Test/review of Nitecore 18650 2900mAh NL1829LTHP (Black-yellow) 2018
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 6 days ago
DSC_4394
Official specifications:
  • Capacity: 2900mAh
  • Voltage: 3.6V
  • Current: 8A
  • Low temperature resistant to -40°C
Nitecore%2018650%202900mAh%20NL1829LTHP%20(Black-yellow)%202018-info
This is a protected 18650 cell that can be used at lower temperatures.
DSC_4372 DSC_4373
DSC_4395 DSC_4396
DSC_4397
DSC_4398
DSC_4399
Nitecore%2018650%202900mAh%20NL1829LTHP%20(Black-yellow)%202018-Capacity
THe normal test shows a good quality cell that can handle up to 5A, the protection trips if discharge for some time at 7A.
Nitecore%2018650%202900mAh%20NL1829LTHP%20(Black-yellow)%202018-Temp-5.0
Nitecore%2018650%202900mAh%20NL1829LTHP%20(Black-yellow)%202018-Temp-7.0
Nitecore%2018650%202900mAh%20NL1829LTHP%20(Black-yellow)%202018-CapacityTimeHours
Nitecore%2018650%202900mAh%20NL1829LTHP%20(Black-yellow)%202018-Energy
Nitecore%2018650%202900mAh%20NL1829LTHP%20(Black-yellow)%202018-PowerLoadTime
Nitecore%2018650%202900mAh%20NL1829LTHP%20(Black-yellow)%202018-TripCurrent
Nitecore%2018650%202900mAh%20NL1829LTHP%20(Black-yellow)%202018-Charge
The test below is done in a freezer with free air around the battery, all equipment is outside the freezer.
Nitecore%2018650%202900mAh%20NL1829LTHP%20%28Black-yellow%29%202018-LowTemp-1.0
This is a 1A discharge at -20°C, the batteries fairly fast increase their temperature with 5°C and this improves the performance.
Note: Temperature curve is behind the internal battery temperature, i.e. the red curve will react way faster than the blue curve.
Nitecore%2018650%202900mAh%20NL1829LTHP%20%28Black-yellow%29%202018-LowTemp-2.0
At 2A discharge the voltage drops to nearly 3V, but recovers significantly when the battery heats up.
Nitecore%2018650%202900mAh%20NL1829LTHP%20%28Black-yellow%29%202018-LowTemp-3.0
The 3A discharge nearly hit the termination voltage, before it recovers. The batteries are above 0°C when the discharge is done.
Conclusion
The battery is a good quality LiIon battery and it sort of works in the cold. The “sort of” is because it need to heat itself up to get some performance.
Notes and links
The battery was supplied by a Nitecore for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Agro
Agro's picture
Last seen: 2 min 3 sec ago
Nice. Smile
I wonder if drivers could use temperature sensors to adjust their low voltage cutoff.
For example 3V when it’s hot but dropping to 2.8V when it’s freezing….
bmengineer
bmengineer's picture
Last seen: 10 months 3 days ago
Thanks so much for doing these tests! Do you have any idea how normal cells perform in the same environments for comparison? Is there a way to show the Wh in the cold tests to see how much capacity is lost?
Find all my reviews of flashlights and more gear at www.bmengineer.com
HKJ
HKJ's picture
I do not have any normal cells yet, I am looking for some good candidates to test (I have played a bit with some rewrapped cells).
The Wh is recorde in my logfile:
A cell 1A: 7.24Wh
A cell 2A: 6.98Wh
A cell 3A: 6.86Wh
bmengineer
A cell 1A: 7.24Wh
A cell 2A: 6.98Wh
A cell 3A: 6.86Wh
So that shows about a 27% loss across the board. Not terrible. Looking forward to seeing how standard cells compare.
light-wolff
Last seen: 4 weeks 16 min ago
I’d love to see how SDI 30Q, LG HG2, Sony VTC6 perform under these conditions.
mcfarlie6996
mcfarlie6996's picture
Thank you for the review!!!
HKJ wrote:
The normal test shows a good quality cell that can handle up to 5A, the protection trips if discharge for some time at 7A.
That’s disappointing considering they’re actually labeling it as an 8A battery.
I guess this battery (and probably all high quality 18650 batteries) would benefit from a light that has a boost driver more than anything. Trying to get 3A from a 1000 lumens light (that uses a linear driver) might not be possible from a battery that drops down to 2.8-3.0V at startup. Either way this is a good example why it’s important to warm your batteries if possible before using if you store the light in your car during the harsh winters.
dts71
Last seen: 17 hours 39 min ago
What kind of cell is it under the wrapping?
Barkuti
Barkuti's picture
Last seen: 12 hours 4 min ago
dts71, more than probably it is a Panasonic NCR18650F (datasheet @ DatasheetsPDF.com).
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
dts71
Thanks!
