XHP70.2 L2. If they do, then the flashlight I got is faulty.
Does anybody know if they should work at 9.5A max discharge?
Thanks.
Tom E
Tom E's picture
No one posted amps readings, not even in the vid review of the OP. I don't have a new L6 XH70.2, but my old ones I should have notes on at home (at work now).
My guess is the 9.5A cutoff of the cells. You could try this: pop off the tailcap, try a long thin wire between the battery tail end and the no-anodized surface of the tube's end, compressing the batteries down. This maybe will drop the amps enough to not engage the over protection circuit.
Are you first turning the light on with the tail switch, then clicking on the side e-switch? You do realize the power tail switch must be on for the light to work? Might be a dumb question, but good to check the basics.
mortuus
mortuus's picture
Please help…!
Thanks Thumbs Up
hm, see this video perhaps its of help.. the batteries should be ok and so the flashlight..
              つ ◕_◕ ༽つ
fluke
Last seen: 2 days 3 hours ago
Got an L6 running those protected Keeppowers all fine here.
Pentaprisma
Is that L6 the XHP70.2 version..?
fluke
Yes the 4300 lumen one with smooth reflector.
Use it regularly when walking dog at night.
