Soshine C 5500mAh (White)
Official specifications:
Battery Capacity (Mfg Rated): 5500 mAh
Battery Chemistry: NiMH
Battery Maximum Voltage: 1.4 V
Battery Rated Voltage: 1.2 V
Minimum capacity: 5000mAh
Internal resistance: 20 milliohm
Standard charge current: 1100mA
Fast charge current: 2500mA (2.4hrs)
Maximum temperature raise at different discharge currents: 1A:+0,0°C, 2A:+1,0°C, 3A:+2,1°C, 5A:+5,4°C, 7A:+9,0°C, 10A:+13,2°C, 15A:+18,8°C, 20A:+20,1°C
The NiMH C cell from Soshine.
These two cells do not match capacity and are below rated capacity, at least the mismatch in capacity is only a minor problem with NiMH.
Conclusion
The batteries have a good capacity, but not as much as promised.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
